Question about GE JGBC20 Gas Kitchen Range
GE GAS RANGE OVEN PROBLEM
I am still having a problem with my oven. When I turn the oven on the spark ignitor light up the "pilot light" but the main burner/bar doesn't get inflammed and the spark ignitor keeps sparking for ever. Can you help me???? Please
  • 2 more comments
  • pierre larue Aug 09, 2007
    Update . it looks like the main burner does come on after all. I had to wait 20-30 second like most people said on this forum. I didn't know that it would take that long. The sparking still goes forever though. So everything works but the oven spark ignitor keeps firing.
    Philippe
  • MPL1967 Dec 31, 2007
    My main burner/bar gets inflammed but the spark ignitor keeps sparking for ever. Does the ignitor need to be replaced? Reset? It is an old Kenmore Stove with a dual gas burner, single ignitor arrangement.
    Thanks.
    MPL
  • Anonymous Mar 19, 2014
    Whirlpool gas range sf367peyn1 oven burner won't come on
  • Anonymous Mar 24, 2014
    ultraline professional gas range, the ignitors are not sparking, the stove is plugged in. is this a fuse issue or an ignitor replacement issue. can lite the burner with a lighter
Thank you for replying. I tried to sand the probe, but it didn't work. The sparking keeps going. Now you are saying to heat up the probe with a torch, but the pilot is heating the probe already isn't it enough to see if the termocouple works? Now what has the main burner to do with the sparking and pilot light? The pilot is on why doesn't the main burner comes on? In theory could I light the main burner inside the oven with a match? Thank you
Posted on Aug 08, 2007
  • 640 Answers
Two options.first does the pilot flame look good (a nice blue flame)?if so you will see a metal probe next to the pilot,use some sandpaper and clean that probe up.if that solves your problem so be it.second if the first thing doesnt work its probably the ignitor board not sensing the flame.the way to definitly tell the one or the other use a small torch and heat up the probe like i said and turn the oven on.if the main burner comes on then you know its the probe which is called a thermocouple and is cheap.hope this helps.
  • anthony james
    anthony james Aug 09, 2007
    that probe senses a millivolt back to the ignitor board to tell it is lit,then the board will send the voltage to the main coil on the gas valve and light the burner.if your getting voltage to the gas valve coil and the burner doesnt light then the gas valve is bad,but if you dont have any voltage to the valve the board is probably bad.it is possible that the t-couple is weak and the way to be sure is if the pilot stays lit when you turn on the thermostat for the oven if the pilot goes out its definitly the thermocouple if not its the board let me know.
  • anthony james
    anthony james Aug 10, 2007
    it still could be the board not sensing the pilot but it still fires the burner.the other problem could be the switch or wire is broken or loose and its grounding out on the chasis.take the ignitor wire off of the ignitor and suspend it in the air so it doesnt make a ground,if you still hear a spark noise try to find the arc in the wire.
SOURCE:
Hotpoint gas stove. burners work, oven and broiler do not.
Probably the safety valve. This unit broils and bakes off the same gas burner. A spark ignitor lights the pilot and this save gas because no standing pilot is needed. It takes a few minutes for the thermocouple bimetal combo to release the gas. When the temp gets to the desired rate then the bulb on the oven control closes off the flow of gas. To recap: The flow of gas comes from a regulator along a rail which supplys the gas to the top burners and the oven control. older models had pilot light tubing going down to the oven and to the top burners. This newer style uses a spark module to light off the top burners and the oven. So when yall turn the the oven on the spark ignitor lights the pilot first and then after the mercury bulf thermocouple heats up the bimetal inside the valve opens allowing gas to flow out to the pilot and ignite the gas burner. the temp rises and the mercury bulb oven control expands closing off the flow but not the gas safety valve. I would suspect the safety valve on this one.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 09, 2011 | Hotpoint RGB528 Gas Kitchen Range
The oven won't heat. Can I relight something?
does your oven have a pilot light or an ignitor (pilotless)? If it has an ignitor, it probably needs replacing. I can't help you if it does have a pilot light. Do you hear clicking when you turn your burners on, if yes, that means you have an ignitor system.
Oct 14, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
    Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
    If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
    There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
    Making Observations
    The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
    Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Getting to the Pilot
    Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
    Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Gas oven wont turn on
    Replace the oven glow bar ignitor.
    Feb 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE STOVE MODEL JGBS15GE
    Often times you will have problems with the gas thermostat and not necessarily with the safety valve. Once you have lit the pilot light, turn the oven knob to any temperature. The pilot light should get bigger in size of flame. If not, the thermostat that controls the oven must be replaced. If the pilot light does get bigger, but the stove does not ignite, it is the safety valve.
    Nov 12, 2007 | GE JGBS07PEAWW Gas Kitchen Range
    clean out your burners and make sure that you check all connections to the burner assenbly light a match next to the burner and see if it will light BE CAREFUL that there is no leak and there is no "hanging" gas in the area just be safe :)
    Aug 08, 2007 | GE JGBC20 Gas Kitchen Range
    Any idea about my GE oven problem?
    but any chance did you acidentally flip the little lever that will shut the gas off the the oven burner? sometimes its in the back neor near the regulator. check that.
    GE Spectra XL44
    Sister, there is no pilot light on this model. Sounds like you have a bad ignitor, however the F7 code shows as a bad touch pad membrane. d7 must represent how many times this fault occured, although Im not finding anything that shows a d7 code. Try resetting the board by killing power to the range for about a minute. After turning the power back on press the COOKING TIME, DELAY START AND NUMBER 8 PADS ALL TOGETHER. The words test should be displayed. Now you are going to energize the bake circuit; press the bake and start, you should hear a click, this is the bake relay on the board. By holding the start button in you are energizing the ignitor (glow bar) in the oven. If you do not hear the click, suspect the control board. If you do hear the click and the ignitor is not glowing, you have a bad ignitor. Have someone with you to verify the ignitor is glowing when you are holding the start button in. To exit the test, just push CLEAR/OFF key pad. Catriver...post back
    Oct 23, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE JGBC20 Gas Kitchen Range Logo
    450 people viewed this question
    Top Kitchen Ranges Experts
    Ismael Rodriguez...
    Steve Allison
    Steve Allison
    Archie Ferrarini
    Archie Ferrarini
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
