Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron won't power up
Sony 35kv35v35 just stop working all of a sudden. Working on it in garage at the moment. Check fuse + good. Unsure what to do next?
I had the same problem, was just playing halo on it it turned of an now will only go on standby an the screen stays black. i have been told to check all the solders (about 100) to see if any are burnt or have a problem.
Posted on Aug 16, 2007
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Today my 1990 nissan terrano/pathfinder just stopped running. wouldnt start back up but would turn over fine........
Sudden death in vehicle is usually based on something electrical. Check fuses and relays with fuses. Check 1) spark on each plug in turn 2) crank sensor 3) coil 4) cam sensor 5) main relay. Put ignition on position 2 and listen at the open fuel filler pipe for the pre-pump operating. Listen for main pump operation. (If unsure what it is you are listening for remove the fuse for the pump and you nshould notice it being quieter) Check fuel rail for pressure (there is a Schrader 'tire' valve on the fuel rail for pressure testing purposes). If fuel flow is low then this could be blocked fuel filter or tired pump. Finally make sure throttle body is good and clean internally at least and that associated idle air valve is clean and working. With fuel air and spark at the right moment the engine should run. My gut feeling is the crank sensor
Sep 29, 2010 | Nissan Pathfinder Cars & Trucks
No power to my KV-32V15
Unplug the unit, wait at least 30 minutes before beginning work after unplugging. take the back case off, there are 10 screws I believe holding it on. Where the power cord goes into the unit, look on the circuit board and you'll see a fuse. Check the fuse, I'll bet it's bad. Replace with the exact same type. I have the same TV, had the same issue. I'm now enjoying it just as I once was. Good luck.
Remember to be VERY careful when inside a TV, there are power sources that are fatal.
Nov 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony Trinitron won't turn on...has 4 blinks in Standby.
There are 3 reasons for 4 blinls
1.unit went to stand by mode because of h-pulse
2.Vertical defflection pulse stopped
3. power line is shhorted or power supply is stoped.
Solution:
1. check 13vdc on A board of powersupply stage
2. Check IC561 on A-board.
Good Luck
Dals123
Sep 08, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power windows don't work anymore
check your fuses or relays under your hood drivers side .
Aug 21, 2008 | 1999 Dodge Durango
Sony 36" Trinitron Problem
Good day.
There may have been some problem in the horiontal transistor. Also, Check for the zener diode that controls the supply going to the flyback. It might got busted due to the sudden supply surge.
chris
Mar 15, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony trinitron tv just stopped working? no warning now does nothing
If the LED is not blinking a code. You have a power supply problem usually means the horizontal ouput and regulators are shorted. Let me know if you need more info and include your model number and I can be more specific on what to check.
Feb 09, 2008 | Televison & Video
Trinitron KV-36FS13
The problem is in the standby power section. Check the fuse, R607, or burnt IC601, fuse R612 and VD relay 601 should show open. Its possible it could be the high voltage area of the power supply. You can try unplugging the set and cable and let it sit 4 to 6 hours. This is a hard reset. If it still doesn't turn on after the hard reset and the fuses and relays are fine, and you don't smell anything or see anything burnt. Then you'll need to call a TV repair man. They normal start around $150-$200 to fix the set. I hope this helps.
Jul 10, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
57 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
