Hard drive Compatabilaty
I'm looking to replace the fried hard drive in the computer. I noticed that there was different types of IDE hard drives. Would the following be be compatable- IDE Ultra ATA100 / ATA-6 3.5" Hard Drive ???
  • 3,799 Answers
That would depend on the motherboard. But, if you computer was made for windows XP then I would say that should be fine. To be sure, just put the part number of the old one into your search engine and it will tell you the drive interface you need. The ATA 100 is the most likely interface you need.
Posted on May 02, 2013
TIPS72
  • 369 Answers
SOURCE: Internal hard drive add-on question
CAN U PLEASE TELL ME THAT WHATS THE MOTHERBOARD MODEL IS IT DESKTOP OR LAPTOP IF DESKTOP U CAN USE SATA HARD DRIVE BY USING A SATA CONTROLLER CARD if just u have a pci slot empty if yes tell me so i tell u the model number t take a card and fix it your self...
thanks
Posted on Jun 03, 2008
tanderson365
SOURCE: Is Samsung sp0802n dma/ata-33(ultra) or ATA-133, what's different
can I buy yours and maybe your parts will work with mine, mine just wont spin
Posted on Apr 27, 2009
FixinFax
  • 3085 Answers
SOURCE: I use an ATA100 40GB hard drive. I wish to
Yes, 540GB.
Posted on Jan 17, 2010
Testimonial: "An explanation as to why would have been even better, but thanks anyway."
ragufiles
  • 105 Answers
SOURCE: is this IDE hard drive compatible?
Ya you can use..
Posted on Jun 01, 2010
  • 75 Answers
SOURCE: compatible hard drive to replace a Toshiba MK8025GAS 80 GB
You can buy hard disk for your model from following link at low price
http://www.laptoppartsexpert.com/c-47805-sony-vaio-vgn-vgn-s-series-vgn-s170p.html
Posted on Jul 21, 2010
I just bought a Dell DHS computer without a harddrive at a yard sale, how do I install a hard drive for it
First you have to make sure you bought the right kind of hard drive (IDE or SATA) to make the installation and connection easier. IDE drives have a set of prongs or pins that stick out. SATA is the later type and does not have prongs or pins sticking out. You just turn the laptop over and remove the cover where the hard drive will be housed. Usually it will have an icon of 3 circular discs on it. Most laptops will also require a Caddy that the drive sits in before it goes into the laptop. And some might require a interface.
I suggest you look on ebay and see if your computer's make and model requires a hard drive caddy or interface.
http://www.ebay.com
In the search box just type your computer's make and model followed by hard drive caddy. Example: Dell Latitude D610 Hard Drive Caddy
In the search box type this is see if it requires an interface: Example: Dell Latitude D610 Hard Drive Interface
May 20, 2012 | Computers & Internet
This Emachine will not boot from HD or CD. The screen only says Emachine.
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter check to make sure the first boot device is set to your hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
you can change it to cd if you want to install an operating system
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure the CPU central processing unit has thermal paste and dust free and is securely seated
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps
Apr 22, 2012 | eMachines T1440 PC Desktop
Can i install a different hard drive
You can install any hard dive brand as long as it IDE type, you might be able to install Sata hard drive if your computer mother board support that too!
Nov 15, 2011 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
How do I choose a hard drive?
It depends upon where the hard disk is to be installed, ie. in a desktop computer, in a laptop or in an USB hard drive case.
A 3 1/2 inch hard drives can be a IDE/PATA or a SATA type. Older computers use IDE/PATA hard drives and the maximum size you can install in a desktop depends upon the computer's BIOS.
SATA hard drives are generally used in later model computers and the size of the hard drive is not limited by the BIOS.
A 2 1/2 inch hard drives are used in laptops and are available in IDE/PATA and SATA types. The size and limitations of IDE/PATA hard drives also apply to laptops. The same applies to SATA hard drives.
The choice and size of hard drive depends upon your requirements and how much you want pay.
Don't forget to check BIOS for the maximum IDE/PATA hard drive size you can install in your computer.
Aug 22, 2011 | HP Computers & Internet
I need to open my computer to replace the hard drive. I need directions - or a visual. Please help!
the hard drive will connect to the motherboard it might be a flat ribbon type IDE or a 8 slat copper type which is usually a bit thicker also have different power connectors which will connect next to the IDE SATA connections
http://www.helpwithpcs.com/upgrading/install-hard-drive.htm#what-you-need
hope this helps
Apr 16, 2011 | Computers & Internet
I took out my hard drive in my Compaq Presario V2000 laptop...and I'm not sure what type it is..like an IDE, SATA...and whether it needs a 2.5 or a 3.5
Hi
Normally a laptop computer using the hard disk type 2.5 "
Here I attach the hard drive example for your reference.
Pic 1> 2.5" IDE HDD
Pic 2> 2.5" SATA HDD
Tq and regards
Mar 21, 2011 | HP Compaq Presario V2000 Notebook
My samsung 40 gb hdd not detectin inany computer after new installation
Is your hard drive a SATA (Serial ATA, a thin cable) or IDE (a fat, usually gray cable)?
If your hard drive is a SATA, be sure that the both the power and data cables are securely connected to the hard drive (and data to the motherboard). Then go into your BIOS and make sure your hard drive is seen by the motherboard. It should read a model number similar to that of the model indicated on the hard drive label.
If your hard drive is an IDE, make sure you've selected the CS (cable select) mode on the hard drive using the correct jumper setting. It should be displayed on the label using a small diagram. If it isn't, you can use the Samsung HDD Jumper Settings page to check the settings. Also be sure the cables are secured, as IDE cables can be difficult to fully connect. If this is the case, try using just the hard drive on its own without any other IDE/SATA devices connected, and see if your motherboard detects it.
Try different cables for either type to make sure it's not just the cables that are causing the issue.
If all the above have been tried and your computer still cannot see the hard drive, you may have a faulty hard drive, motherboard or power supply. Try using your hard drive in a different computer, if it still fails to be recognized, you'll need to replace your drive. If it is recognized, your motherboard or power supply may be at fault. Try a different power supply. If that doesn't work your motherboard may be the issue.
Best of luck.
Mar 21, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Hard drive adaptor
Your laptop HDD uses a newer connection type called SATA. The one you are used to using is called IDE. They do make adapters to go from one to the other but they are hard to find and not very reliable (sometimes just dont work).
You can find a 2.5" (laptop size) hard drive enclosure for SATA to USB at almost any electronics store.
Double check your motherboard (on your desktop if thats what you are using to read the drive) for SATA connectors on it. Many computers have been using SATA almost as a standard since about 2004-2005, but some may not still have it.
The reason for the new type of connection is faster data transfer speeds.
To look at the differences, click the link below:
http://jekkilekki.files.wordpress.com/2009/06/sata-ide-laptop-hard-drive.jpg
Oct 16, 2009 | Toshiba Satellite P105-S6104 Notebook
I need a new hard drive for my Sony VGN-FS742 and need help...
Well, according to http://www.clearanceclub.com/depot/quelle_showroom.cgi?sku=4768 your laptop has a 80GB Enhanced IDE drive, so you'd be looking for any 2.5' IDE laptop drive.
Any computer store will be able to sell you one.
That said, you mention your hard drive is fried, but you also say you want to take the old media files off it? Well, if the hard drive is fried, there is nothing coming off it because..well.. its fried.
But if the drive works you dont need a new one. But sounds like you do need to format and reinstall the Operating System.
Mar 03, 2009 | Sony VAIO VGN-FS742/W Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
