Question about Sony VGPSP4 2 Speakers
VGP-SP4 The on and off botton does not work any more, where can I get the circuit board, it looks like its burned.
Cant find the pound sign eventhough it should be on number 3when i push the up botton
Don't press the up button. Hold the "Shift" key while pressing number 3.
Mar 07, 2011 | Sony VAIO VGP-WKB1 Keyboard
I would like to receieve the specs for this unit
Go to below website to see the specification,It is posted on the right hand side of the page
http://reviews.cnet.com/pc-speakers/sony-vaio-vgp-sp4/1707-3179_7-31768268.html
Thank you
Jan 18, 2011 | Sony VGPSP4 2 Speakers
I have a Kurzweil Mark-Pro TWOi. It takes several minutes to turn on, and keeps resetting and clicking while booting up. My guess is a bad capacitor somewhere. I looked at the power board, and it looks...
I don't know what you "tested" the power supply board with, but I would use an oscilloscope to look at the outputs to see if any of the regulators are drooping. Clicking is a broad term... if it is a relay, it PROBABLY is for speaker protection and senses balance of the power amps.
With a two minute delay, this is PROBABLY a thermal issue... Use freeze mist/circuit cooler to find suspicious parts.
Jan 01, 2011 | Kurzweil SP4-7 76 Note Digital Stage...
My preset buttons no longer work.
The buttons are just metal domes glued to a circuit board. After time, pressing the buttons will cause the button strip to shift downward and stop functioning. Open your radio and push the strip back into place.
IIRC, the SP4 has a separate button PCB. That may have just come loose. The connector is just to the left of the power button. Press firmly on that area and see if that helps.
Nov 30, 2010 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
I was Looking at some of the other posts and was wondering if the BATERY CELL 2032 could be the problem to my VGP problem. What is currently happening is any card i plug into my VGP slot, is non responcive...
Changing the battery on the board won't make a difference. It is clear that your "VGP" slot is damaged as there is little chance that all 5 of your test cards are damaged. The onboard video controller functions independently of the "VGP" slot and should not be affected by its failure.
Before you ask, there is absolutely no way to replace the "VGP" slot on the motherboard. You must replace the entire motherboard. If you can find a board with the exact same northbridge and southbridge chipsets you might be able to avoid reinstalling your operating system.
Now, one more thing to clear up. There is no such thing as a VGP slot. You have either an AGP or PCI-E slot.
Please vote for my solution if it helps.
Sep 26, 2010 | ASUS K8S-MX Motherboard
Where can I get peavey replacement parts for sp4 speakers? Need to replace the internal board.
The internal board is the crossover. Your best bet is to contact Peavey directly. Call them up and select the service department. You can purchase parts directly from them. Have both the model (SP4) and serial number. Because the series has been around for a while, there are slight differences in the crossovers (may not be the case for the SP4, bt was for the SP2 series). The serial number will incidate the "run" and insure that you get the proper parts.
Dan
Feb 23, 2010 | Audio Players & Recorders
Light in refrig not working & blue indicator lights out also. Pulled switch & lights still out if I jump the leads. Is there a reset botton.
your motherboard in the lower rear area of the unit is bad,if you have recently replaced burned out lights in the refrige when these lights burn out it causes a surge on this control board and burns the circuit trace,hint:if you hear a rapid clicking noise in this area of the motherboard its a relay trying to latch,a bad board wont let it latch and the lights will dimly flash in the refrige compartment and the digital read-out may be out too
Jan 24, 2010 | Whirlpool GS6SHEXNL Side by Side...
COMBINATION OF PROBLEMS WITH MODEL 25 HOT POINT SIDE BY SIDE. UNPLUGGED IN FREEZER FAN SO REFRIDEGERATION UNIT WORKS AND TOOK OUT ICE/WATER CHUTE LIGHT SO WATER INDOOR DISPENSER WORKS. LOOKED AT CIRCUIT...
i think you answered your problem / sounds like the board. some times you can smell the burn and some boards have clicking sound . / from what you have stated . i would replace board. mm the burn is the price of the board .. mm
Dec 03, 2009 | Dryers
GE profile microwave
Most likely problem is your Smart card has fried.Its located on the removable panel that your display is attached to.If you remove the screws that open this Clock Panel (un plugged from power first) the display panel will swing down and you will see the circuit board I mention (Smart card/control board ).Look for a visible burn on this board.If you see one ,replace the board. Please Rate This !
Aug 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sony VGPSP4 2 Speakers Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
