Question about Maytag M6Q10F2A Air Conditioner
Hot air the AC continues to blow, but its just hot air.
  • 40 Answers
Compressor isn't running. You're only getting the inside fan.
Posted on Jun 20, 2008
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 02, 2016 | Heating & Cooling
I have a 2002 pt cruiser that is blowing the ac 10amp fuse repeatedly. I mean within minutes of changing it. Also the ac is only blowing hot air. Can someone please help.
An AC system blowing hot air is usually due to a low freon charge or a non operational AC compressor. If the fuse blows, disconnect the compressor electrical plug and turn on the AC. If the fuse doesn't blow, suspect a compressor problem. If the fuse continues to blow with the compressor disconnected, there is a direct short between the ON/OFF switch and the compressor which can take hours to diagnose
Sep 07, 2015 | AC Cars & Trucks
Ac
You would need to find out if the compressor continues to run when the cold air stops.
Jul 17, 2013 | 2000 GMC Sierra
2004 Honda Pilot hot & cold
Sounds like a blend door problem under the dash.
Jun 25, 2013 | Cars & Trucks
Air conditioner blows the fuse
SOUNDS LIKE YOU HAVE A SHORT IN THE WIRING BETWEEN THE FUSE AND THE AC PANEL, USE A CONTINUITY TESTER TO CHECK FOR CONTINUITY , IF THAT FAILS OR IS OK THEN CHECK ALL RELATED RELAYS IT MAY JUST BE THAT YOUR AC NEEDS RE GASSING?
Sep 02, 2012 | 1997 Land Rover Discovery
Ac on 96 grand marquis continues to blow hot air with new compressor and freon?
The first question is do you know if the ac compressor is running ?
If one ac line is hot and the other is cold you may have a blend door problem under the dash.
Jul 01, 2012 | 1996 Mercury Grand Marquis
My 2002 Expedition air conditioner will sometimes blow hot air and others cold air
I would check the following possibilities:
1. Is compressor clutch working? - You need to do this when the ac is blowing hot air only - locate compressor drive pulley on engine - rubber belt wraps around it. Start engine and set to max ac. When the ac is blowing hot air, look at the center of the compressor drive pulley using a good flash light - watch it for a while, it should be spinning with the pulley - this means the compressor is engaged. If not, the compressor is not engaged. If your ac is blowing hot air, then the compressor should be engaged and running (trying to cool). If it is not engaged, then your compressor clutch is probably going out. Could be low voltage to clutch, but more likely the clutch is worn out and only working some of the time. Note: if working normally, the compressor clutch will engage and disengage in cycles- but the air should always be cold. If clutch is bad, compressor would need to be replaced (sold as one unit). This is tricky to diagnose and could take some time - you need to do it when ac is blowing hot air but set to max cooling.
2. Low on refrigerant or refrigerant has moisture in it? If your ac blows cold initially after being off for a while, then heats up, and continues to regularly cycle back and forth between hot and cool air, then the system may be low on refrigerant or the refrigerant may have moisture in it that is freezing and restricting refrigerant flow. An a/c shop can check refrigerant level and even replace refrigerant if moisture is suspected.
Could be other issues, but I would start with these.
Good luck
May 07, 2010 | 1999 Ford Expedition
Air conditioner blows hot air inadvertantly.
possibl ac compressor clutch problem,cooling fan at rad not working so ac goes into high press mode and turns off(so it doesn,t blow system apart,built in safety)not enough r134 in system(low charge)
Sep 19, 2009 | 1997 Chrysler Concorde
Drivers side AC will blow hot air.
the blend motor on the vehicle is probably bad
Aug 20, 2009 | 2003 Chevrolet Silverado 2500HD
Maytag M6Q10F2A Air Conditioner Logo
70 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
