Question about Juniper FIREWALL VPN Part SSG-320M-SB,"
Error message poll ordered: Oops timed out!" Getting this every 2-3 seconds after clearing configuration - any help?
Why Does the NMS Display the Error Message another nms was polling the switch with wrong communityWhen It Uses SNMPv2c to Connect to the Switch?
The reason is that the community name configured on the NMS is different from the community name configured on the switch.
When this error message is displayed, run the display snmp-agent community command to check the community name configured on the switch, and then change the community name on the NMS to be the same as that on the switch.
S6700 Switch Thunder link com
Nov 17, 2016 | Office Equipment & Supplies
Tip
Ink System Failure Fix for Some HP Printers
<span><span>Hewlett Packard Ink System Failure Error Fix (tested C6180) </span></span> <ol> <li><span><span>Press and hold the "*" key. </span></span></li> <li><span><span>Press the "#" key and release both keys. Display should say "Enter Special Key Combo" </span></span></li> <li><span><span>Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M </span></span></li> <li><span><span>Press and release the right arrow button until the display says "System Configuration Menu". </span></span></li> <li><span><span>Press and release the "OK" button.</span></span></li> <li><span><span>Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", </span></span></li> <li><span><span>Press and release the "OK" button. </span></span></li> <li><span><span>Display should say "Hardware failure status: Clear. Press OK to clear". </span></span></li> <li><span><span>Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". </span></span></li> <li><span><span>Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. </span></span></li> <li><span><span>Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.</span></span></li> <li><span><span>Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer </span></span></li> <li><span><span>Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. </span></span></li></ol><span><span>I hope this helps</span></span> <span><span><br /></span></span> <span><span>Regards GM</span></span>
on Jul 15, 2011 | Office Equipment & Supplies
May 31, 2016 | Huawei Computers & Internet
I installed Chrome, downloaded latest Adobe flash player and Internet Explorer 11...keep getting "oops msg about browser
Do's
1. Dont use two different browser like chrome and ie at same time.
2. I f you are getting message in firefox go to this link Firefox Nightly Fix Oops your browser seems to have cookies disabled error...
3.. Please give more detail if you post any question.
Dec 14, 2014 | Acer Aspire One PC Notebook
I am getting the message "Ink System has failed. Unable to print. Refer to printer documentation. Error:0xc18a0001." I have tried to shut it down and back on and it's still not working -...
1. Get the unit into the "Support Menu" by following the steps below according with the product,
A. - Press and hold the "left arrow" key.
B. - Press the "Setup" key and release both keys.
C. - Press and release the "OK" button
2. Press and release the right arrow button until the display says "System Configuration Menu". (on C8100 use Touch Screen)
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
5. Press and release the "OK" button.
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. If the error is still there, or reoccurs replace the unit.
VOTE ME IF YOU LIKE THIS SOLUTION
Aug 12, 2011 | HP PhotoSmart C5150 All-In-One InkJet...
I hav\e brother printer MfC and am getting the code "unable to print4F"what do i do??????
4F message indicates that the printhead is dead, you will need to replace it to make it work again. Before you replace it, you may want to try this, see if it will clear the error message: Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3. This will reset the purge count value. Then the printer will restart, hopefully without the annoying error message.
Jan 23, 2011 | Brother MFC-465CN InkJet Printer
I have HTC Smart 3188 Mobile, I am getting error message "Oops:A system error has occured restarting..." i tried taking out the battery and reconnecting it after some time...same probelm..pls...
what time it is Visible.i mean,After Sending MP3 Song,Video Song through Bluetooth.That time it'll visible,some virus is there.I have a same problem,suddenly delete the item.Afterthat problem slove.Try it
Jan 04, 2011 | HTC F3188 Smartphone
I am getting error 244 when receiving a fax.
errors 243 and 244. Taken from HP.
The user of the remote machine has pressed that machine's Stop key causing the session to be prematurely terminated. Alternatively: the remote fax machine determined there was a feature incompatibility between the two machines and has terminated the session. An example would be when the local machine wanted to initiate polling, but the remote machine did not support this mode of operation.
Solution:
1. Confirm the remote user is not inadvertently attempting to poll transmit from the local machine, instead of transmitting to the local machine. This mode of operation must be specially configured on the local machine. If poll transmission from the local machine is the desired mode of operation, confirm the local machine has been configured for this operation.
2. Reconfigure the local fax machine to use different configuration settings, toggle the ECM state and/or select a slower reception speed
Sep 20, 2010 | HP 910 Plain Paper Inkjet Fax
Gmail Error code # 008 OOps error while sending
Hi!
When ever iam trying to send any attachments to some id it is taking
time ,and at last iam getting a error message as
Oops.....the system was unable to perform your operation error code
008 please try again in few seceonds
pl help me how tp solve this problem this problem is comming since
morning
raju
Dec 24, 2009 | Google Gmail
I need help Please my printer won't print gettig an error
The error message is related to the card that connects the printer to the network. The card is most likely bad. You may be able to clear the message by turning the machine off for 20-30 min, however this does not always work. If the error persists, you should turn off the machine, remove the card (it is in the back where the cables plug in, it has a connector similar to a large phone cord and can be removed by loosening the two thumb screws and sliding it straight back) and hook the printer directly to the PC with a parallel cable. You can also order a new card (Part#J3113A) online, but it will take some time and needs to be configured after installation.
Hope it helps,good luck to your daughter with her paper!.
May 15, 2008 | HP LaserJet 4050 Printer
Juniper FIREWALL VPN Part SSG-320M-SB," Logo
155 people viewed this question
Top Juniper Computers & Internet Experts
David Payne
David Payne
Are you a Juniper Computer and Internet Expert? Answer questions, earn points and help others
