Question about AIMS Electronics - Others
Aims Inverter Trouble
Just got this inverter brand new. When the battery cables are connected to it (with the inverter switched off) the fans begin running and don't stop. When I called tech support they said upon initial installation that the fans run sometimes ten to fifteen minutes. I let it go like that for at least 30 minutes and the fans never stopped (all the while the inverter never being switched on.) Tech support said this is definately wrong and should be sent back. I'm just reluctant because I'm afraid it's something simple I'm doing wrong. The instruction manual is overly vague. And input would be greatly appreciated.
  • 3 Answers
SOURCE: aims 5000 watt inverter troubleshooting
The amp meter on this unit measures the battery current. So if you have an 8 amp load at 120 vac you will draw more than 80 amps at 12 volts and 40 amps at 24 volts. While this may not explain the 180 amps that you are seeing -- it's possible that the dryer is drawing more than 8 amps.
Posted on Jan 11, 2009
  • 9 Answers
SOURCE: roof top rv air conditioner installation
Waeco manufacture a rooftop A/C with a matching will need to ensure that you have enough battery power when staionary but your al;ternator will provide power when mobile you could also use a small generator through a battery charger to keep your batteriesd charged up but this is not neccessary unless you are stopped for a long period of time.these units are fairly easy to install and come with fitting instructions for the A/C and wiring kits for the inverter..hope this helps
Posted on Jan 14, 2009
  • 21 Answers
SOURCE: Aims Inverter PWRINV5000W Installation Manual
Here you go- contact info for Aims. They can provide you with a manual. Good luck....gary
AIMS Power Contact Information:
9736 S. Virginia St. STE A
Reno, NV 89521
Tel: (775) 359-6703
Fax: (775) 359-6753
Posted on Mar 14, 2009
SOURCE: fan switch not work - Viking 3048SS brand new range hood
I did some more troubleshooting and figured out how to get the plate off that houses the switches. I disconnected the fan switch and created a safe electrical by-pass. I re-connected the main power supply and sure enough, the fan worked. Issue = defective switch. Currently looking to order replacement. Problem solved.
Posted on Apr 11, 2009
  • 732 Answers
SOURCE: Power inverter installation?? (Vector 2500W in Tacoma truck)
Don, There are two ways in which I would have satisfyied the 6 foot guide line. 1. Mounted the VECTOR under the hood. 2. Supplied the VECTOR with additional "bed mounted" battery to be charged via the present wiring with a two pole single throw "knife switch" as as the "connect/disconnect to the vehicle battery/alternator for charging the new battery. In any case, you should make it a twice yearly thing to inspect the 15 feet of wire now installed, for wear and tear faults that could result in sparks, smoke, fire. You may need to visit local electrical supply house to see what they have to offer in the way of small "breaker-boxes" that may be capable of handling such large GAGE wire. I MEAN #2 gage wire IS very thick and expensive per foot!!!! A disconnect box similar to type found mounted to brick-work and next to and connecting a 1.5 to 2 ton central air unit might do the trick. But anyhow, if you are not going to use the VECTOR disconnect the POSITIVE lead at the battery and tape the connector with electrical tape to be safe. Let me know how it works out for you. lmistyrel@ 12fixlouie
Posted on Nov 30, 2009
Battery connections
? I'm at a lost on why you need 8 battery's for 96 volts? make it 9 and you have 108 in volts?
not my problem, You hook up positive from bat 1 to Neg on battery 2 pos on battery 2 to neg on battery 3, and keep going till you only have 1 positive and i negative and when those are used you will have 96 volts,. OR you could just use the inverter and 1 battery for 110 volts?
Jul 02, 2014 | Inverter Aims Pure Sine Wave Power...
I have a 1250 watts inverter and i wanted to know if i can connect it to my 2003 ford explorer without connecting it straight to the battery
Let us look at the math. 1250 watts at 120 volts is w=va Watts equals volts times amps. Or in this case 1250 divided by 120 volts = 10.41 amps. But what is the 12 volt side capable of drawing. 1250 watts divided by 12 volts. 104.10 amps. This is more than what the average cigarette lighter or power port can provide. So, yes you need to connect directly to the battery, you can use a relay rated for 100 A in between the inverter and battery to control the power to the inverter. I would use a good #2 copper welding cable for the power leads. Now, if you are not planning on using the whole 1250 watts, then you can use a #4 welding cable (it is very flexible) for power leads.
Jan 21, 2011 | Inverter Aims Pure Sine Wave Power...
Red fault light comes on after about 10 mins and
Had a similar problem with the same inverter BUT to include a failing cooling fan.
Take it back and get your money back as soon as possible.
Replaced it with a pure sine inverter 1500 watt that is kicking **** 24 seven days a week on my solar / wind power system.
Hope this tip helps.
Dec 24, 2009 | Inverter AIMS 1000 Pure Sine Wave Power ...
Same inverter, running low power items. Fans do not operate.
Some inverters don't like being turned on without a load pluged in to it. Try plugging in and turning on an appliance (eg a soldering iron) before connecting the inverter to the battery. If you still get a fault it may be an internal fuse or electronic problem. In this case you'll need to get it repaired.
Sep 15, 2009 | Vector 3000w
Overload light on Aims 5000w inverter
try to disconnect all cables from front and back, then turn the unit on and let all the stored charge drain and reconnect and test...make sure the unit grounded
Sep 06, 2009 | Inverter AIMS Power 5000 / 10000W
My aims 2000 pure sine wave inverter is pluged to 2 240amp/h 6 volt batteries. When | plug in a 1800 watt hairdrier i get an alarm as if the batt. were to low. they are new and at full charge. is the load...
Your inverter has a peak of 3000 watts rating and should power that hair dryer. Make sure your batteries are in good shape. The inverter can only put out what it takes in. 1800 watt demand on the inverter requires 1800 watts from the batteries.
Jul 14, 2009 | Inverter Aims Pure Sine Wave Power...
Aims 5000w inverter
Try shutting down the load completely, then power up the inverter with no connected load. Then bring a little on at a time and see what happens.
May 21, 2009 | Inverter AIMS Power 2500 / 5000W
Want To Install a 1250 W Power Inverter on a Class A Motorhome
You are definitely on the right track. When you choose your power inverter consider the following: buy the inverter for around 40% more of your anticiapted load. You will need a double pole transfer switch to isolate the inverter from the generator(and visa versa). A simple double throw double pole switch with fuse or breaker protection should do it. You wouldn't necessarily have to isolate the curbside circuit as the double pole double throw switch would simply be switching the power from the existing generator to your new inverter for only the roadside circuit; i.e. you don't need to worry about the curbside power source as it will always be connected to the other branch circuit. Even if your generator or other source came on the system would be protected no matter what the the roadside configuration was set to as only one source of the 2 roadside power sources would be connected at any give time to the roadside circuit. The six dots represent the connecions for the double pole, double throw switch; shown supplying the new inverter to the roadside circuit while the source from the existing generator or inverter is disconnected via this switch from the roadside circuit:
existing * *------* new power inverter; switched to source
Middle 2 dots represent your roadside circuit and represent the "throw arm" of the switch. Safe and simple! If you don't have a voltage meter for your batteries you can purchase one for a few bucks. Just run it across the terminals so you will know battery condition as it is being drained (you may already have this indicator) You can find a transfer switch at an electrical supply place, maybe even Lowes. Make sure you get the switch that will be in a protected enclosre. The enclosurre can be purchased seperately if you can't find the switch/enclosure package together.
Good luck....gary
Mar 12, 2009 | Inverter Aims Pure Sine Wave Power...
Aims 5000 watt inverter troubleshooting
Dec 10, 2008 | Inverter Aims Pure Sine Wave Power...
Electronics - Others Logo
225 people viewed this question
Top AIMS Electronics - Others Experts
Are you an AIMS Electronics - Other Expert? Answer questions, earn points and help others
