Question about Minolta EP1083 CS/PRO Copier
Service manual Dumps load of toner about 1" wide along bottom of page.
  • Minolta Master
  • 1,294 Answers
Clean or change the drum cleaning blade,check the fuser unit rollers abd the transport belts.Clean the image transfer/separator coronas unit,check ,clean or change the drum antisplit bade,located under drum cleaning blade.
Posted on May 01, 2013
What causes streaky copies
A few questions:
- Did this problem just start?
- Was there a paper jam and when the paper was dislodged the next few sheets were streaked? Running a few more pages usually clears this.
- Is this a new toner cartridge? Did you just change the cartridge? Are you low on toner? Try removing the cartridge and gently rocking it back and forth, side to side. This will distribute the toner more evenly.
- Is this a heavier weight paper then previously used? Try going back to the old weight and see if the problem continues.
Aug 19, 2014 | Brother MFC-8860DN All-In-One Laser...
I have a code E000013-0001 code showing on Canon 6055i copier
Its on the rear bottom right, I believe there is two screws, remove the panel and take out the bottle and empty it. After replacing the waste toner case or removing the waste toner from the case, clear the toner counter in service mode as follows:
To get into service mode, hit additional functions[*] 2&8 follow by additional functions[*] again. [Select [COPIER> Counter> MISC> WST-TNR], press "C" (Clear key) to clear the counter, and turn the power OFF/ON.
You can also change the detection level as follows:
The waste toner detection timing is determined by the total page counts specified in service mode below:
1. Page counts until the warning message is indicated
2. Page counts between the warning message and E013 indication
Field Remedy
Follow the steps below if you want to change these page counts:
In service mode [COPIER> Adjust> MISC> WT-FL-LM], select any number from "0" through "4".
0: 80,000 / 1: 140,000 / 2: 210,000 (default) / 3: 320,000 / 4: 460,000
In service mode [COPIER> Adjust> MISC> WT-ER-LV], select any number from "0" though "3".
0: 1 / 1: 20,000 / 2: 40,000 (default) / 3: 60,000
Apr 24, 2013 | Canon IMAGERUNNER 6570 Copier
My intellifax 4100 has a wide solid black bar approx 1 1/2 wide down the entire right hand side of the page of faxes that I send. (faxes that are received by others). The machine works perfectly in every...
Here is a list of possibilities.
1. The scanner glass is very dirty on one side. (the area the paper paasses over.)
2. The laser scanner lens is dirty on one side
3. Look in the bottom of the machine and locate any mirrors and clean with a dry soft cloth.
You will need to remove the drum and toner to do this.
Feb 23, 2011 | Brother IntelliFAX 4100 Laser Fax
2130cn printer vertical light streak about 1/2 inch wide down the paper from top to the bottom of the page. using non-dell toner BD
Hello.
The most common reason is the toner. Replace the toner with another. Use a Dell toner, if possible.
Hope this helps.
Oct 19, 2010 | Dell 2130cn Laser Printer
Paper won't feed
Cleaned the pickup roller (pull out the toner cartridge - it's the large 1" wide roller at the back) with a little 91% isopropyl alcohol ($2.50 at the drug store), The printer feeds perfectly now.
If this didn't work, then Samsung tech support suggested replacing the pickup roller assembly which is available at www.samsungparts.com ($6.95) along with a service manual ($28). But, fortunately, it wasn't necessary.
Dec 24, 2009 | Samsung SCX-4725FN All-In-One Laser...
When printing, I see a vertical streak on the printed page, from top to bottom, about 2 1/4 inches from the left side of the paper, and about 1/16 of an inch wide. I can't seem to see what causes this. The...
This is more than likely down to the upper roller in the fuser assembly. It's the heat roller at the back of the printer. The upper roller wears so paper dust and toner stick to the roller which then can get deposited back on to the page.
Oct 15, 2009 | HP LaserJet 1020 Printer
An Empty Stripe along the right side of portrait setting
Have you tried a new toner cartridge? There is a couple possible culprits.
Thanks,
Lee
Jul 19, 2008 | Dell 3000cn Laser Printer
Seems to print a red or yellow line down the edge about 1 to 2mm wide, prints black fine. All toners over half full. Test page seems fine but can see red line along edge.
What ever color the line is you need to replace that photoconductor unit. They can be ordered from a Ricoh dealer and come with instructions for installing.
May 04, 2008 | Ricoh Aficio 3800CMF Laser Printer
Toner is skipping in same part of the page
you have a weak photo drum or dirty corona wire take drum assy out and spray metal grid above drum suface with canned air until free of toner dust(take outside to prevent toner dust from getting on carpet or household ) items.
After cleaning reinstall drum and run printer.
Jan 07, 2008 | Konica Minolta magicolor 2430 DL Laser...
125 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
