Question about GE Spacemaker 75300 Shelf System
Antenna How do I attached an attena?
HOW TO HOOK UP HDTV ATTENA TO DAYTEK 426F SO IT WILL ACCEPT CHANNELS
If your Daytek TV is equipped with a digital tuner, connect your HDTV antenna to the antenna input of the TV.
Feb 05, 2015 | Televison & Video
Every time i key the mic up it says attena failure
where do you have it mounted? you may have to provide a ground for it .Maybe its your antenna , get a better one , like a wilson or one of them K-40's . could be the radio itself.Take it to a tech ,on the vehicle you intend to use it on and have them check it out.
Jan 16, 2013 | Radio Communications
I need instruction on how to remove a broken antenna base from a 97 chev suburban. There are two mounting screws on the inside of the fender and it doesn't look like there's any way to pull the antenna...
remove the 2 screws and access hole cover, the attena comes out of the fender access cover hole. make sure u undo the lock nut at base of attenna and i hope you have small hands lol
Jan 05, 2011 | 1997 Chevrolet Suburban
Do i need a converter box or attena for this tv??
U require a good antenna no need for a converter box,because this tv is digital tv.
Nov 08, 2010 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Where can i get a replacement antenna for my ge portable super radio? also, how about info on installation.bthanks,norm.
Radio shack has replacment attennas. There is a scew in the back of the radio below the attenna. Loosen it. the lower part of this and the attenna will come out. at the top of the base part is a screw where the attenna bends back and forth. remove this screw and take off the top of the attenna (the telescoping part of the attena) get a replacment attenna thiis length (of top part). The bottom of new attena will have a screw toward the base where it bends back and forth. Take this screw out and replace the new attenna base with the old attenna base (the new attenna base won't fit in the radio correctly) Now insert the fixed attenna back in t he super radio and tighten the screw on back of radio. Hope this helps.
Feb 26, 2010 | Audio Players & Recorders
Transmitting problem on motorcycle
  • Make sure you run the CB directly to the battery. What you are hearing is the alternator whining. Even then sometimes a low pass filter may be necessary. Make sure the chassis of your CB is grounded with a copper braid strap too.
  • Hope this helps.
Apr 27, 2009 | Midland 75-822 40-Channels Handheld CB...
I don't know if i want to buy the attena for my tomtom one. can someone explain to me the benifits of having one?
only really needed if you have a shielded windscreen ,ie heated or uv blocker or if you are a techno that has to pin point there location,there are better attena on the market for same price.
Mar 27, 2009 | Tomtom (9N00.000) Antenna
My radio attena will no extend and their is no sound.but it is turned on
After some time the antenna gets so dirty that it cannot work properly. It is usually possible to assist the extension motor by pulling gently on the antenna when someone turns the radio on. Once extended give the mast a good cleaning and you should be back up and running.
Mar 16, 2009 | 1987 Chrysler Conquest
Plasma TV Reception
Bro the reception in that area of the house must be poor, as you've said. The walls in that area of the house must be too thick, or some part of the house is blocking the signal that the attena emits. You should consider getting an antenna that can be placed outside the house, like on the roof top. Make sure it isn't being blocked by anything, like trees with large branches or whatever.
Jul 21, 2008 | Televison & Video
GE Spacemaker 75300 Shelf System Logo
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jonathon summesfield
Carlos L. Burgos
Carlos L. Burgos
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
