Question about Compaq Presario Notebook
Caps Lock on when boot?
Sometimes when I turn on my laptop, the fan sounds like it's starting, and the caps lock is stuck on (not flashing like most other posts when I tried to search for this), then nothing else happens, just a black screen, while it sounds like it's working... and then I have to reset with the whole battery out, power button 30 sec. thing... I was just wondering if it means anything, because it is happening more often recently, and only started happening in the last 6 months...
  • 6 more comments
  • Tyler DeSautel Apr 30, 2013
    1) It could be that... I've had this laptop for almost 2 years... P.N. = XU683UA#ABA
  • joecoolvette
    joecoolvette Apr 30, 2013
    Compaq Presario CQ56-129NR,.........http://h10025.www1.hp.com/ewfrf/wc/produ... .......The laptop's hardware components are cooled by air........The cooling components are; Cooling Tube, Heatsink, and Fan Assembly......Here is a general example,.....http://www.ebay.com/itm/HP-Compaq-Presar... .........(If the links are not highlighted in Blue, they are not direct links.....Copy the link {URL}, paste it in your address bar, { http://}, then press the Enter key) ......The Main view shown automatically opens to a Bottom view, of the cooling system.....In the 3 smaller views below the Main view, the small view all the way to the Right, shows a Top view..........In the Bottom view you see the finned rectangular Heatsink, at the Top.......Copper Cooling Tube comes down from it.....(No. The wires coming from the Fan Assembly, does NOT mount to the copper Cooling Tube.......That is a power cable for the Fan Assembly.....The seller apparantely just stuck the small Black male plug connector, for the Fan Assemblies power cable; to that white label for safekeeping ).......Coming DOWN the Cooling Tube, observe the first small rectangular shaped plate of metal.......That Cooling Tube plate sits on the graphics chipset (G.P.U.).........The next small metal plate down at the end, sits on the Processor. (CPU)..{Has three 'arms' coming off of it).......The Cooling Tube is a slightly flattened copper tube, sealed on both ends; and filled with Nitrogen.......The Heatsink is a small strip of metal, with Tall, Thin, fins on it........The Fan Assembly consists of a small Black multi-bladed fan, sitting in a D-shaped fan shroud..........Heat is absorbed from the Processor, and graphics chipset, by their two respective small metal plates....The heat from the small metal plates is absorbed by the Cooling Tube........The Cooling Tube transfers the heat up to the finned Heatsink........The Heatsink absorbs the heta, then radiates it away with it's tall, thin, fins......Air flow from the Fan Assembly helps carry heat away from the fins of the Heatsink........
    ok, so what are you telling me? are you telling me to buy this? or are you telling me what i have already? all I wanted to know is what the light means... and that wall isn't really formatted as instructions, if that's what you wanted to do...
  • joecoolvette
    heta......New word I apparantly just invented........As you have probably noticed by now, you can set your mouse cursor in the middle of the photo; and this enables the Zoom In feature.........Looking at the Bottom view, and the small metal plate that sits on the Processor; you can see Thermal Paste residue left behind......Imprint of Processor is still in the Thermal Paste residue.....(Grayish Thermal Paste residue).......The small metal plate that sits on the graphics chipset, still has a piece of Thermal Pad on it. {Beige(?) in color }..........When the Heatsink's fins get clogged with 'Gunk', and the Fan Assembly's fan, and shroud get clogged; the cooling capacity drops tremendously......('Gunk' = Dirt, dust, lint, carpet deodorizer, hair, food crumbs,...you name it).........The hardware components inside the laptop overheats......When the Processor overheats it turns off..(BIOS turns it off)......This is a fail safe feature that is built-in.....Keeps the Processor from burning up........After repeated overheating, the Thermal Paste dries up........A Thermal Pad is a material that is impregnated with Thermal Paste...So you can see how this equates to it also.........Thermal Paste, and Thermal Pad should be replaced......I also have a upgrade to the cooling system, for the graphics chipset, that I would like to run by you......Involves NOT using a small piece of Thermal Pad anymore, and substituting with a small piece of copper sheet......Thermal Pads are J-U-N-K!....(Cannot be reused anyway).........A piece of copper sheet, the correct amount of thickness; is used. (Around 1/16th of an Inch thick....0625 inches) ....Thermal Paste is applied to the top of the graphics chipset. (PROPERLY)......Then the small piece of copper sheet is applied........Then more Thermal Paste....then the Cooling Tube is set into place.....(Find small piece of copper sheet at Hobby store, for one example).........The width, and length of the copper sheet is larger than the Thermal Pad would be....How big?......Suggest as large as possible, without running into any hardware components, or electronic components, on motherboard....(1-1/4th inches by 1-1/2 inches?....You will know what the proper size is).........More surface area for cooling the graphics chipset........Makes things last longer, and are Not using a Thermal Pad........
    oh i see... i might have to try that, thanks!
  • joecoolvette
    About Thermal Paste; ......The top of a Processor is not perfectly smooth. (Graphics chipset, either).....A maginified view would detail, 'Ridges, Valleys, and Pitholes'........This is the same for the small metal plate of the Cooling Tube, that sits on the Processor. (And the one that sits on the graphics chipset).........When the two parts are mated together, Air Pockets are created......In this case air is an Insulator, and not a Conductor........Thermal Paste fills the above imperfections, and is an Excellent conductor of heat.......On the HP Support main page, click on User guides.......In the list click on -> Compaq Presario CQ56 Notebook PC and HP G56 Notebook PC -Maintenance and Service Guide....Ignore the following if you are aware......This is a PDF file...The computer you are using now has Adobe Reader on it, which uses PDF files.......After you click on the file name, it may take up to 30 seconds before the first page comes up......Moving on.......You need to wear an ESD wrist strap, and have it's alligator clip attached to a good ground source......You can set a large metal serving tray (Unpainted), on the table you're working on; and connect to it........Or a large metal knickknack. (Unpainted)......Average cost is $3 to $6.....Here is but one example........http://www.radioshack.com/product/index.... .........DO NOT use one, and have it's alligator clip attached to a good ground source, you may as well skip the motherboard across the lake.........Your body carries Static electricity...Static WILL fry out (Short Circuit), the delicate hardware components inside a computer....Hence wear an ESD wrist strap........How far do you have to disassemble the laptop?......Down to the motherboard in your hand......The processor, graphics chipset, and Ram Memory; are on the Bottom of the motherboard......General example of motherboard.......Main view shown shows Bottom view......Pink rectangular socket is the processor socket.....It is a Socket P processor socket.....http://en.wikipedia.org/wiki/Socket_P .........The graphics chipset (GPU) is sitting to the Left.......No access cannot be accomplished from the bottom of the laptop.........You have to disassemble from the Top down, remove motherboard..........If you decide to undertake this endeavor, post back in a Comment.......I would like to guide you step by step........Also want you to know, that if you break the Keyboard Cable's motherboard connector, you are looking at MOTHERBOARD REPLACEMENT.....With my guidance this will not happen.....(Large photos, and information on motherboard connector)....Also applies to other motherboard connectors, that a Flat Flex Cable is attached to.....(The Keyboard Cable is an FFC......There are other FFC's used also.......Touchpad Cable is one of them)........Sounds, and may look daunting........I can guide you so it is not.........Regards, joecoolvette
  • joecoolvette
    Hmmm, wHeRe did the motherboard example go?.....(Cyberspace.....the OTHER frontier)......http://www.ebay.com/itm/Compaq-CQ56-6239...
  • joecoolvette
    'Wall'?........Yes, FULLY understand what you mean.......When the solution goes to the Comment section, the expert then is forced to use a 'ticker-tape' type of format......Hence why I use periods to space out the sentences......It also used to be automatic, for a URL that was pasted in the Comment section, to be a direct link.......With new site changes, apparanetly this is not an option anymore........If the laptop model number was listed in the beginning, I could have had the Solution box, and it's format........Spell check,...and proper spacing with paragraphs.......One never knows who they are conversing with on here, so do not know the person's computer knowledge........If it cannot be discerned in the problem stated, then it has to be assumed they have little computer knowledge, in the area if the problem they stated.......Hence why I am so windy.......I could have just stated, "Clean the inside of the laptop out, and replace Thermal Paste, and Thermal Pad...You'll be glad you did......(Lol! Inside joke)........LOT of reading, hard to read......
  • Compaq Master
  • 5,660 Answers
Let's start off with the simple stuff first;
1) Laptop dirty inside?
Post back in a Comment.
Also post the Product Number.
This can be found in the white Service Tag, on the bottom of the laptop. P/N = Product Number.
Regards,
joecoolvette
Posted on Apr 30, 2013
    1) It could be that... I've had this laptop for almost 2 years... P.N. = XU683UA#ABA (I dont know what you meant by comment, so I posted it here too...)
kunaps
  • 6 Answers
SOURCE: Compaq M2000 laptop lighting bolt flash 3 times wont start
Could be a bad mother board or a hard drive..see if you can connect the hard drive with a USB on another machine and run a test on it...
Posted on May 28, 2009
  • 3 Answers
SOURCE: C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Posted on Sep 28, 2009
SOURCE: my laptop presario cq40's monitor is not displaying
my laptop presario cq40's monitor is not displaying anything. but caps lock key and scroll lock is blinking automatically
Posted on Nov 09, 2010
ShatteredSun
  • 40 Answers
SOURCE: my compaq 615 does not
What you are seeing is a "blink code". Similar to something like a digital SOS message, your laptop is built to flash certain LED lights a specific number times to indicate a hardware problem.
According to Compaq's table of blink codes, the Caps Lock LED light blinking five times consecutively means you have a system board failure. If your laptop is still under warranty, I would contact the company immediately and have it shipped out to be serviced. Otherwise, you will need to either pay Compaq or another third-party repair shop to fix or, more likely, replace the system board.
Posted on Mar 01, 2011
  • 1542 Answers
SOURCE: Hello good day,sir My compaq presario cq40..is
Hi
You could try this
switch on power and press either the f5 or f8 key
if this works try to go down to use the last good known configuration
itf that dont fix it
try again to power up and press either the f5 or f8 key
and try to repair
if not try to start up in safe mode and do a system restore back to when it was ok
Posted on Mar 06, 2011
My hp model, hp pavilion rt3290, red wont work power button is on caps lock flashes n thats it
Try this "wrapping the laptop with a fleece blanket" according to this forum it is a known problem with graphics adaptor.
Laptop not booting and CAPS lock blinking
Feb 14, 2015 | HP Computers & Internet
What does it mean when the caps lock light and num lock light flash and the computer beeps?
If your cap lock light blinks on and off, and your machine is beeping at you, it means you are about to shut off for overheating. Clean out your vents, grease your fans, and see what happens. You may have intermittant fan failure, with a fan about to stop functioning, or maybe its not working at all.
May 03, 2012 | Sager Computers & Internet
Caps lock Flashing when trying to boot the system
Take the laptop back, this sounds like a motherboard issue or improper factory install.
Apr 30, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Blinking battery power LED
Battery
Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock
CPU
CPU not functional
Blink: 2 - Caps Lock/Num Lock
BIOS
BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock
Memory
Module error not functional
Blink: 4 - Caps Lock/Num Lock
Graphics
Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock
System board
General system board failure
Blink: 6 - Caps Lock/Num Lock
BIOS
BIOS authentication failure
Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
HP DV6110us: 4 beeps, no boot
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock System board General system board failure
Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
The caps lock is flashing when I power up
While I am not familiar with this model, I would start by turning the laptop over, and gently tapping the bottom, to get any crumbs and other garbage out of the depth of the keyboard. There may be something stuck down at the bottom of the caps lock key which is causing this to happen when you boot up.
Jun 14, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiro 6400 not starting up
If the Num lock is lit constant, and the Caps Lock and Scroll Lock keys are flashing, the system is reporting a memory error. Power off the system, remove the battery, and follow the user manual from support.dell.com to reseat the memory module(s). If the error persists, you may need to replace the memory and/or the system board of the portable.
Mar 12, 2009 | Dell Latitude D600 Notebook
Compaq Presario Notebook Logo
52 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
