I need the schematic for QSC RMX2450 - Audio Players & Recorders
  • Audio Player... Master
  • 6,694 Answers
HI,
if you can provide your email address the i will sent you the schematic diagram . Its not possible to upload PDF files here.
Ajin
Posted on May 02, 2013
Qsc k12 schematic
Tengo el mismo problema, ella suena pero al subir la potencia se apaga, supongo es una soldarura mala, si es asi por favor especificame adonde y si es otra causa favor indicar.
Agradecido de ante mano!
May 10, 2013 | QSC K12 Speaker PA Active
Qsc hpr153i rattle
Please specify a bit more, does the rattle is physical(Enclosure structure) or electronically hear thru speaker(Power Amp Common Issue)? I have the solution for the amp issue, let me know.
Mar 20, 2013 | QSC Audio Products QSC HPR153I 12 SPEAKER
Qsc hpr181i blow fuse
Two possibilities here, one is a cracked pin on one of the power supply UF diodes and the other one that the power output devices got fried.
Jan 30, 2013 | QSC Audio Products QSC HPR 181i
What kind a outputs transistor use a QSC Gx3 power Amp
this power amp uses 2SA1962 and 2SC5242 output transistors. You can download the schematic diagram from this website.
Thanks.
gylacz
May 10, 2012 | QSC GX3 Amplifier
My QSC PLX 2502 amp completely blew. Channel 1 has been giving me problems for a year and I have had the amp about 3 years. This past week it drove into the red so much and I could not stop it. Well now...
You should NOT drive the amplifier into the clipping mode continuously. There is a possibility that you have fried your speakers or that they are the real problem. You haven't told us what you were driving, however this amp will deliver 450 Watts per side RMS at 8 ohms which means your speakers have to be rated at least that much RMS power for continuous. When speaker voice coils fry, they can wipe out amplifiers. Let us know what speakers you are using and how they are configured. This amp is going to be expensive to repair I can tell by looking at the schematic: Here is the schematic:
http://elektrotanya.com/qsc_plx2502.pdf/download.html
Scroll down to "get manual" and click to download it. IGNORE other download links.
This amp has circuits to boost the power supplies to the amps to handle the peaks. It is rather complex but the schematics are complete and have good explanations... some of the best I have seen. There are going to be a lot of destroyed components and great care has to be used after repair to "cold start" the unit to make sure nothing else is bad or it will blow up again. Most people do NOT have trouble with the QSC amps... so do tell me what speakers you are using and how they are configured so we can verify the design is correct. This amp is rated for 8 ohms so USUALLY only ONE speaker can be connected per side... and finding an 8 ohm speaker that can take 450 watts continuous RMS isn't easy. People fall for the advertising claiming "Peak" and "Program" power which are FAKE advertising... ONLY use continuous RMS power when sizing amps and speakers. There are MANY ways to cook out equipment... One is to boost the bass or the treble way up. Another is to NOT use balanced interconnect lines between mixers and your amps. Yet another is to NOT power ALL interconnected equipment from a single receptacle or power conditioning module. Please describe your setup further so I can help you more!
Sep 20, 2011 | Qsc Plx-2502 450w Per-Ch. 8 Ohms Amplifr...
How do I bridge my QSC GX 3 amp to run one speaker cabinet?
For QSC amps the GX series are not bridgeable. You will have to run one speaker to each channel.
Mar 22, 2011 | QSC GX3 Amplifier
Have a blown capacitor in a QSC PLX 3602. It's the large black capacitor near the on/off switch. Can't read the letters and numbers. What is this capacitor? Thank you.
I need a board marking number as there may be several caps near the on/off switch.
Example:
C117 .47mfd 250VAC (use 600VDC)
C126 .1mfd 250VAC (use 600VDC)
C132,133,136,137,140,141, All 2200mfd 200VDC (These are large canned units)
Note if one of the latter ones, better check the full wave rectifier bridge for a bad diode as well.
I have the schematic but not an assembly drawing so description of near switch doesn't tell me enough.
Oct 29, 2010 | QSC PLX3602
Behringer EP2500 Clip light Channel 2 stays on & heatsink HOT!
There are so many components that can fail that troubleshooting this can be an expensive problem.
HINT: Put a 150 Watt light bulb in series with the power going into to limit current for/during troubleshooting.
Go through and compare the voltages on the teo channels. If power amp transistors have failed, likely the driver transistors also are gone.
Testing components in-circuit is very dificult. Resistors are pretty reliable and usually show damage by discoloration.
Furhter use before repairing MAY cause further damage.
Jun 03, 2010 | Behringer EUROPOWER EP2500 Amplifier
Soon as i turn on my QSC RMX2450 the clip light comes on for Ch 2
Sounds like an output going bad. Try to get some electronic contact cleaner and spraying on the circuit board. If its corroded this will help clean the circuit..
Sep 07, 2009 | QSC RMX-2450 Car Audio Amplifier
44 people viewed this question
 Grubhead
Grubhead
