Question about HP Officejet 5510 All-In-One Thermal Printer
Black print is too light - HP Officejet 5510 All-In-One Thermal Printer
  • HP Master
  • 1,679 Answers
Hi Barry,
Remove all the cartridges, Clean the Golden ( electrical ) contacts with lint free cloth.
Reinstall the Cartridges and wait for the printer to align.
If the issue does not resolve,
Press the Setup ( home ) button front panel. Scroll till you find Tools - Press ok, Look for Clean Printhead/Cartridges - Press OK.
Wait for the process to complete and this should solve the issue.
Regards,
Sean
Posted on May 01, 2013
Prints blacks fine, not printing grayscale.
Hi:
The answer to your question is very simple. If your document has a greyscale area, it is a color document and needs a color printer to print.
Greyscale is not light black printing, it is color in layers to give the visual impression of light black or grey.
Greyscale printing is only printable in a color printer, and does not use any black ink in its reproduction.
Sorry.
Mar 16, 2015 | HP LaserJet 2430n Printer
Print is fully black
often when the exposure lamp burns out, all your copies will come out black. The light reflects off the immage to the drum to create the copy to be printed to the paper. If the light is out, all the drum will see is a black image to be printed. Make a copy with the cover open, and see if the light turns on.
Nov 04, 2014 | Canon IR2016J
I replaced the black ink and the error light is on and the out of black ink light is still on. Won't print
Try it.......
Remove the print head and soak it for three 5-minute cycles in hot (~170 F) distilled water about 3/4 inch deep with continuous mild agitation. The first soak quickly turn the water black, the second end with the water a dark grey color. The hot distilled water dissolved the dried ink in the small ink passages from the cartridges to the ink ejection part of the print head.
Carefully dry the print head as per instructions, clean the electrical contacts on the printer, and placed the print head and the ink cartridges in the printer.Turn off the printer, then unplugged it for one minute.Then turn it on...and print an alignment sheet...
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 20, 2012 | Dell 1320c Laser Printer
Canon i250, black text won't print, but ok with nozzle check
Canon i250. Instructions on this website solved the problem of flashing green and orange lights, but now the black won't print. Changed ink cartridges, but still no print. Did a diagnostic nozzle check, and the black DID print. What do I do now?
Oct 21, 2009 | Canon i250 InkJet Printer
Printer will not print black ink
Seems to be a common fault with Kodak EasyShare 5100/5300
Contact Kodak Support and go though the following tests:
Remove and re-seat Printer Cartridge(s) - Done
Clean Printhead - Done
Calibrate Printer - Test Sheet Not Complete!
Run Computer Colour Test - Done
They will then send you a new Print Head.
Mar 25, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
The printed pages with black is light and spotty.
Try to run the "Clean Print Heads" utility. Sometimes it is called something else, but whenever your print quality degrades, this is a good program to run. If that doesn't work, then I would suggest replacing the print cartridge. Sometimes they go bad if they have not been used for a long time. Hope this helps!
Mar 13, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Light purple cast to black and white prints
Known issue. Use QTR to print bw prints. Works great on my Epson 2200.
http://www.quadtonerip.com/html/QTRoverview.html
Dec 06, 2008 | Epson Stylus 2200 InkJet Photo Printer
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
Copies print all black
Make 1 copy with the lid open & verify that the scan lamp is lighting & that the scanner moves. A blown lamp is the most common cause for all black copies.
Jun 11, 2007 | Gestetner 5499 Black and White Copier
Scanner & black pages
The black printing usualy occurs when there is a faillure in the light, since your light is working fine, there may be a problem in the imaging device inside(camera) or the reflector. There is nothing wrong with the cartridge.
May 05, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP Officejet 5510 All-In-One Thermal Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
