Baumatic bwr1206 DOOR WILL NOT OPEN
New integrated baumatic fridge freezer installed yesterday but the door sensor alarm keeping going off..door is def shut. As baumatic gone into administration has anyone got any ideas plse?
It's telling you it has a fault, you have to find out who is doing the warranty work for Baumatic now, by law they have to honor the warranty.
Nov 30, 2013 | Baumatic Refrigerators
Baumatic bdw10 door catch
Have you tried at PartMasters. Looks like around 30 pounds.
Sep 22, 2012 | Baumatic 23 in. BDW10 Built-in Dishwasher
Hi - I have a Baumatic slt 014 cx and the internal latch on the door has seemingly broken. Is there any way I can fix it?
You will need to replace the lock unless the present observation of the lock will confirm if this can be mended by welding or brazing .
Please checck this link for tips to remove or check the lock;
http://www.espares.co.uk/advice/washing-machines/a/7/1294/how-to-open-a-washing-machine-door-thats-stuc.html
Sep 17, 2011 | Baumatic Washing Machines
My Baumatic bdw9 dishwasher's door is leaking from the bottom, I dont know if it is over filling or the door seals have gone, any help would be appreciated
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Dec 26, 2009 | Baumatic 23 in. BDW9 Built-in Dishwasher
I have a Baumatic American style fridge freezer. Problem is freezer door comes open when fridge door is shoot...
Re-level your unit and tilt it just a little toward the back. When you close the refrigerator door you in effect cause a compression affect which pushes the freezer door momentarily open. If it is leveled so that it is tilted toward the back the door would re-close under its own weight.
Jun 02, 2008 | Baumatic Refrigerators
Baumatic dishwasher won't start
Had this problem with the Baumatic 13. Perhaps the door is not closing properly. Make sure you push the door hard in the top centre. It should beep once and then start after a few secoonds.
Terry
Nov 22, 2007 | Dishwashers
Something went snap!
same thing happened to me. The door spring broke on hte right side. Got the baumatic people to come out to fix it at a fixed cost of £79. I think the spring part is only £3.
May 14, 2007 | Baumatic 23 in. BDW5 Built-in Dishwasher
Washing Machines Logo
Top Washing Machines Experts
