RCGA-36A2G I NEED A FILTER PART NUMBER
I have a sear air compressor #919-165030 I need to replace the muffler on it
The air compressor you have does not have a muffler on so I'm assuming you're talking about the air filter. You can buy any craftsman parts from www.SearsPartsDirect.com or go to a site like www.ereplacementparts.com and get an air filter for it. Both sites also let you search on your model number to see the breakdown of your compressor so you can see what parts you need. The air filter element is part number D24233 and the air filter kit which includes the filter retainer is part number D24235.
Mar 26, 2012 | Craftsman Air Tools & Compressors
I don't have a problem with my product...im trying to find out how many watts do my product use. Model #uamb-036jaz serial #6263f040410617
Brand: RUUD Manufacturer: RHEEM Model Number: UAMB-036J* Condenser Type: air-cooled Condenser Coil Model Number: RCGA-36A2 System Configuration: split-system air conditioner Cooling Capacity: 34,200 BTUHs per hour Efficiency: 12 SEER
10.5 EER Electrical Service: Single-phase Electrical Input: 3,272 watts per hour Voltage: 230 and 208
Jul 01, 2011 | Ruud UAMB Air Conditioner
I have a ruud rcha 36a2g heat pump from 2004. What is the seer rating and tonnage of it? Also inscribed uhbc-17jo6nfh
The unit is a 3 ton or around 36,000 BTU
It also is around a 10 SEER could be a abit more depending on the maych up of the coil and airhandler or furnace combination...
Heatman101
Apr 15, 2010 | Ruud Matching Split Air Conditioner
Not heating. The fan blows, but no warm air. RHEEM RCGA-60A1AS24
Please check if the compressor is running, if not, then
there is no warm air generated. Please contact the RHEEM dealer about it. Aircon compressors are run
with a thermostat. So, you may try setting the aircon
thermostat to maximum, so that the compressor run,
and you can have your warm air. May this info help you.
Jan 10, 2010 | Heating & Cooling
I need the air filter number on a compressor porter cable 80gl 175psi the model number is c7550
The Filter number you are asking for is A03157. The can be purchased at most local tool or compressor repair shops for around forty dollars. If none of the local shops are able to help you might try tryping the filter number as a search online. Hope this helps.
Sep 23, 2009 | Air Tools & Compressors
I am trying to determine the specs on my Rheem Criterion II lx2000 heating/AC unit unit installed in Sept 99, I blieve it was manufactured 2/5/99 based on AC Pump serial number 6263F259928697 Model RAMB...
rheems site is secure for dealers only but i can tell you. its a 3 ton unit 12 SEER R22 unit. The coil (rcga) is a 3 ton coil The AC is a 1999 and coil 1998. the # you have for the heater is accually just the honeywell gas valve. the model for the heater would be on the inside wall near the gas valve.
Sep 19, 2009 | Heating & Cooling
My unit is 9 years old Ruud RCGA-60AIGH24B seems
It's possible that there is gas leak causing part of the coil to freeze. The cost will depend where the leak is.
Jul 12, 2009 | Heating & Cooling
I purchased a new filter (Model LT600) Part #(5231JA2006B) for my LG refrigerator I installed the new filter and I am unable to set the filter/month button. After installing the new filter the number (1)...
Usually you just need to hold in a reset buttom (or a button near the dispensor for over 5 seconds to reset. The owners manual will tell you (I do not have one). or- Try any buttons you can find.
Apr 21, 2008 | Refrigerators
Ruud uamc-048jaz
What do you need to know? That is a 4 ton 12 seer straight cool system, with 11 kw heat strip. You may go to ari.org to search perfomance data.
Dec 03, 2007 | Ruud Central System Air Conditioner
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
