Question about IBM 6262 Printer
IBM 6262 THERMAL CHECK 0410
Thermal check error code 0410
tonyy168
  • 45 Answers
SOURCE: Thermal sensor error
Chcek www.thinkpad.com for a service manual.
Posted on Sep 15, 2009
hawk127311
  • 350 Answers
SOURCE: thermal sensing eror ibm r40
Sorry to say, unless you are a hands on kind of person and can fix it yourself, the thermal sensor is malfunctioning and the only fix is to have it repaired by an authorized dealer.*********** board and CPU have these installed in certain spots to monitor temperatures. I hope this helps and good luck!
Posted on Nov 04, 2009
SOURCE: Thermal Sensing error
"Thermal sensor error" just means "Broken fan".
Posted on Mar 10, 2010
caroldon
  • 17129 Answers
SOURCE: IBM R51 laptop when start the laptop it canot boot
Possible that the cooling fans to the Processor is clogged and so there is heating on the processor going beyond the set limit thereby triggering the thermister to warn and shut down.
This normally happens when the laptop is make work on dusty surroundings/ tops or matresses which can pull up fibres to clog the vent.
remove the fan assembly and clean the section using a air jet and brush , then reset.
Posted on Jul 05, 2011
  • 910 Answers
SOURCE: Getting an error message on
Sorry if this is a little vague but this is all I've been able to find in the 30 minutes we get to review a problem.
K102 is a control relay and the error indicates it's faulty.
The only place I've found that may be able to supply a replacement is at the link below although I suspect this would be a job for a printer engineer.
http://www.theprinterplace.net/cgi-bin/fccgi.exe?w3exec=TowerApp&FormName=PartSearch&PartNumbers=062H2734
I'll keep looking to see if I can find any further reference to this relay or a service manual showing its location.
p.s. Model No. is 6262-D22
Posted on Aug 10, 2011
Printer not printing first 3 left characters
There are 2 kinds of 6262 that have vastly different hammer asm, but most likely you have a hammer issue. If it is a 12 or 14 you would need
IBM 5665720 HAMMER COIL 6262 Refurbished
It can also be a cable or card, but those normally have errors reported.
PS I don't know why the wrong pick is coming up for that part on fixya, but the site has no pic as the part is super old.
Nov 04, 2015 | IBM 6262 Printer
Ibm Z60t getting thermal sensing error while
Thermal damage? Check the fan and radiator are clean.
Oct 11, 2014 | Computers & Internet
What causes a thermal sensing erro on ibm t43
A Thermal error on the T43 usually indicates a problem with overheating. This can be caused by many reasons:
1. Dirt build up on fan or fan louvres causing fan to turn slowly and not being able to cool the system properly.
2. Blocking of air inlets to the laptop. Do not use on your lap, or on soft surfaces such as blankets, bedsheets, etc.
If you feel a lot of heat from the air out of the laptop, then the system is over heating.
You can run fan diagnostics as follows:
1. Turn on the computer and check the air turbulence at the louver near the PC Card slot.
2. Run Diagnostics --> ThinkPad Devices
--> Fan.
Here is the T43 maintenance manual to see how to check and or replace the fan.
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t6193.pdf
May 08, 2014 | IBM ThinkPad T43 Notebook
How do i solve thermal sensing erro on ibm t43
See my answer here:
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=8&fml=0&brd=228&p=2&thid=24357750
May 08, 2014 | IBM ThinkPad R30 2656 Notebook
Error code e66
Hello wez1330 - Error code E66 indicates that the thermal limiter circuit is open. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the inlet or outlet thermal limiter for continuity. If the thermal limiter is open, tech will need to check for evidence of high temperature event and any resulting damage. If no futher damage is evident, the thermal limited and retest will need to be replaced.
Sep 29, 2012 | Electrolux Frigidaire Affinity 5.8 cu. ft....
Error Code E65 on Frigidaire Front Loader Model #LTF2940ESO
Thermostat issue - need a professional to complete the following:
For electric model, check inlet thermal limiter for continuity. If thermal limiter is open, check for evidence of high temperature event and any resulting damage. If no further damage is evident, replace thermal limiter. If no problems are found with the thermal limiter, check exhaust vent system for air blockages. If no problems with vent restrictions, check/replace high limit thermostat, and retest.
Aug 15, 2012 | Frigidaire Washing Machines
Have an error: security PAL not detected on a IBM 4400 printer
How do I fix a FPGA error on a 4400 thermal printer?
Dec 16, 2010 | IBM 4400 Thermal Printer
IBM R52 1860-A36 Giving thermal sensor error
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one.
Sep 28, 2010 | IBM ThinkPad R40 2681
Sep 15, 2009 | IBM ThinkPad R40 2681
Jan 11, 2009 | IBM ThinkPad R40 2681
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
