Question about Plumbing
Faucet hard to turn on - Plumbing
  • 17,173 Answers
What is the model?
Posted on May 19, 2013
Sticking of KWC Suprimo faucet
My bathroom faucet handle (not same brand as yours) was so hard to turn that it pulled the base around with it on the vanity when I jerked it. I used an Allen wrench to take out one of the set screws holding the handle on, put the tiny straw of a WD40 can in the set screw hole, squirted WD40 inside the handle, replaced the setscrew, and worked the handle to and fro a few times to lubricate the inside. No more sticking!
Feb 22, 2014 | KWC 10.271.333.700 Suprimo Kitchen Faucets
Water just trickles out of the waterfall faucet
Look for the obvious-take off the screen. Then you may have to venture into the faucet itself. If you have galvanized pluming, every time you shut the water off, scale will fall int the center of the piping without pressure and then when you open the faucet it tries to flow through small orifices.
Dec 13, 2013 | Garden
Jameco single handle kitchen faucet with spray hard to turn
make this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals .
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type.
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
If the aerator leaks around the edge, replace the washer in the aerator
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head
Nov 25, 2013 | RTO Jameco #K-1320B Bone Drop In Lav Sink
Faucet leaks when water is turned on at the spout base. I took the set screw out of the back but can,t remove it to access the orings or seals
better turn off the main line first, screw the ring again putting some extra pressure because usually rings are tighten so hard.you have to replace the base of the faucet.
Jun 22, 2011 | Banner Faucets Castille 700 Vintage Series...
Dripping faucet
first step would be to change the rubber washer or o ring.
  1. buy a proprietary washer kit from any DIY store.
  2. Turn water off at isolating valve on teh pipe underneath the sink / bath or at the mains and or hot water tank as appropriate
  3. Remove the top of the faucet (often there is a plastic circle at the top that prises off to reveal a screw - mixer taps may have a grub screw on the side)
  4. Gently using a wrench to loosen the nut unscrew and remove the tap (faucet) barrell (middle bit)
  5. Remove nut that holds washer in place and remove it or, in the case of an O ring - prise it off with a pin or needle.
  6. Reassemble in reverse order - do not over-tighten.
If that doesn't stop the drip then the seat that the rubber washer / O ring seals against may be pitted or grooved. Either buy or hire a 'tap (faucet) seating tool.
  1. Turn off water before opening the faucet
  2. dismantle faucet as above
  3. Find which of the sleeve adapters that comes with the seating tool is teh right one to screw into the top of the faucet body
  4. select the grinding disc that is closest to the size of the seat and screw it onto the end of the seating tool
  5. Screw the tool into place in the top of the faucet body - just finger tight.
  6. Pressing down firmly with even pressure (but not too hard) on the top of the seating tool rotate the handle backwards and three or four complete rotations.
  7. reassemble the faucet but DO NOT close the faucet off
  8. slowly turn the water back on and allow it to flow hard for a few seconds to flush and debris out of the spout
  9. Slowly close the faucet and check for leaks.
  10. If necessary repeat re-seating process
Feb 27, 2011 | Home
Sour smelling/ tasting water from bathroom faucet when not used for several hours. Smells like traces in water bottles, which I can bleach or wash in dishwasher. How do I clean possible bacteria from a...
Assuming the problem is right there at the faucet, and not further upstream (which you could verify by taking a little water from the tub faucet), perhaps you could try this--- turn off the water supply then remove the flexible water supply lines from the faucet underneath the sink. These are usually not too hard to remove from the faucet with a basin wrench (less than $10). If it's easy, remove the other end of the flexible water supply lines too. Maybe you should replace these. Otherwise, get the water out of those flexible line, then put some bleach into them. Reconnect to the faucet. Leave the faucet turned off, and turn the water supply back on. Then very slightly turn on the faucet to allow the air out, then turn it off. Leave the bleach to soak for a while (maybe 30 minutes) then flush plenty of water through it. If the smell comes back, there is probably something organic stuck in the faucet and you will have to disassemble or replace it. Good luck.
Dec 20, 2010 | Home
I have a Delta Waterfall 172 SSWF faucet in my kitchen. I need to replace the water spout - I have the replacement spout. It appears there is a plastic retainer ring that holds the spout in place but I'm...
Normally you just turn that ring, counter clockwise. If too hard to turn, I usually put a rag over it, to avoid scratching, and use a pair of channel lock pliers, and squeeze just hard enough not to slip.
Jan 15, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
My Am Stan series 4453 faucet has always been hard to turn left and right. The handle works fine, just the entire spout is hard to turn. What can I do to relax the tightness?
Look on the underside of the sink (in the cabinet) and find the nut that holds the faucet in place. Loosen it a quarter-turn at a time until it's where you want it. If it starts to leak, remove the nut completely, wrap the male connector with teflon tape, and replace the nut. Tighten it a little at a time until it's where you would like it. Good luck.
Dec 07, 2009 | American Standard 4275.550.002 ColonySoft...
When i turn my bathroom faucet on i get a sewer smell for about 30 seconds then it goes away. its only in the bathroom at that faucet. what causes that? thank you
check under sink for a clogged or a bad trap in drain. it is hard to believe that the smell is coming from faucet.
Nov 03, 2009 | Home
Peerless faucet with a squeeky hard to turn handle.
you can get a new cartridge for it or try pulling it out and putting some faucet grease on it the cartridge should come apart put grease on everything with a black o ring and you should be good to go
Jul 29, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Plumbing Logo
22 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
