Baumatic integrated washing machine BWR1005
DOOR WILL NOT OPEN
SOURCE: Baumatic washing machine instructions
the twelve programs are explained on the detergeant drawer.if not i will post them for you.
to use the dryer turn the middle knob clockwise to the amount of time you desire upto 140 minutes then select the temperature on the far left knob and then depress the half load button your dryer should now work.
Posted on Jan 02, 2008
SOURCE: Baumatic BTWM6 washing machine flashing F02 error
hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
Posted on Mar 18, 2009
  • 3600 Answers
SOURCE: Washing machine front loading door won't open.
that is the way it's made you have to turn it off before you can open it or water would go every where.
Posted on Aug 20, 2009
SOURCE: BAUMATIC BFW1000W
Hello. I too am having the same problem with this model. Did you find a soultion at all. Also I can post you a copy of the user manual if you are still interested?
Posted on Aug 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: CAn you tell me what code FO6 means and is it an easy job I can do myself?
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
What does e33 mean on a baumatic washing machine
not saying this is whats wrong with it i just found this on the internet............hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
Dec 11, 2016 | Baumatic Washing Machines
Door wont open
Realign the switches by loosing the screws and aligning the switch and then tightening again.
Jan 12, 2014 | Baumatic BTWM4 Front Load Washer
New integrated baumatic fridge freezer installed yesterday but the door sensor alarm keeping going off..door is def shut. As baumatic gone into administration has anyone got any ideas plse?
It's telling you it has a fault, you have to find out who is doing the warranty work for Baumatic now, by law they have to honor the warranty.
Nov 30, 2013 | Baumatic Refrigerators
Our new integrated washing machine (Baumatic btwm4) sometimes doesn't spin properly and clothes are very wet. Even thought a single spin is selected, the same poor result. The machine is definitel
1) tes the belt for broken or worn replace
2)test the door switch, this cause to NOT spindle the machine , replace if necessary or readjust
3)Main control module or CCU, if the door switch test o.k, tight any wires connector well from loose, otherwise the CCU is faulty.
4) motor control module, this receive signal from CCU, tight any wires connector for loose, otherwise you must replace the board faulty.
Jul 18, 2012 | Washing Machines
Hi - I have a Baumatic slt 014 cx and the internal latch on the door has seemingly broken. Is there any way I can fix it?
You will need to replace the lock unless the present observation of the lock will confirm if this can be mended by welding or brazing .
Please checck this link for tips to remove or check the lock;
http://www.espares.co.uk/advice/washing-machines/a/7/1294/how-to-open-a-washing-machine-door-thats-stuc.html
Sep 17, 2011 | Baumatic Washing Machines
Beaumatic washing machine says fault code co3, what does that mean
machine is out of balance. Manual below. www.ecowashinglines-blog.co.uk/.../Baumatic-Fully-Integrated-Full-height-Washer-Dryer-BWD12.1.pdf
Mar 18, 2010 | Washing Machines
Feb 10, 2009 | Baumatic BTWM4 Front Load Washer
Baumatic bdw45.1 integrated dishwasher
sorry i have no knowledge of this "baumatic" product line. please repost with another expert
Jan 28, 2009 | Baumatic 18 in. BHD45 Slim-Line Built-in...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
