Question about Health & Beauty
240 v should work right?
I want to hook up my tanning bed and use my 220 dryer outlet both of them are 240 volt should it work? Cause I just get a loud humming noise.
  • 742 Answers
Yes, so long as the dryer has a circuit breaker that has the amp. rating that is required by the bed it will work fine.
Posted on Jun 02, 2014
  • 25 Answers
No, voltage is not the issue, what is the amperage you need. If you need more than you have, then you could have 2000 volts and it will not work. Also your taking AC to AC, or DC to DC. There's a big difference in what you need for each.
look up Ohms law for for the calculations needed for voltage vs amperage using one socket.
good luck
Posted on Apr 30, 2013
    Top Expert:
  • 10,875 Answers
Make sure that white connects to white and black connects to black in the plugs,if it is wired correct and only hums,then there is a problem with the bed
Posted on Apr 25, 2015
  • 774 Answers
Yes, absolutely, Your tanning bed manual and electrical label will indicate the either the number of Watts consumed or used when the bed is in operation or the the Amps (large letter A) consumed by the bed. If you have only Watts listed, convert to Amps using the formula A= Watts/Voltage Your 220-240 Volt AC circuit breaker should be at least that Amp capacity for the bed to work properly. A slight hum you may hear is largely due to fans inside the bed. DO NOT use an extension cord to plug your bed into to reach the socket. Most extension cords that one may make themselves for such uses, are contrary to the instructions provided by the equipment mfr. The use of an extension cord is contrary to the National Electric Code as a replacement for permanent wiring, so your Fire Insurance Policy on your home is voided in the event of an electrical fire.
3 Suggested Answers
  • 60 Answers
SOURCE: Is tanning on a tanning bed just like tanning outside in the sun?
No - it's very different as outside, various objects block the direct rays of the sun and allow you to be outside in the sun for a lot longer. Tanning beds are very instense. You should not be on the bed for longer than 10-12 minutes for your first sessions and be very careful about adding extra time.
Posted on Feb 18, 2013
  • 61 Answers
SOURCE: We just opened up a tanning salon. The beds are on individual timers and we were trying to hook up the timers to a main computer in order to be more efficicient. The timer locked up when we entered
is there a key lock? if so, locate the key lock at the front left of the timer and then insert the key, turn it clockwise and hold it for 5 seconds. other timers have a card to scan to unlock.
Posted on Mar 04, 2013
My machine has a 220 plug and I need a 110. How can i change this to work?
if that's an electric dryer that runs on 240 volt and that's why that cord is on it you can't just remove it and put a 120 volt cord on it,you need an electrician to run a 240 volt plug in your laundry room to run the dryer.
May 03, 2018 | Dryers
Plug in for a 24sr tanning bed for my home
Was your furnace electric or gas? If it was electric it was probably 220 and should work (although testing with a volt meter would be a great idea)
Jun 17, 2016 | Health & Beauty
How can I wire a 110 outlet to a 220 outlet?
If the bed is a 220 volt, you can only use a 220 volt outlet.
If the bed is 110/220 you should check the web for specs and wireing.
May 31, 2014 | Health & Beauty
2003 SUNQUEST PRO 24RS MANUAL TANNING BED
I Have a m2 24rs8 tanning bed. I loved it . I have moved it was in storage for 2 1/2 years. Moved to a new house. I hooked my bed up. the only thing it does kinda turn the fan on. what have I done wrong....It is on a 20amp bracker. Wire is 12 2 with ground. HELP PLEASE
Aug 25, 2012 | Wolff Sunquest Pro 24RS 220 Volts
I need a owners manual for a Sunquest Pro 24 RS, Wolff Systems tanning bed
Have a trained technician to look at it. You probably have a loose wire nut in the wall box if it is hardwired or a loose connection on the wall receptical. The screws on the recepticals can come loose when pushing the receptical into the wall box. Most new construction uses plastic wall boxes so shorting out the receptical screws to the box should not be a problem. It is possible that the bare ground wire inside the box is hitting one of the receptical screws. If so, then push the bare wire away from the screws with an insulated screwdriver.
Jul 22, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Tdc is not heating any more (dryer)
If it is spinning then you may have lost a 110 leg on your electrical outlet that causes the heaters to come on. Start there and work your way back to the dryer. You should have 110 from the ground(lower center hole) to the hot left hole. You should also have the same on the 110 ground to the right hot leg. if you check both the left and right together you should have 220/240 volts. If you don't stop right there and call an electrician. If you do have 110 on each leg as we call it giving you a combined 220/240 volts (it sometimes varies) move up the line to dryer. Either the heater coil has broken (good time to check for good airflow at the vent) or a non resettable thermostat has been tripped causing the heaters to stay off. Poor airflow can cause these two things to fail. The thermostat will need to be replaced if it is the non resettable type. The heaters may have gone too. Those should be checked as well.
Oct 16, 2009 | Hotpoint TDC32 Electric Dryer
A diagram of how to wire a 220 volt outlet from two 110 volt outlets.
You can't really do that. The two 110 outlets probably come for the same 'leg' of the 240. If you check them with a meter, there will be '0' volts between the two hot wires. So, they have the same 'potential'. You need a regular 240 volt circuit from a double pole breaker that is rated for the wire size that it's feeding. 20 amp-#12 ; 30 amp- #10 etc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
Ler662
CHECK FOR 240 VOLTS AT DRYER ELEMENT WITH DRYER
RUNNING IN HEAT CYCLE. IF NO VOLTAGE, CHECK WALL
OUTLET FOR 240 VOLTS BETWEEN LEFT AND RIGHT SLOTS IN RECEPTACLE. A DRYER WILL RUN ON 120 VOLTS TO
GROUND BUT WILL NOT HEAT IF 240 VOLTS IS NOT PRESENT. IF THERE IS 240 AT THE OUTLET, START TRACING THROUGH THE HEATER CIRCUIT. LOOK FOR A FAILED THERMOSTAT OR THERMAL FUSE NEAR THE HEATER OR EXHAUST OUTLET. CHECK THEM WITH A CONTINUITY TEST WITH DRYER UNPLUGGED, OR A VOLTAGE CHECK WITH A HOT CIRCUIT.
Jul 28, 2008 | Whirlpool LER5636P Electric Dryer
Health & Beauty Logo
127 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
