Question about Sharp Aquos Televison & Video
Sharp aquos service menu - Aquos Sharp Televison & Video
    Top Expert:
  • Sharp Master
  • 74,118 Answers
If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2380 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.
http://electronicshelponline.blogspot.com/ Check this site. Service mode menu entry method to many brand TVs, including Sharp are given in detail.
Posted on Apr 30, 2013
Testimonial: "Hi Gopakumarg43, thanks for your solution, the procedure detailed on that site is the procedure i've been attemping, to no avail. :( "
SHARP LC 46XD1E LCD TV
the service menu can only be accessed with a "service remote" only available to certified Sharp service techs... special training and $350 required to become one... contact sharp for more info or find a repair man locally if you dont want to become one yourself... the training is a lecture
Jul 04, 2012 | Sharp Aquos LC46XD1E 46 in. HD-Ready LCD...
Sharp aquos 42 inch lcd, too much red thro certain areas in the picture that should be dark. I have heard it needs eeprom reset how would i do this please, if anybody could help xx
Contact Sharp to see if it can be a "reset" issue and to see if this is a known problem in this model----more likely than reset would be a possible software upgrade but it depends on what actual issue is---maybe a bad board somewhere in the set.
Mar 25, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The demo mode apears every 30 minutes. I can't really stand it. How can I shut it doen for ever? Sharp aquos LED 40"
I'm not certain of the specific model number of your set, but this should be the same for all Sharp Aquos models.
First, navigate to TV input, and select menu
Next, enter setup and select, "ez setup"
In the ez setup menu, select "home", not "store", for television location.
This should turn off the demo mode and solve your issue.
Jun 10, 2011 | Sharp AQUOS LC-40C32U 32 in. LCD TV
How do I stop the CC on my Sharp Aquos
Sharp Aquos LC-37G4U
Try the remote.
On the remote is a button labeled CC near the bottom.
Press the button to access a menu to switch off. Each time you press the button it will toggle among the choices.
If the tv has problems, try turning it off and unplugging for a few minutes to reset the EPROMs.
Plug in and turn on. Repeat the above.
If you want to change the size/color of the font you can get into menu mode by pressing the menu botton in the center of remote.
Next use the and > arrows to get to OPTION menu.
Use the ^ and v arrows to get to the Caption Setup menu and press Enter.
Feb 22, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp AQUOS 65" LCD, No Picture Menu Access
change picture mode from (STANDARD)or other modes and put tv in CUSTOM then you will be able to change the contrast
make sure all cables are in
Dec 15, 2009 | Sharp Aquos LC65E77UM 65 in. LCD HDTV
No picture from cable box to tv
If you get on screen menues using the Sharp Remote then you have a main board that is defective. If you just bought it new you are in luck as the warrenty on that unit is a lease 1 year parts and 1 year labor. Contact Sharp Customer Service and should be able to refur a Sharp Auth. Repair facility to get you taken care of. In the mean time, If you got on screen menues then you can go to any one of the other video inputs and see if you get a picture.
If you DO NOT get onscreen menues with the Sharp remote then you are out of luck until a service repair facility looks at it.
Hope this helps,
Skyassoc
Jun 19, 2009 | Sharp Aquos LC-32D40U Television
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I lose the sound on my 1 year old SHARP aquos Lc-42D62U tv??
There is a fix for this. Call a Sharp servicer or Sharp electronics the cost of repair is around 200.00 dollars.
Apr 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a sharp aquos 52" with a thin vertical red line in center
If you have a thin line running down the screen, you may be looking at a service issue right off of the bat. Here is a few things I want you to try before calling sharp, 1. Reset the unit from the setup menu
2. Unplug the unit for 2 minutes then plug back in. If that does not work. Take digital pictures of the line and call sharp immediately. Make sure you tell the rep you want to sign up for the aquos advantage program that they have(extends your warranty 3 months free of charge!) because that will get you priority service on with your issue. If they cant resolve that line ,9 times out of 10 they will replace the unit. hope this helps you
Feb 15, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Sharp Aquos 46" LCD
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in.
Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Mar 14, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
153 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
