Question about Garden
Belts wont move
I have a Troy Bilt Super Bronco model 6605 riding lawn mower. When I move the lever to engage the blades, it seems like the pulley's are not moving right because I get a burning smell right on the front main pulley and it seems like the belts are not moving and since they cannot move they burn. Why is this and what can I do?
    Problem Solver:
  • 5 Answers
I would check to make sure that that the belt isn't pinched somewhere around the pulleys. See if they are movable with mower disengaged and off. If they are hard to move, they most likely have pressure keeping them from moving.
They would create a burning smell even though they are not moving. The main pulley while engaged does rotate and if the belt is touching but not moving, it will rub enough to make the odor.
Posted on May 02, 2013
  • 205 Answers
SOURCE: Troy Bilt ride-on mower will not move in either fwd or reverse
Is the parking brake on? Or if it's a hydrostatic (automatic) there is a release lever to push the unit around when it isn't running. Most of those releases are on the back of the machine, and you just push it in for drive and pull it out to push.
Was this helpful?
yes
no
Posted on Mar 21, 2009
  • 376 Answers
SOURCE: MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Posted on Jun 28, 2009
woobie dog
  • 1273 Answers
SOURCE: my belt wnat stay on my 42 inch cut troy bilt
Usually, it's because the belt's worn out. Over a period of time, they stretch and wear against the pullys. I recently replaced one after it came off several times. Try as I might, I couldn't see anything wrong with the belt. I changed it anyway, and it's run fine ever since!!
Good luck! --W/D--
Posted on Jul 17, 2009
bbreton
  • 437 Answers
SOURCE: wont free roll
On some tillers you have to pull the pin that holds the wheel on, move the wheel in and reinstall the pin to get them to freewheel. You may have to use some penetrating oil like i.e. PB blaster or DeepCreep to get the wheel to move on the shaft. Be patience there may be plenty of rust to break the hold. But when you get them free, clean up the shaft and wheels and put some grease on them. This will make it move more freely next time.
Posted on Dec 19, 2009
Testimonial: "that got it. thanks"
  • 18 Answers
SOURCE: troy built riding mower runs at low speed and
Probably an engine problem.
Does it run at max rpm with mower deck disengaged?
Posted on Apr 18, 2010
Troy-bilt bronco riding mower hydrostat drive will not move mower
be sure the drive rod is engaged on the back of the mower. pulled out should be free move and in should be the drive position. if it is in check the belts are in good shape and not off of a pulley.
Feb 05, 2017 | Troy-Bilt Garden
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Need diagram of deck for 2006 super bronco model 6605
I DON'T HAVE IT ON HAND, BUT YOU CAN TYPE IN ON GOOGLE SEARCH "YOUR MODEL # DECK BELT DIAGRAM" TO FIND IT, BUT TO DO IT YOURSELF, JUST REMEMBER THAT BLADES MUST TURN COUNTERCLOCKWISE AND THAT GROOVED PULLEYS MUST FACE THE INSIDE OF BELT AND FLAT PULLEYS THE OUTSIDE OF FACE OF BELT, ALSO REMEMBER THAT SOME MODELS HAVE JUST ONE BELT (DRIVE AND DECK BELT) OR TWO BELTS (DRIVE BELT AND DECK BELT)
Jul 08, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Troy bilt lawn mower
sounds like wrong belt you raise it belts tighter lower belts looser or the tensioner has come loose
Jul 13, 2013 | Garden
Troy-Bilt Horse XP, Model 13bx79kt011 - Won't Move
You need to check the belt to the hydro units is connected properly and is tentioned and not slipping in the pilleys
May 31, 2013 | Garden
I have Troy Hydrostatic 46" when I attempt to
If you lower the blade deck and get down near the mower, you can see the blades belt on top of the deck. If it is intact, with the engine off, have someone try to engage the blades. A tensioner should move into place to tighten the blades. If it is not, follow the engagement lever to under the dash to see if there is a cable broken or a rod detached.
Post back.
Gary
Sep 11, 2011 | Troy Bilt 22HP Hydrostatic 46" Riding...
Troy-bilt bronco riding lawn mower choke problem
Check your air cleaner...then check fuel line from pump. Pull fuel line off carb make sure fuel is present. :)
Sep 07, 2009 | Garden
Was this helpful?
yes
no
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
89 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
