Question about ViewSonic VE155b 15" LCD Monitor
Monitor is on, goes light to dark in 1 second
I switch monitor on, the light goes on for 1 second but then evrything goes dark. please help me. Thankyou
Ii have the same problem help me
Posted on Jan 26, 2008
    Problem Solver:
  • 6 Answers
I have the same problem with my Dell 17" monitor. I've been reading and what others with similar problems say is that the power supply has a bad capacitor.
Posted on Aug 08, 2007
SOURCE:
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
Monitor comes on and then immediately goes dark goes off
Your monitor's power supply is probably bad. If your inclined, you can pry apart the monitor shell and replace any bulged capacitors you see on the power supply. Replacement capacitors are available from mouser.com.
Mar 30, 2013 | Computers & Internet
Used as second monitor suddenly stared to go dark
If the screen is lighting up for a fraction of a second when you turn on & then goes dark, this indicates a fault either with the backlights on the screen or the inverter part of the monitor. You can check the backlights if you have access to a backlight tester, you need to remove the rear cover & connect the backlight cables into the tester, if this checks ok then look for a problem on the inverter board, checking the capacitors for any signs of distress.
Aug 11, 2009 | LG W1934S-BN 19" Monitor
SCREEN GOES DARK TWO SECONDS AFTER ITS SWITCHED ON
when it goes dark disconnect the data cable of the monitor from the system end and if u still see nothing
monitor bad and if u see the colour scheme monitor working system is the culprit
Oct 04, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor problem.
This just happened to me last night.  My web research indicates that the monitor is bad...others have had the exact same problem.
Oct 25, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Open Questions:
See all ViewSonic VE155b 15" LCD Monitor Questions
ViewSonic VE155b 15" LCD Monitor Logo
219 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
