Question about Suzuki 25Note Chromatic Tone Chime Set
Muted Sound I have a set of chimes that when you try to play them the rubber striker does not hit the bar and others that when they are struck they sound muted (like when you hold your hand against the chime)...Any help??
4 Suggested Answers
  • 5603 Answers
SOURCE: The clapper on the A#/Bb-6
Frankly, I would analyze what the clappers ar made of and MAKE them yourself. If they are plastic, find suitable material and make your own. If metal, you can have a metalshop make some for you.
Finding replacements either piecemeal or individual chimes is NOT likely to happen.
Posted on Aug 09, 2010
  • 5603 Answers
SOURCE: The head of my A6
You will have a near impossible task to find a replacement. Try at a music store that deals in student instruments. This is not high tech and the technology has not changed much so you might luck out.. DO NOT leave any part of your set with them... they tend to get lost.
If you can't get the part then your choice is to MAKE a suitable part. It is often not hard to come up with a substitute. If the metal of the chime has cracked, then have it welded and then tune it with a file...
Posted on Mar 09, 2011
  • 4 Answers
SOURCE: I am trying to replace
Suzuki does sell individual replacements, I bought a few last year. If there are a few unusable chimes now, you can try to tune them, nothing to lose, I was able to tune 8 of ours and 2 others were too far gone and had to be replaced. They tune like a tuning fork, which is what they are. If the chime is flat, you either file the tips, in effect making the legs shorter, this must be done evenly or sustain will be affected, or, the inside of the legs near the tips can be filed, again evenly, to reduce mass. If the chime is sharp, filing is done down in the "******" area.
Posted on Oct 06, 2011
Highest intensity in some keys even when I play it with slow push
DUST on sensors! If you have steady hand, you can remove the entire keyboard. Using a computer vacuum cleaner, clean the sensors on the instrument, then replace the keyboard carefully. Or, take it to a technician to have the keyboard sensors cleaned.
May 23, 2013 | Roland Music
I have the dm10 studio pro 2011 kit, and no matter how i store settings for priority, if the rim of tom 1 or 2 are struck at the same instant as the snare head, the snare does not sound. even if i set no...
Realize first that your "instant" is like eons to the electronics where billionths of a second count... This is an interesting set of symptoms. I would connect one of the other devices to one of the tom inputs and see if the snare acts the same using that devicee. Also try to characterize how much ahead or behind the snare hit the tom hit can occur and have both sound. This problem MAY be embedded in either the electronics or the firmware in the module. It could be an electrical noise issue or any of several other things. I want you to try this using ONLY headphones and NO amp... this is to isolate the possibility that the vibrations of the snare by the amp may be triggering anti-noise gate in the snare circuit. These are some more tests I want you to do the above and give me the results.
Sep 13, 2011 | Alesis DM10 (Module) High Definition Drum...
Hi, when I play a chord on my Casio-656 keyboard it sometimes sounds out of tune - if you hit the chord again it plays correctly. Is this a fault or a setting? It seems to be intermittent so that would...
I would check your fingering... You MAY be late in hitting a particular note and the using auto chord... this can cause the problem. Another thing is if notes are hit with different velocity that can affect the sound. Sometimes certain voices have VELOCITY switching which actually changes the voice depending on the velocity you hit a note.
May 19, 2011 | Casio Music
Got a "Dwell" effect when
It sounds like you have cable in the wrong ports. Make sure your cabling goes in to out on all ports. Also make sure no cable are bent or heavy equipment on top of it. If your getting sound but sounds like muted sound its either cable in the wrong place bad cable or amp setting is to low.
May 04, 2011 | TC Electronic Classic Sustain & Parametric...
The head of my A6 chime has split. I need a replacement part, but have no idea where to get one. This is a very old classroom set that was purchased years ago. I'm not surprised that the rubber is...
Mar 09, 2011 | Suzuki 25Note Chromatic Tone Chime Set
Hi there, I have a Nord Stage EX 76 and played a gig on friday night outdoors. I have set the keyboard up and now one or two of the notes occasionally sound much louder than they should. The problem...
What has happened is that one of the contacts on those notes is not working properly. Each key has two contacts. One makes before the other as the key is pressed. The processor MEASURES the time between those as you hit the key to read the VELOCITY you have hit the key with. This velocity is often used for loudness on many voices such as the piano. These contacts are USUALLY conductive rubber pills suspended in silicone rubber "domes". One can disassemble the key area and clean BOTH the black rubber pills and the circuit traces they are pressed against using Q Tips and ONLY 99% isoprophyl alcohol to restore proper operation
One needs to be very careful when disassembling unit as there are many tender ribbon cables and connectors. Best to have clear work area and two people to "control" the halves of the shell while opening..
Nov 07, 2010 | Clavia Nord Stage 88 - Digital Stage Piano...
In juno di faviourite button when i bush one after another there is sound gap in tones ie fraction of second gap
This is probably normal. The sound generators need to re-configure when changing voices. This means that while one set is generating the old voice, others have to be set to the new and the old cancelled. The sound has to be muted between the setting changes... this takes a fraction of a second to do in the hardware. The only solution is to use two synths and have each set to the sounds you want. MANY musicians rack up two synths just for this purpose.
Oct 15, 2010 | Roland Juno-D
One of the keys catches/stops about 1/2 way down. It can be pushed all the way down with effort. Sound occurs when it is pushed all the way down, but it is muted somewhat
Open the unit being careful of the cables between top and bottom of the unit.
The problem should be fairly obvious. The muted is because teh velocity sensing contacts are not making in the usual time so it acts like you are hitting the keys very slowly.
It will either be something jamming the key or a broken part OR the silicone rubber carrying the conductive pills has broken down.
Sep 26, 2010 | Casio Privia Keyboard Case
When striking 3 keys key nomber;11 b flat;13 c;15 d,the volume is very high in level with all others.is there any way i can repair or overcome this. this is in full keyboard mode thank you
Is it a dynamics sensing keyboard (does it sound soft when you play softly and loud when you hit the keys hard)?
If so, you need to clean the double contact under those keys that sound too loud (if contacts are dirty, the key might either not work at all or it may loose the ability to sense how hard you hit it and will work at full volume).
You'l probably need to disassemble the unit and remove the keyboard to be able to remove the keys that don't work well, after you've done so, you need to clean the lower (under) side of the double rubber button which is struck by the key when you hit it, also be sure to clean the contact tabs on the circuit board undereath the rubber pad (you can use ethyl or isopropyl alcohol and "cotton sticks").
This should do the trick if the contacts are dirty, but it may have no effect if they are damaged or worn out (in such case you would have to replace the rubber pad for that particular key).
regards
3rq8 (Triarcuate)
Jul 31, 2009 | Music
Suzuki 25Note Chromatic Tone Chime Set Logo
35 people viewed this question
Top Suzuki Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Suzuki Music Expert? Answer questions, earn points and help others
