Question about General Electric GE Profile CounterTop Microwave - Model Number: PSHF6VGXBB Side by Side Commercial Refrigerator
The ice dispenser works but the water dispenser does not
I think that the freezer may have been too cold so I have put it up to a three in case the water line to the dispenser is frozen. There are no leaks in the rear of the refrigerator and the lines look clear. I am thinking that the door mechanism is broken? Although there is no green light going on just red when I push to reset. Help! Rachael
  • General Master
  • 4,654 Answers
The ice dispenser works but the water dispenser do - 6404d9bc-b69f-4578-bd32-49c46ecf9312.jpgHaving a water line freeze in the door is possible but the most likely reason for not getting the dispenser to work is a defective=> WR57X10070 Water Inlet Valve on the dispenser side of the water inlet valve. I would like you to watch the video and if you have questions let me know Thanks Sea Breeze
Posted on May 02, 2013
  • 219 Answers
SOURCE: I recently replaced an old water filter from my
u either have a bad valve or your line is frozen to your dispensor
Posted on Mar 19, 2009
SOURCE: I purchased a new GE bottom freezer refrigerator
If the panel temperature reads 0 F 0 F it is in the "DEMO" mode. This is normal if you purchase a floor model. To bring it back to normal mode press ENERGY SAVER & ADJUST FREEZER together for 3 to 5 seconds until it beeps. Then unplug the referidgerator for at least 30 seconds. Then plug it bck in. That will reset the stupid computer and get it back to normal operation.
Posted on Apr 24, 2009
  • 135 Answers
SOURCE: GE Refriderator model GSL25KGRB RB water dispenser no water.
Water line may be frozen right where it enters the ice maker. Or the water valve may not be working.
Posted on Aug 26, 2009
SOURCE: The ice maker makes ice
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Posted on Dec 01, 2011
  • 230 Answers
SOURCE: Water dispensing into ice maker won't shut off
There should be a float or electronic water level sensor that will tell the water to shut off, if it has calcium from the water on it or the float is damaged it will keep sending water until manually shut off(pull the plug). I would look for a water level sensor of some sort and clean or replace it. If that doesn't work it could be a sticking water fill solonoid which you should then replace
Posted on Sep 06, 2012
Ice cube dispenser not working
Hi there, did you find the answer to this problem? We have exactly the same issue. We noticed a burnt smell in the freezer, mainly transferring to our hands when we touched packaging. The ice dispenser was working fine but the ice started to taste funny (a bit like burnt plastic) and had black bits in it. We took it out to clean the tray and since putting it back in, it just won't work. We don't know if we have put it back in wrong or if something has blown. We can still hear the motor when we try to press for ice, but nothing comes out. No water is making its way into the ice cube tray to form the ice, but we still have cold running water. I would be so grateful for any help. Thanks
Mar 16, 2014 | Ovens
The ice maker works but the water dispenser does not dispense water.
I had the same issue. I added a heater element (available on Amazon), replaced the flapper valve and the solenoid to ope the flapper valve. My opinion (not technically validated) was that the flapper valve (for the ice dispenser) was not sealing well so the ice chute was freezing (creating a lot of ice) and this the water tuning was also freezing.
Jan 19, 2014 | Refrigerators
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser won't work --ice dispenser is fine but no water comes of the water dispenser.
fridge set too cold ? frozen tank or water lines in fridge. set ref warmer for a couple of days
Aug 26, 2009 | Amana AFB2534DE Bottom Freezer French Door...
Ice Maker Not Making Ice
pls check the thermostat
Jul 23, 2009 | Refrigerators
Kenmore side by side fridge not freezing after pwr went out for few hours
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Hotpoint HSS25GFP Side by Side...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
General Electric GE Profile CounterTop Microwave - Model Number: PSHF6VGXBB Side by Side Commercial Refrigerator Logo
Top General Refrigerators Experts
John Tripp
John Tripp
Shehu Pro
Shehu Pro
Joseph Mueller
Joseph Mueller
Are you a General Refrigerator Expert? Answer questions, earn points and help others
