Question about Refrigerators
Gsh22jsxa ss I smell freon inside the fridge. What is the most likely source of leak?
5 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: Not keeping cold temperature and can smell plastic from heat
Sounds like the condenser fan motor is either jammed or has failed. if you wil pull the refrig from the wall and remove the lower compartment cover you will see the fan I'm reffering to as well as the condenser coil and compressor. if the fan has failed you can put a house fan blowing into this compartment to keep the unit operational until you can get it repaired. thanks for using FixYa Peyton
Posted on Feb 20, 2009
Sea Breeze
  • 4654 Answers
SOURCE: leak gathering under produce drawers inside kenmore fridge
I can send you a video of that problem if you like. It's a Youtube video.
seabreezehvac@yahoo.com
Posted on Feb 28, 2009
arikrom
  • 528 Answers
SOURCE: whirlpool fridge leaks water in the back inside
your freezer cabinet need to get all out and open the back wall
there is a drain hole in the bottom middle of it make sure it is
clean and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday .com
Posted on Jan 03, 2010
carriedobbin
  • 18 Answers
SOURCE: freon leak in refrigerator?
no refrigerant leaks have little to no odor and if it was leaking bad enough to smell it the unit would be out of refrigerant and not cooling...the problem sounds like gases coming off of a veggie of something un-covered inside the fridge--have you put any veggies in the fridge or freezer un-covered check real good if one or a piece of something has fallen behind something else where you cannot see...all else fails remove all your products from the unit and clean and get a box of odor control arm&hammer to rid the smell..as for a leak in the sealed system i think your just fine.
Posted on Mar 27, 2012
What does a freon leak smell like in a refrigerator. Mine smells like very rotten oranges and its clean
Thats Not Freon! roll fridge out, take back lower cover (condenser compartment), and see what is going on there. Maybe some mice lives there.
Jun 06, 2015 | Kenmore Refrigerators
What gases are omitted from a fridge?
gases used in refrigerators are freon which is odorless . Smell could be bacteria build up in AC system
Oct 01, 2014 | Refrigerators
Freon leak in refrigerator?
Mar 27, 2012 | Samsung RF265AA Bottom Freezer French Door...
My travel trailer refridgerator got a freon smell in it...what can I do about this
Freon smell?
To remove the smell from a fridge - crumple up news paper and put it inside.
May 27, 2011 | Refrigerators
My refridgerator smells like fermented oranges. the smell is now in the water from the fridge and tastes like the bad smell. fridge is a side by side maybe 5 years old, don't know the brand right now....
This may be from the dirt that has accumulated on its drain or inner panels. Clean out the unit. In that way you can inspect the insides. Clean out every corner and drains. Make sure you check the coils at the back of the fridge. You will have to unscrew the panels inside to get to it. Check if there are balls of ice forming on the coils. There may be a leak, and the smell may also be from the freon.
May 10, 2011 | Refrigerators
Odor can it be freon leak?
Two possible causes of odor on fridges:
* Freon Leak
* Defrost Drain Pan dirty.
If the fridge was unplugged for a while or there was a liquid dropped in the refrigerator, it's more likely to be the drain pan. It is located at the back of the appliance, above the compressor.
If it is clean and the smell is not coming from there, then you may suspect about the freon leak.
Nov 06, 2009 | Sub-Zero 661/F Side by Side Refrigerator
Refrigerator
you will initially have a rotten egg kind of smell aroundthe refrigerator.
Dec 14, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Chemical odor
Hi serena38,
I'm Harvey the Master Plumber.
Your question is: You have a sweet chemical odor in our boat cabin, it leaves a sweet taste in your mouth. You cannot find the source. The fridge does not work. You can smell the odor stronger when the A/C is turned on or when the boat is closed up with the A/C off. Help????
Great, I live on a boat! I can think of two reasons for this. The first and most likly is electrical. Look carefully at the components especially the capaciter, it's on or near the motor. If it is leaking or out gassing, replace it. Wire corrosion can cause a wire to slowly give off fumes. These kinds of problems are common on a boat so look very carefully i.e. testing meter is helpfull here. I've already expirienced this and it sure was hard to find. Less likely is a freon leak. You won't smell the freon itself but if the oil is a little burnt, that can be smelly indeed. You will need a special leak detector for that. Anyway my money is on the electrical.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Kenmore 53642 / 53644 Side by Side...
There is a smell coming from the back of the fridge freezer,its a funny smell,sometimes you can smell it inside the fridge too, it seems to get stronger when the fridge is cooling more(as its a frost free...
I presume you have a house hold fridge if so you could be smelling a freon leak. It is a repulsive smell and you would notice it more during the cooling cycle. Is there any oily film inside or on the back of the fridge if so that is another sign. If you have a Recreational Vehicle it will smell more like ammonia and have yellow residue
Aug 11, 2008 | Refrigerators
Smell
Our refrigerator had a strong smell and it was freon leaking into the frig.
Jan 27, 2008 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
