Question about Goldstar MV-1515 Microwave Oven
What is the manufacturor height clearance from the top of the stove to the bottom of the microwave?
  • Goldstar Master
  • 9,047 Answers
That will be found in your installation instructions.
if you don't have them, post a new help request and include the full model number from the tag in or on the oven so we can help you further.
Posted on May 03, 2013
How low is too low over the range? What is the minimum clearance between range and microhood advantium 120?
from the bottom of your cupboard the minimum is 30 " to the glass on your stove or 2 " above the back panel of the stove heres the instructions on how to assemble the advantium if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in the future here is your link as well http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40590.pdf
Thanks again Rick
Jan 28, 2011 | GE Advantium 120 Convection/Microwave Oven
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
Can you put and over-the-counter microwave over a stove?
Yes, that is what they are made for, As long as it has a vent that can be used to vent the smoke from cooking it can be mounted over the stove. Normally the bottom of the microwave should be mounted 16" to 19" above the stove top. The microwave must have a vent with a blower motor in order to be used above a stove top. Most have a thermal switch that will turn the microwave vent on once the temperature reaches a set point.
Jun 12, 2010 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
How far out does a microhood sit from the cabinet. My cabinets are 12 inches and the microhood I want is 16 deep. Also it will be 19 inches above my stove.
Don't know right off the top of my head, but the installation instructions should tell the min and max height from the stove. If they don't you may want to contact an electrician to find out.
Mar 29, 2010 | Kenmore 62622 Microwave Oven
I have a Roper Microwave mounted over my gas stove
Usually you should have at least 12" - 18" AND a fireproof "Barrier" as the "Roof" of the stove "Floor" of the microwave shelf.
Jan 20, 2010 | Roper MHE14XKB Microwave Oven
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Presently have a regular hood, would like a microhood. How many inches clearance do I need between the top of the stove to the bottom of the cabinet?
This is a good question to ask at the point of sale. The measurement varies for different models and makes, but 33 - 36 inches is ideal. If you have a 12 or 15 inch tall cabinet above the stove, you are fine. A microhood does require a dedicated electrical circuit. When powewring off the current hood circuit, check to see if any other lights or outlets go off.
Jul 07, 2009 | Microwave Ovens
Recommended clearance from bottom of microwave to range top
Your installation manual should have given specific height limitations. I'm not sure for your model, but I beleive it's no less than 22". If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 29, 2009 | Microwave Ovens
Ge spacemaker installed over stove-----need to remove it
Her is a link that I hope with work that shows the bracket and how it was installed.
PDF]
  JVM1850BH/CH/SH/WH – GE Spacemaker Over-the-Range Microwave Oven File Format: PDF/Adobe Acrobat - View as HTML
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Over the stove microwave install space
I would call Sharp at 1-800-SE-SHARP.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 09, 2008 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
57 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
