Question about Konica Minolta Bizhub c203 Copier
Service programming i can't scan to my pc anymore and i don't know how to fix it.
  • Konica Minolta Master
  • 1,294 Answers
Instal a Konica Minolta Bizhub universal driver ,print a machine configuration page and type in PC the ip adress config.
Posted on May 01, 2013
My dell laptop is very slow, I can't watch a full movies on it cos it keeps breaking out. Could anybody help me solve this problem
I would start by downloading free CCLEANER at :http://www.filehippo.com/download_ccleaner/ Install and run. The scan will clean the junk from your system. Also there is a section TOOLS , STARTUP, to disable programs from starting at windows boot. ANOTHER program MALWAREBYTES FREE at :http://www.filehippo.com/download_malwarebytes_anti_malware/ Run A FULL SCAN delete ALL results. I don't no the model of you DELL so I don't know the specs. But you want to disable ALL programs not needed . In Services you can disable Windows Search, a memory Hog. Only you can choose the programs that are not needed, I have no clue what is on you machine. Take a look at this for tips: http://www.pcmag.com/article2/0,2817,2364937,00.asp
Nov 19, 2012 | Computers & Internet
Tip
Increase the speed of computer
The speed of computers depend on several things.
In your case >>>>
1. Check the hard disk ... Go to My Computer >>> Right click on C: >>> Properties >>> Disk Cleanup (to remove useless files) ... Again from Properties >>> Tools >>> Check Now >>> Tick on ( Automatically fix file system errors & Scan for attempt recovery of bad sectors) >>> Start >>> The computer will schedule the scan to the next start up, so restart the computer ;) ..... After finishing the scan go again to C: >>> Properties >>> Tools >>> Defragment Now >>> a new window will appear , click on Defragment button ...
By the way make sure that the hard disk isn't full. If it's , try to move some personal files to another place such as D: or burn them on CDs , try to remove useless programs, Start >>> Control Panel >>> Add or Remove Programs ...
2. 256MB of ram is quiet slow reallly at least 1 GB would help your computer loads. You just need to stop some unnecessary programs working ( Be careful the following steps maybe harmful to your computer ( If try to change the setting ), so don't change the setting of the system)... Start >>> Run >>> Write ( msconfig ) >>> Ok >>> A new window will appear ( be careful here DON'T TRY TO CHANGE OR EDIT ANY SYSTEM OR BOOT FILES OR SETTINGS UNLESS YOU KNOW WHAT ARE YOU GOING TO DO) >>> Click on Startup ( This window shows the programs, which are running in the startup) >>> Remove ticks from the programs, WHICH YOU KNOW THEM, to stop them running in the startup ( this step is really useful to speed the computer up) ... By the way the computer will ask you (after restarting) about that change in the startup, just press ok and tick on (Don't ask me this question again).
3.Increasing the performance of the computer ... Right click on My Computer >>> Properties >>> Advance >>> ( Performance field) Setting >>> Here you can increase the performance by choosing (Adjust for best performance) and you can leave some visual effects if you like ( this step isn't harmful,but don't go to Advanced if you haven't experienced it)...
By the way, sometimes, having two virus protection together makes the computer works like a turtle :)
You should Only have and only need ONE virus protection installed on your PC.
You can click start-----click run-----type msconfig------click startup tabs,then you can uncheck programes that dont need to run at startup. Then click ok to exist..And you also can go visit http://www.make-pc-fast.com to download a speedup software.
on Sep 07, 2013 | Computers & Internet
I've got this laptop ACER ASPIRE 5742G it runs on windows 7 -- 5GB memory , 500 GB HHD ; intel core i5-460M ... some of my program run on Microsoft Windows XP Professional Version 2002 Service...
You don't want to download any program to run programs compatible for windows XP, you can find a built in program coming with windows 7, and it is very easy to do,
go to control panel and open troubleshoot, then select programs, click next, after scanning it will all the programs that installed on your laptop, then select any programs which has compatibility problem with windows 7,
then you can see one option to start that program with Windows XP compatibility mode, after opening that software, click on next, and save that settings,,,,
finished....
you can fix all problems,
I hope it will be useful for you, so don't forget to rate me if you are happy
Thank you
Sep 03, 2011 | Microsoft Windows XP Professional With...
I am trying to scan a page and it is telling me no scan options are available.
Hi
You don't say how you're trying to scan.
You can scan by pressing the Scan button on the printer control panel or by opening the HP Solution Center program and clicking on Scan.
If neither of these options work then connect and disconnect the printer cable and if necessary test a different cable.
If none of the above fix the problem, the printer control program is probably either corrupted or partially deleted, so uninstall the program and all its components in Add or Remove Programs and then reinstall the program using the Easy Install option.
Start > Control Panel > Add or Remove Programs (Uninstall a Program) > highlight - Remove.
If you don't have the driver and applications disc, you can download them from:
http://www8.hp.com/uk/en/support-drivers.html or your country specific www.hp.com HP site.
I hope this helps.
Aug 25, 2011 | HP OfficeJet J4580 All-In-One Laser...
I cant play sound
Improve the Fixya.com experience for everyone by voting!
Unfortunately, I would either have to be in the chat mode or on the telephone with you to fully analyze your problem and provide a coherent answer. But don't despair because there is a little FREE program that may solve your problem.
It happens periodically that our computer shuts down, restarts, hibernates or some other weird thing when we really don't want it to. I'm going to pass on to you a FREE and hard to believe program from Microsoft! I have no idea why this little program hasn't been advertised but then I don't own their stock.
Just click on the following link and your problem should be solved: Download Microsoft's Fixit
I don't know your skill level so my suggestion is that you utilize the automatic function of Fixit.
Be a hero and fix your friends' computers; just don't tell them how you did it! That will be our little secret.
All the best,
Ben
Jul 22, 2011 | HP 530 Notebook PC
My sun blade 150 boots but it stop its services after a while
All the best,
Ben
Jul 22, 2011 | Sun Blade 150 PC Desktop
Computer will lock up after its being rounning a few hours ? tryed defraging ,keep cookies down,run full scan , for viuris, using Avast ware..
All the best,
Ben
Jul 21, 2011 | eMachines EL1200 PC Desktop
My mobile memory card want to format. without format is cant open. but i want to save my photo. is this possible.
Not usually but have you tried if your PC can read the card, sometimes the phone can't and the PC can.
Other than that the only thing I can sugest is to try using your PC to scan and Fix the card to see if that will recover the file system.
Last resort I don't know if it is possible but maybe a file recovery program to find files on the card, get what you can off the card before you format maybe even run the program after the format also to see if you can recover even more if you do not get what you want off the card prior to the format.
Good Luck!!!
Jun 08, 2011 | Computers & Internet
My proxy is not functioning...i just want to know what are the programs or any software can fix it...can you help me please?
proxy... this is not a 'service/program' that end users can work with or fix. hell 80%+ of the globe don't even know what it is...
how do you know it's broken? or have you jumbled a word out of context here?
your Router (wifi point if you will); does not perform Proxy features; your internet provider might do... so if you genuinely do mean "Proxy"; then speak to your internet service provider on this issue.
May 02, 2011 | Computers & Internet
Anti spyware not scanning
I think you need to shutdown and restart the program.
Nov 26, 2008 | Zone Labs ZoneAlarm Anti Spyware Full...
Konica Minolta Bizhub c203 Copier Logo
52 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
