Question about Roland Mc-909 Sampling Groove Box System
Roland mc 909
The keys don't work what should I do
2 Suggested Answers
SOURCE: headphone jack output
The same problem here. I solved it like this:
You must open the device. There will be a PCB with outputs and inputs. You must must detach it by removing screws on outside and then disassemble the PCB from two plastic pins to get the PCB rotated (I used plice to detache it one by one) and the conections of jack socket visible. In my case one od the lanes to the hot pin was broken. I checked that with Ohm meter 'cause it wasn't clearly visible with an eye. So having the PCB more or less secured I started to clean the lane a little bit to have a chance to put the solder layer near the pin and breakage. Get some really precise soldering device. It's a precise job. Do not overheat the diode which the lanes goes to. After placing some of the solder I checked the new connection by placing a jack into the socket and Ohm meter once again. All was perfect and working after assembling. Piece of cake.
ZIBI
Posted on Aug 22, 2008
Where can I go to get my Roland mc 909 check out
Contact Roland in whatever country you're in for the service centers in your area. For instance in the USA check this link-
Roland Support Service Repair Service Center Locator
Apr 18, 2016 | Roland Music
How can I get all my velocity pads to work?
After a lot of use chances are the sweat and oil from your fingers has gotten under the button contacts, when that happens the contacts cannot complete the circuit and you have to keep pushing and moving them around trying to make a connection. You need to open the unit and clean all the contacts under the buttons on the circuit board, as well as the bottom of each button. Some rubbing alcohol on a Q-tip works well.
Mar 22, 2015 | Roland Mc-909 Sampling Groove Box System
None of the buttons on the device will work. Batteries are fine and blinking light inside appears normal. Cannont lock the device from outside or get the code to unlock the door.
Check to be sure the keypad is still connected to the inside assembly. There is only a one year warranty on the electronics and Kwikset will not sell the electronic parts separately. If you want to replace it, there are other brands that are key-compatible with Kwikset. You'll still have the same problem if the electronics breaks though. The main difference is that other brands don't move the bolt with battery power, they just enable it to be moved by hand.
Aug 06, 2011 | Kwikset 909 909-L03 Lifetime Polished...
Mc909 work station problems
problems with automatic volume sometimes is cause by leaky/corroded pushbuttons.the other impending defect of the circuit itself.i suggest you bring or have a tech check your unit just to be in the safe side.
May 28, 2009 | Roland Mc-909 Sampling Groove Box System
Compaq Presario Vista Line In Recording Distortion
I was having similiar issues with my Vista system, upgrading the audio driver resolved the issue for me.
Feb 03, 2009 | Compaq Presario Notebook
2nd hand roland mc 505 display panel needs replacing
Hi.
Right Key Repair MC-505 LCD Replacement Modules are exactly what you are looking for!
Visit www.rightkeyrepair.com/MC505.html and and read on how easy it is to replace your LCD display with no soldering required!
Jan 27, 2009 | Audio Players & Recorders
16 step pads at the bottom are sticking or inoperable
yeah call roland support and order the pads... i just fixed mine... the pads are 12.00 each 1-8 and 9-16
Dec 13, 2008 | Roland Mc-909 Sampling Groove Box System
Headphone jack output
ZIBI
Jul 16, 2008 | Roland Mc-909 Sampling Groove Box System
Roland Mc-909 Sampling Groove Box System Logo
35 people viewed this question
Top Roland Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Joseph Mueller
Joseph Mueller
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
