Laptop issues Cannot get out of this screen on my laptop
  • 783 Answers
Mine did this to me for awhile and eventually went completely black. (I had a pc) When I had it checked out they told me that my hard drive crashed and that it would cost more to fix it then my computer was worth (and my computer was only about a year old). Hopefully, it\'s not the same for you because it\'s such a pain to buy a new computer especially when you have lost all you info! However, if you have a mac and it\'s less than a year old it\'ll be covered by the warranty- after a year if you decided not to purchase the warranty then it\'s also going to be a better investment to buy a new mac. Good luck~
Posted on Apr 30, 2013
I have a dell studio 1558 laptop, suddenly while using the laptop the screen for blank so i did a hard shutdown. After that i tried starting my laptop, but there was only blank screen. I attached my...
Seems like a two fold issue here. The blank screen is possibly a faulty laptop display or inverter but the blue screen is caused by powering off the laptop whilst it was doing something and now has damaged files. With your external monitor connected power up and try to reach Safe Mode and let windows find the issue and attempt a repair or press F8 and select repair OS. When you have repaired the OS, shine a bright light at the laptop screen and see if the inverter is not running or a dead screen.
Oct 28, 2014 | Computers & Internet
Dell Inspiron N4110 laptop
Select the first option that says hard drive. If it wont boot from that, the hard drive is missing a key file OR it has failed. You may be able to do a restore or recover process if the drive is ok.
Apr 09, 2014 | Dell Inspiron Computers & Internet
The screen in my Philips 190SW8FS/00 monitor, suddenly becomes black... I connected it in a laptop, it does the same thing after a while. Do you know what might be the problem that causes this?
Its not a usual thing to happen, Just try to restart your laptop and check it if you get anything on the screen. It might be a operating system issue (in that case you will see the main screen of your laptop while starting like brand name ) also it might be a screen issue (in that case you can try to connect this laptop to any external monitor and check it) or it might be a hardware issue (normally caused by RAM)
Oct 18, 2013 | Computers & Internet
Laptop white screen
Having a laptop screen turn white is one of the most frustrating problems a user can experience since it prevents use of the laptop to find a solution.
A white laptop screen indicates a serious problem with the laptop's hardware, and no easy solution to this issue exists.
Just diagnosing this condition requires advanced computer knowledge.
Identification
With this problem, the laptop itself will power on and load the operating system as per usual, but the screen will become a complete, static white, according to LaptopRepair101.
No particular brand or make of laptop falls prey to this issue more than any other; it can happen to any laptop.
Causes
Since so many different brands and models of laptops exist, specific causes of a white screen vary from laptop to laptop.
The likely cause in most cases of a white screen on a laptop is a connection problem between the LCD screen and the video cable running from the motherboard.
The issue can also reside strictly with the motherboard or the screen might contain a defect.
Considerations Users can diagnose a white screen problem by opening up the laptop display case to determine whether a loose video connection on the back of the LCD screen exists.
Reconnecting the video cable should resolve the white screen; a video cable reconnection that does not fix the white screen narrows the root cause to a problem with the motherboard or the screen.
Motherboard Problems
The only way to determine if the laptop screen turns white due to a motherboard problem is to test out a different, working LCD screen with the laptop.
This requires the user connect the inverter board--the power supply for the LCD backlight and the video cable to the test LCD.
If the test LCD works with the motherboard, then the laptop's screen needs replacing; otherwise, a new motherboard is needed because there is no way to replace an integrated graphics card on a laptop motherboard.
Prevention/Solution
Taking apart a laptop screen may make some users feel uncomfortable, so you can use an external monitor connected to the VGA port common to most laptops if the processor and hard drive still work fine. Using an external monitor requires finding the proper function key command to toggle between the LCD and external monitor.
Warning
Taking apart the LCD screen on a monitor likely voids any manufacturer's warranty.
Consider visually checking the video connection to the laptop screen as a last resort if no other viable options exists.
The service manual that came with your laptop likely offers some tips to disassembling the computer, or conditions that could void the warranty.
http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/
Jul 02, 2013 | Dell Inspiron Computers & Internet
I am having a ACER TravelMate 5730 laptop. For the past three or four months whenever I boot my laptop it gives a blank white screen. If I reboot one or two times it will be ok and works fine. Sometimes...
2 Solutions Possible.
The connection between the LCD Screen to the motherboard is not connected well and is causing the issues you are having.
OR.
The screen itself needs to be replaced because it defective.
Mar 16, 2011 | Acer TRAVELMATE 5730-6984 LAPTOP LCD...
What can i do, they have a power but no screen, no one i can see
Blank screen Issue
1. Power drain your laptop ie., Unplug the power cable from the laptop, Remove the battery.
2. There is no power flow in your laptop now press and hold the power button for 10 to 15 sec.
3. Now plug back the power cable and start the computer normally
3. This will fix the issue.
4. If not, its an issue with your laptop hardware ( Display screen, SMPS or RAM)
Dec 13, 2010 | Lenovo IdeaPad S10 - 42312BU Notebook
The screen flashes whenever I move it around it looks like the scrren is off when it turns black.
As you say the the screen flashes whenever you move the laptop the issue might be with the internal connections. However, to isolate the issue with the software or hardware.
Restart the laptop, press F10 to enter into the BIOS screen. Then move the laptop and check if the BIOS screen flickers or not.
If the BIOS screen flickers then we can confirm that it is a hardware issue and your laptop needs to be serviced to fix this issue
Jun 15, 2010 | Computers & Internet
Lines are showing up at the lower part of my laptop screen
The screen is going out and will eventually need to be replaced.
Jan 05, 2010 | Compaq Presario Notebook
Laptop malfunctioning
Connect any Desktop monitor to the Laptop and check whether the Display. if the display is fine on the Desktop monitor screen then it can be identified as the Laptop screen malfunctioning.
And if the Display has the same issue that on the Laptop screen
then it can be treated as the Display card issue.
However, it seems to be Harwre related issue. Get the laptop veriufied under Technical supervision to repair the Laptop's display card or the Laptop screen to be replaced if the display is fine on the Externally connectd Monitor.
Aug 04, 2008 | IBM ThinkPad T40 2373 Notebook
Computers & Internet Logo
David Payne
David Payne
