Question about Adobe Photoshop CS6 Extended 65170137
ENTRY POINT NOT FOUND - Adobe Photoshop CS6 Extended 65170137
Kernell32.dll error on photoshop cs6
hi,
i downloaded Photoshop cs6 trial and when i click the Photoshop icon to open the software i get a window:
Photoshop.exe - Entry Point Not found
The procedure entry point GetLogicalProcessorInformation could not be located in the dynamic link library KERENEL.32.dll.
What can I do???
I have allready tried to reinstall....
still the same.....
HELP
Dec 16, 2012 | Adobe Photoshop CS6 Extended 65170137
CoD2SP_s.exe entry point not found
the procedure entry point _AIL-3D-provider_attribute@12 could not be located in the dynamic link library mss.32dll.
Mar 03, 2012 | Activision Call of Duty 2 for Windows
Error message: procedure entry point PowerReadACValue could not
tvagente.exe is used to use computer as a TV. If you do not use it, you may want disable it. It uses excessive system and memory resources If you are not using the TV application, you should remove it to improve your overall system's performance. anyway try in run-msconfig-startup the entry for tvagent.exe and disable
Mar 06, 2010 | HP Pavilion dv9000z Notebook
Receiving error message: WlanMon.exe - Entry
Try a reinstall of the software sounds like that wlanapi.dll isn't being "Registered" If installing on Vista or Win 7 use Admin mode and try Compatabilty Mode for XP SP2.
Feb 03, 2010 | Blitzz Technology (BWA611) Router
TVAgent.exe entry point not found always pops out. It says: "The procedure entry point PowerReadACValue could not be located the dynamic link library POWRPROF.dlll how do i fix this. please
Hey,
I have the same problem as you and im in the process of fixing it
I researched it and found this...
http://support.microsoft.com/kb/929135 (Note this is for Vista only)
Use the instructions on how to clean boot your Windows and it should work...
Dec 13, 2009 | HP Pavilion dv9000z Notebook
try to re-install windows installation cd/dvd and all drivers that came with computer....this should automatically re-install the correct entry point processes into laptop.....make sure you back up all of your settings and documents,pics etc on dvd/cd first incase windows automatically formats over them...
Nov 19, 2009 | HP Pavilion dv9000z Notebook
Microsoft Windows message: SOUNDMAN.EXE - Entry Point Not Found
install service pack 3 if that doesnt work then reinstall the OS in repair mode.
Jan 02, 2009 | Microsoft Windows XP Professional With...
Adobe Photoshop CS6 Extended 65170137 Logo
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
