Question about Vehicle Parts & Accessories
1996 mustang 3.8
1996 ford mustang 3.8 won't idle
  • 25 Answers
Ok, need details. Is it turning over, has the timing, plugs, belt etc.etc. been checked, replaced, are correct.
Saying it wont idle with out details is really useless. I would fist ask you if there is gas in it. Maybe that is why. More details you provide the more we can help
Posted on Apr 30, 2013
  • jesea davis May 01, 2013
    Plugs, belt and gas are fine. It will turn over and start with out giving it any gas. It runs for about 5 seconds than dies. You can drive it if you go from neutral to drive and keep throttle on, other wise it dies.
    Took off egr valve to clean and I'm getting ready to replace iac valve, not sure if its bad though, it's not cheap, I don't want to replace it if I don't have to.
My 1995 Mustang GT won't run right!
Your problem is it is a ford,LOL:
Nov 03, 2012 | 1995 Ford Mustang GT
2001 ford mustang passenger window won't go operate from driverside
If it works with the passenger side switch but not the drivers switch, I would look at the drivers switch for the problem.
Jul 18, 2012 | 2001 Ford Mustang
My 1993 Ford Mustang convertible won't go up.But the motor is coming on.Also it will go down thou
There must be a hydraulic fluid leak somewhere. Check to see if there is oil filler cap on your hydraulic pump located in the trunk compartment. Fill if necessary with just enough fluid to raise the top. The reason it won't go up is cause it is lacking pressure from the low fluid
Jun 26, 2012 | 1993 Ford Mustang
96 cobra everything comes on but wont turn over
Hello! When you say; "Won't turn over"; You mean the starter will not crank the engine...Correct? Is the Check Engine Light on?
Oct 11, 2011 | 1996 Ford Mustang
I have a 1996 Ford Mustang GT 4.6. My car would start then turn off as soon as the theft light starting flashing, I tried disconnecting the battery, turning the key in both the passenger and driver doors,...
On the older fords the theft module has 2 plugs in them. You can disconnct one of them, I believe it is the right one , and disable the security system. Finding the module is the hard part. most are located in the middle of the dash.
May 20, 2011 | 1996 Ford Mustang
My 96 Mustang GT engine will idle fine in park or
it sounds like either the torque converter solenoid is stuck or the torque converter itself is bad
Sep 10, 2009 | 1996 Ford Mustang
1996 mustang with 4.6 is idling up and down but won't stall.
sounds like a vacume leak in the intake that will make the idle go up and down
Sep 07, 2009 | 1996 Ford Mustang
1996 Mustang radiator fan constant running
Disconnect pos. battery cable for 3-5 minutes, then reconnect that should do it!!!!!!!!!!!!!
Jul 26, 2008 | 1996 Ford Mustang
Vehicle Parts & Accessories Logo
80 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
