Pink screen screens gone a light pink
  • Computers & ... Master
  • 5,660 Answers
Problem can be;
1) Graphics chipset
2) Video Cable
3) screen Inverter (IF Used)
4) LCD screen
Diagnose to find out.
I need the laptop manufacturer name, and model number.
Model number can be found on the Bottom of the laptop.
Post back in a Comment.
A) Graphics chipset:
An external monitor is used to check, and see if the display is also pinkish on it; or it is OK. Info posted I need, I will detail this procedure out step by step.
Display good on external monitor means graphics chipset is OK.
(Mounting is usually the problem)
Means problem is screen Inverter (IF used), or Video Cable, or LCD screen.
B) Video Cable:
The Video Cable connects to the motherboard, in an area under the Keyboard, or under the Switch Cover.
(Depending on laptop design, Switch Cover may be an integral part of Palm Rest Cover)
From there it leads under, or close by the left Hinge; and then goes up into the Display Assembly.
IF, a screen Inverter is used, the Video Cable has a separate small cable that branches off; and connects to one side of the screen Inverter.
The main part of the Video Cable connects to the back of the LCD screen.
Just due to normal repeated opening, and closing of the laptop; the Video Cable may become pulled on, and/or pinched.
This can lead to a loose connection at the motherboard side, or LCD screen side. (and/or screen Inverter, IF screen Inverter is used)
Can also lead to a damaged Video Cable. (Stretched/Broken wires inside it)
This can cause a pinkish screen.
C) screen Inverter:
With Backlighting that uses CCFL/s for a Backlight, a screen Inverter is used.
(Cold Cathode Fluorescent Lamp)
For Backlighting that is LED, a screen Inverter MAY, or MAY NOT be used.
(First design LED backlighting seemed to. Later design LED backlighting, does not. Light Emitting Diode)
A screen Inverter is used to convert the power (Electricity), from the laptop; for the LCD screen and Backlight.
Screen Inverter going out, can cause a pinkish screen.
D) LCD screen:
Graphics chipset is good, Video Cable connections are good; no damaged Video Cable, screen Inverter is good (IF used); problem is LCD screen.
Awaiting manufacturer name, and model number.
Regards,
joecoolvette
Posted on Apr 30, 2013
Vizio pink screen
do other I/O ports work? May have defective I/O PCB
May 03, 2014 | Televison & Video
Pn60e530 Samsung plasma tv when turning on screen flashes pink then goes black Sound is on no picture
screen drive on back of the screen has gone. they do over heat. the pink is the plasma lighting. replace the screen driver board and should be fine, when replacing put a bit of heat sinc on the top of the 2 or so chips big square ones on the board should help it last longer.
Sep 14, 2013 | Televison & Video
The screen on my Dell Latitude D505 became grainy and exhibited pink and green areas. Normal colors were gone. And then, the screen went black, however when I shine a flashlight on the screen, I can...
hello
very much sounds like the back light in your screen has gone. this is a small flourecent light that is fitted inside the bottom edge of the lcd screen, these can be replaced , best bet is try another screen. if screen ribbon cable is ok, realy only a few other things it could be, inverter, or graphics card. i hope this helps you
Aug 09, 2013 | Dell Latitude D505 Notebook
I turned on my TV and the whole screen has a pink tint
If using a box for signal disconnect it from power for a while to see if when it reboots this issue is gone or not.
Nov 28, 2012 | Samsung HLP4663W 46" Rear Projection HDTV
When i turn on my flatscreen tv the screen comes up pink and crackly
i had same problem.thought the tube or r light had gone.i looked internet & saw it could be 1 of many problems.simplest solution was colour saturation was wrong.i turned saturation down to -14 & hey presto it worked
Jul 26, 2010 | Philips 20 in. TV/VCR/DVD Combo Flat...
My sony 790 was dropped and now the colour has gone the screen is all pink can see the picture but only in pink
Your screen hasdamaged ..Only way to retrieve that will be changing the display.....Let me know the feedback...
Thank you...
Oct 09, 2009 | Cell Phones
Pink screen
Not a motherboard issue. If the screen looks pink it means the backlight tube inside the screen ain't reaching full brightness (the tube has gone bad). If it flickers? Well... remember them good old florescent tubes and what happened when they go bad? Same thing.
You have a bad tube in your screen and ... hence, a defective screen.
Apr 14, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Apr 01, 2009 | Epson PowerLite® S4 LCD Projector
Computers & Internet Logo
David Payne
David Payne
