Question about Garden
Pd18j carburetor governor
There is a black line on the bottom of my pd18j carburetor that I removed from my scooter but it doesn't hook up to anything. my scooter also does not run so I'm trying to figure out what is wrong with it. It's a brand new 2010 sunny jl5808t-8 but it still will not run. it's been sitting in my garage for 2 years and it has a total of 33 miles on it. i haven't cleaned it since use the first time but it isn't dirty because of the time i've used it i assume
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
That black wire is a fuel injector and it has to plug into something but sitting two years you have to have carb rebuilt and fuel system cleaned out to
Posted on Jun 07, 2014
  • 59 Answers
SOURCE: lawn mower ony runs at idle and dies after seconds
try holding the throttle open
Posted on Jun 26, 2009
rwvanlue
  • 486 Answers
SOURCE: Poulan Pro Mode 96134000800 push mower dies immediately
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Nov 22, 2009
2strokeJim
  • 577 Answers
SOURCE: Toro GTS 20332 (bought it 12 months ago) won't run
I believe that Toro Guarantees to start 1 Pull, was gas left in it all winter?, If so this is'nt covered under warranty, cause gas is to be ran out or dumped out at end of season this will prevent any gumming up of carb . did you completely disassemble carb? does it have a primer on it, those gskts need replacing, clean out the jet in bottum of float bowl,small holes,sometimes missed and remove and check your needle/seat to make sure that when float drops gas runs out then lift float up and gas should stop. hope this helped you,another thing spray carb cleaner in carb and pull over and see if it will start that way enough to keep running with choke to see if it will **** gas into it
Posted on May 16, 2011
  • 17 Answers
SOURCE: Hi, I have a Craftsman
the Primer bulb most likely has a crack in it. If it does then there won't be sufficient suction to draw in the fuel. Also, if you remove the carburetor, separate the upper and lower halves so you can get to the fuel bowl, check that the float needle isn't sticking inside the hole. Look for dirt and other contaminates.
Do you by chance have the model # of the mower? It will be in the following format: XXX.XXXXXXX The model # sticker is usually located on the deck behind the engine. And what HP is the Engine? (It should be a Briggs and Stratton.
Posted on May 27, 2011
rycgl
  • 1545 Answers
SOURCE: Just bought a self propelled
It is possible that the scews and/or latches for the cover will be accesible UNDER the deck where the blade it. Have someone tilt it back while you check and/or hold it for you while you removes the retainers and screws. If the unit IS defective, I suggest you take it back as the Toro should be warranted.
Posted on Sep 11, 2011
Testimonial: "Thank you!! :)"
Air vane spring location
Dose your motor have a manual choke or automatic?
Jan 26, 2015 | Garden
How do I connect the throttle to the carburettor on la125100 series
THis provide that it still the Briggs 331877 on it
Install Carburetor
NOTE: Always replace air cleaner gaskets and carburetor mounting gaskets any time the carburetor has been removed for service.
1. Position new gasket on studs with long edge of gasket opposite fuel inlet of carburetor.
2. Hook governor spring in throttle lever hole without grommet. Hook governor link in throttle lever hole with grommet.
3. Hook choke link into outer hole of choke shaft from underneath. Slide other end of choke link into slot in governor control bracket.
4. Position carburetor on engine. Install Carburetor to intake screws or nuts and torque to 70 in- lbs
5. Connect fuel hose to carburetor and secure with hose clamp.
6. Using new gasket, install air cleaner assembly to carburetor.
Adjust carburetor, if applicable.
7. After final carburetor adjustment, use Knockout Pin #19135 to install new limiter cap with flat side facing up.
Jan 08, 2015 | Garden
208cc b&g craftsman snowblower governor settings
sounds like last years ethanol gas messed up your carburetor.
Probably have to drop the carburetor Bowl and clean the Jet
Nov 22, 2012 | Craftsman Snow Blower / Snowblower Bottom...
2006 Yamaha Vino 125 scooter turns but doesn't start
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to the carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and CDI box.
Spark plug cables in bad condition and shorting check for leakage in the dark, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty MAP, CKP, O2, TPS, sensors.
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box.
17. A stuck bent or burnt valve.
18. Tip over sensor needs a reset.
19. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Scooter Troubleshooting Scooter won start All about Scooters
Scooter won start
Yamaha YJ125S Service Manual
OEM parts for Yamaha
Yamaha VINO 125 Owner Manual
Oct 03, 2012 | 2006 Yamaha Vino 125
50cc Scooter won't rev up, Keihin PD18J carb
my 50cc scooter will idle at first and rev very well but wont idle what can this be
Jul 08, 2012 | Motorcycles
Electric scooter no power to motor
Sounds like the surface of the relay needs to be cleaned. Doesn't let enough juice through the connection to keep the contact. Might even just need a new relay. Or "Curtis Module."
Apr 16, 2012 | Pride Celebrity Xl 4 Wheel Scooter
We had the Hunter fan installed in April and have been very pleased with its performance. About a week ago whenever you turn on the fan light it flickers nonstop. Can you help me?
this is caused by the watt governor or the black box in fan to the lights. remove the watt governor and wire the lights directly. when removed, hook white wire to white wire, and black wire to red wire. black and red wires are always the hot wires. governor part number- 98480-02, have a good day !!
Jun 19, 2011 | Hunter (25417) Ceiling Fan
I have a Yamaha super jog 90 motor scooter which I inherited from my Grandson.He was involved in an accident and the scooter was damaged a fair bit.It was stripped down for a rebuild and when assembled...
Typically there is a vacuum fuel petcock involved. When the motor is turned over a small vacuum line opens the fuel petcock and fills the carburetor with gas. If the vacuum line is not hooked up correctly the fuel will not flow when vacuum is applied. If the petcock is stuck, the fuel will not flow. Also if the carburetor has been sitting with old fuel in it for a while the float needle may be stuck closed stopping fuel flow. Clean the carburetor and inspect the fuel petcock for operation and correct hook up.
Dec 28, 2010 | Yamaha G5 Motorcycles
Where to hook vacuum lineon might carburetor Jeda 50 cc
The vacuum port is near the mounting flange, sticking out horizonally near the top on the right side just above the fuel inlet. This vacuum is used for the fuel pump or the fuel shutoff valve, otherwise it is plugged off.
Sep 28, 2009 | RTO Gas Motor Scooter
Whre do the two vaccum lines hook up, one comes out by the intake on top and the other from the very bottom??
If u re on the kick stand of your scooter there is a vacumn line that connects the main carb and also the one near the black fuel inreacher. Mine is cut and the front hose is open. the back one id okugged. this indicates that the fuel enricher is not working. Scooter runs great, sarting is good but not great.
Apr 27, 2009 | Watches
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
