Question about Microsoft Computers & Internet
Window showing 2 operating system but i have just one install window 7
I Have Just Install Window 7 After Making New Partion Only C Drive Rest Of Other Are Same But It Showing 2 Operting System To Choose I Wana Run Window 7 Only I Want To Delete "Earlier Version Of Window" option In Such A Way That I Can Also Use Safe Mode
  • 826 Answers
For this you have to completely format the system and then install the win 7 on it. And then you can also use the safe mode afterwards.
** You can also avail our technical support by visiting our website: http://www.vtechsquad.com.
Posted on May 01, 2013
raja_ranidad
  • 6 Answers
SOURCE: How to Create multi-boot ( multi operating system ) dvd.
i use nero 6 but am willing to try other software if it'll work...
Posted on Jan 22, 2009
skatz
  • 47 Answers
SOURCE: accont losted
we have one type of method to solve this problem. but, not regularly.
if you have any other administrator account, you can log in to this and work with your account.
or
if you did not enter any administrator authentication(password), when the windows xp was installed, you can easily manage this.
press CTRL + ALT + DEL keys simultaneously (two times) and type the username as "administrator". then enter without giving a password.
or
you can connect your hard disk with any other hard disk. boot through the other hard disk. then you will see your disk drives on the another disk. Try to delete the "SAM" file on your os (C:\windows\system32\). (Only on your hard disk).
then reboot via your hard disk. now, you have no need to enter any username or password. just enter and go to the windows desktop
if it is not possible for you, just go for password recovery software
thank you,
Posted on Feb 13, 2009
proartya8765
  • 581 Answers
SOURCE: Running Windows 7. A windows Critical Update auto
it more than likely has little to do with the operating system. It sounds like a hard drive problem. Are you able to format the harddrive and reinstall?
Posted on Jan 30, 2010
prerit_777
  • 214 Answers
SOURCE: How do I install My CDMA 1X on Windows 7
download.com
Posted on Aug 02, 2010
earllan
  • 26 Answers
SOURCE: I just got a new
maybe your DVD-RW have a problem to reading your CD.
Posted on Apr 13, 2011
Tip
Install Unsigned Drivers on Windows 7 & Vista with Driver Signature Enforcement...
Every time when we try to install any hardware drivers which are not signed by microsoft, Windows shows a warning of Unsigned driver dialog box. The reason of showing warning message is to protect the stability of your Windows operating system as such drivers are not passed in Microsoft windows driver compatibility test.
In Window XP you can still install unsigned drivers but in Windows Vista SP 1 and Windows 7 Microsoft has introduced very restricted module of driver signature enforcement which doesn’t allow us to install any incompatible unsigned drivers.
If you want to bypass or disable Unsigned Driver warning message then Here is small freeware utility Driver Signature Enforcement Overrider which allows you to install and load unsigned drivers dynamically on your Windows 7 and Vista.
Supported Operating System
1. Windows Vista 32-bit & 64 bit
2. Windows 7 32-bit & 64-bit
Download Drive Signature Enforcement Overrider 1.3b
Please Note: User Account Control (UAC) must be disabled in-order to use this tool.
on Jan 10, 2010 | Computers & Internet
How to convert window 7 to window xp?
Sorry for this answer but you cannot convert back Windows. You only are able to Upgrade but you can't rollback.
You have to backup all of your files on your system drive and then reboot your machine while you are inserted the Windows XP CD into your drive.
Boot with it and Format your system drive and then install Windows XP on that drive. But if you want to keep your 7, you can Install XP on a different drive and then by using Vista BootPro program, repair your boot because Vista and 7 are using a new version of boot manager and XP uses the older one.
Feb 26, 2011 | Microsoft Windows XP Professional With...
Can not install win 7 on a new clean formatted partion.
Hi
You can install in new formated partition only when you are in Window set up mode. By deleting all partition and create new partition. It you make like this.
The operating system installer CD is damaged or corrupted. Just new installer CD.
Regards
Feb 17, 2011 | Acer Computers & Internet
Rhow to install window 7 with a cd rom give me steps
put your Win. 7 DVD in Rom Drive then restart your system -- when your screen shows the options to press F2 then press it then go to boot settings then put your rom drive to 1st boot device and hard drive as 2n boot device -- then press F10 and ENTER. then your system will restarted. then after few seconds your displays shows that "Press any key to boot from CD/DVD...." then press any key to go to setup then follow the steps and install Windows 7 and enjoy it.
Feb 11, 2011 | Microsoft Windows 7 Home Premium 64BIT...
How to install Windows XP on Acer Apire 4740 with Windows 7 ultimate
Install the XP CD on your optical drive and do a restart it should then beging to ask you if you wish to install XP, make sure that when you reach the prompt to install that you delete partion which you have VIsta, Win 7 then create a partion it will be clearly marked and then install your new / older OS XP.
Aug 21, 2010 | Computers & Internet
When I install Rockstar midnight 2 in my pc.it shows the error of crc . I am using the windows 7 in my computer
with this type of problem the best way to solve it is to reformat the operating system and re-install a new operating system window 7, or better still change the operating system to another version like Window Vista or Window Xp service pack 2.
Apr 25, 2010 | Intel Computers: P4 3.0GHz Mid Tower...
I want to system format but now it hang on verifining pool data and tdlmr missing pls tell me about it
insert your windows cd in drive and restart computer and now your cd will be boot press enter and cd boot now window will install startup files wait until install files,after installing file follow your screen intruction intruction press esc to dont repair window and disk format option will appear format your drive partion to choose fat or ntfs format.
Dec 17, 2008 | Microsoft Windows XP Professional With...
Installing Windows XP alongside Vista
First you want to install xp and then only you want install vista because higher version will not take lower version.
Feb 26, 2008 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
