Question about Toshiba TP50G90 50" Rear Projection Television
TP50G90-screen will fade to black and then instantly power back on every 8 seconds
I have TP50G90. when powered on the set will run fine except that every eight seconds it fades to black as if it were being turned off and then will instantly power back on. during this effect the power light remains on and there is no break in the sound. any ideas. thanks,
    Problem Solver:
  • 18 Answers
Power board problem needs a shop fix or new transformer without a test you cant tell.....
Posted on Aug 08, 2007
SOURCE:
Vizio e500ib1 50"smart tv power on light then that goes out. has 5volt stand by only, there are voltage that come up but fade out. screen is black no sound. was working great perfect picture,
Do you have voltage (3.5V) on the PSON terminal when you push the start button on the TV...if you don't its the main board that has failed
Feb 09, 2018 | Vizio Televison & Video
Pentair Easytouch 8 loses low voltage power to contol panel
if while it fades check voltage from transformer if ok bad control board if fades bad transformer
Feb 17, 2018 | Pentair EasyTouch 8 System Pool and Spa...
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
PSP comes on and plays fine then the screen goes black?
I am having the same problem.  The screen will intermittently come on as blurry.  Like all the text and graphics are doubled, but off by a few pixels.  Doing a sleep and turning it back on usually fixes it.  But I can not operate my PSP for more than like 10 seconds to a minute (varying) until the screen freezes and fades to black from right to left.  This usually occurs by pressing any of the buttons on the front panel.  If I am reading the news in the browser for instance and it is just sitting there, it is fine, then the second I hit a button, fades to black.  After it fades to black, sound and buttons continue to work.  I figured it was a bad LCD, so I purchased a brand new OEM LCD screen and installed it, however, the problem still persists with the new LCD screen, so it is not the screen itself.
Jul 21, 2008 | Sony PlayStation Portable (PSP) Console
TP50G90 no power
sounds like something in the standby voltages most likely a regulator or leaky diode causing the problem.
Jun 22, 2008 | Toshiba TP50G90 50" Rear Projection...
245BW monitor not working (stranges colors ad aeternam...)
I had the same problems as almost all of these people and the answer seems to be that I uninstall the current Nvidia Drivers and use a previous set. The 169.28 were a real problem for me. Just when I thought it was working I would get the strange wash out and I could not turn it off except with the back power switch, aslo using the DVI turns off all the on screen controls.
Good Luck
Dec 27, 2007 | Samsung SyncMaster 245BW Monitor
Dell inspiron laptop screen issue
First, are you sure you have the correct power supply?
Also, the lcd inverter could be going bad, consequently needing more power than it can get off the battery.
Hope this helps,
Good luck
Oct 19, 2007 | Dell Inspiron 710m Notebook
Televison & Video Logo
97 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
