Question about Dell Inspiron 9400 Notebook
Firewire Hi Fixya Expert, I stumbled over your site while looling for info about my Dell Inspiron 9400/E1705. As I can't get any help from Dell or related forums I thought I might try you. My question is as follows. Is there a way ofdisabeling the Ricoh firewire driver so that I can insert an expresscard with 6pin firewire ports directly into PCI-E bus and the system recognising the Texas Instruments drivers. If this is possible at all it should not have any negative influence on any other parts of the computer. The reason for my question is that I am involvered in music and recording and the defacto firewire chipset is aTI and the Richo is not built for audio interfaces. It would be nice to hear from you. Fedon
    Master:
  • 663 Answers
If you add an extension card then the onboard card would automatically stops working and the computer will give priority to the card. However, you have to make sure that the CARD is compatible with your motherboard. There are times when extension cards have conflicts with other hardware parts.
What's the build of your computer? What the specs of the card?
Please provide me with more information when you get back to me.
David
Posted on May 01, 2013
ginko
  • 19396 Answers
SOURCE: dell 1525 inspiron driver
Here is general download page for your laptop, from Dell.
Here also few direct links:
Dell 1525 XP audio driver.
Dell 1525 XP modem driver.
Intel chipset
Ricoh chipset system driver.
Posted on Mar 16, 2009
clark_styx
  • 282 Answers
SOURCE: DRIVERS FOR DELL XPS M1210
you need the ricoh chipset drivers
Posted on Aug 03, 2008
  • 998 Answers
SOURCE: Dell Inspiron 710m PC Notebook Problem
Go to "Device Manager" and look if any yellow or red alerts are being displayed next to any devices. To access the "Device Manager" go to the 'Control Panel", "Administrative Tools", "Computer Management" and select "Device Manager" located in the left side column.
If there is an alert, double click on that device to determine the problem, i.e.… device not configured, cannot start this device, etc…
It sounds like all your software drivers got blown away or can’t load. If that’s the case, try running diagnostics. Press and hold the <Fn> key while powering the system on. This will initiate a diagnostic routine to check your hardware.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Oct 31, 2008
  • 3 Answers
SOURCE: No wireless connection because of problems with my Base System Driver and SM Bus Controllers
depending on your ISP, this may be a common problem. I have Verizon DSL and wireless is included on the modem. I recently expirenced a similar problem and i hardwired my laptop to my modem (you can do this with your router as well) via ethernet cable and this worked for me. once you get internet this way, unplug the cable and you should be connected wirelessly
Posted on Nov 11, 2008
pontelemon
  • 538 Answers
SOURCE: laptop dell inspiron 1525 sound only when headphones connected
If you can here sound in headphones, but not through the speakers, most likely the phone jack switch is bad. The whole jack needs replacement.
Also, in some cases, it could be more then that, like Audio CODEC chip on motherboard is bad, but lets assume the best.
Posted on Apr 19, 2009
Charging light is flashing
There are two possible causes for this issue:
1) Your dell 9400 charger is malfunction
2) Your laptop dc power jack is loose or dead
Possible troubleshooting step:
1) Borrow a compatible dell charger to plug in your laptop, if it works without any issue, it means your dell inspiron 9400 adapter need to be replaced.
2) If the compatible dell 9400 charger won't work normally, the problem may lie in your dc power jack.
Hope this will help.
Jan 07, 2013 | Dell Inspiron 9400 Notebook
No sound speakers and headphone dell inspiron 9400
First, check that the audio is not muted, either via any hardware switch/button, or via software.
If not, I'd download and reinstall the sound card drivers for your notebook here:
http://www.dell.com/support/drivers/us/en/19/DriversHome/NeedProductSelection
you will need to select your model, or put in your service tag (on the bottom of your notebook) and then look for the driver under audio in the list.
from memory the first audio file should be the one you are after.
click on download, on the right hand side.
once downloaded, run and install software, then restart the computer.
Hope this info helps.
May 21, 2012 | Dell Inspiron 9400 Notebook
Bios Password dell inspiron 9400
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-9400-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
May 14, 2010 | Dell Inspiron 9400 Notebook
Can't activate wifi key on inspiron 9400. fn f2
Try to uninstall then re-install the Dell Quickset from the Drivers and utilities disc.
Oct 29, 2009 | Dell Inspiron 9400 Notebook
Cd jammed on top of cd drive of dell inspiron 9400 notebook
One screw on the bottom holding drive. Take it out, and pull drive.
Mar 27, 2009 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 display
you may have damaged the screen in which case theres not much more you can do then replace it.if its a new labtop it may be still under warrenty in which case get back to dell.
Mar 22, 2009 | Dell Inspiron 9400 Notebook
How do I add a dell external monitor to a dell inspiron 9400
Simply use the external video port. It may require an adapter depending on the monitor you plan to use.
Nov 18, 2008 | Dell Inspiron 9400 Notebook
Dell 9400 battery problem
Hi bockobulb,
There's a good chance if the casing got damaged that the connector that connects the battery pack to the system was also damaged. First I'd suggest trying another compatible battery pack if you can get your hands on one. Bear in mind that there can be damage to the connector even if it's not visible.
Ben
Mar 05, 2008 | Dell Inspiron 9400 Notebook
Unable to adjust the brightness of display screen
bright ness buttons are indicted witha sun like mark . they r usaly used with fn keys look for that keys
Dec 22, 2007 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 Notebook Logo
Alun Cox
