Question about Alpine Car Audio & Video
Equalizer power supply - Alpine Car Audio & Video
Problem with amplifier equalizer HITRON
You would be better off replacing the unit
May 22, 2013 | Computers & Internet
Power supply men ded FBQ 6200 9-0-9 ya 12-0-12
what is the problem the power supply is broken? if so go to your local music shop and buy a new power supply there usually universal
May 08, 2011 | Behringer Fbq6200 Ultragraph Pro Equalizer...
I am experiencing a humming/buzzing sound which seems to improve when eq is in bypass mode.
Ensure that the power supply is clean and that the source audio cables are not touching or crossing power cables.
Jan 17, 2011 | AudioControl RIALTO Home Equalizer
Please could you tell me what power you need to run the oven
As a rule of thumb, mutliply the total power consumed by the appliance, (see manufacturers label) by 1.5. That means a 1kW oven requires a 1.5kW supply.
Power in Watts = Voltage X Current (Ohms Law).
Current therefore is equal to Power divided by the Voltage.
In the UK that would be:
1500Watts divided by 240Volts equals approximately 6Amperes.
In the States it would be:
1500Watts divided by 110Volts equals approximately 14Amperes so much fatter cable will be required!
Hope that answers your question.
Nov 07, 2010 | Microwave Ovens
I connect it to the power supply but it doesn't on .How to fix this ?
If the power connections wer correct and your ground was also done well the set must power on. Also check if the standby power was also connected to the switched output from the head unit.
if all these are fine then you might need to take the set out remove and check for the internal fuse or failure of some component in the power supply front end.
Sep 14, 2010 | DHD NTX-6201 Car Equalizer
I get power light but no sound. does the sub remote have to be connected in order to get sound out of this unit
There are two positive supplie's on this unit's, one is directly wired to the Batteries poisitive terminal, one for remote which is connected to your ignition positive supply.
Yes you need to connect this one to any switch positive supply
Jun 09, 2010 | Audiopipe XV3 Car Equalizer
I need a hook up digram fof an optimus model 31-2025 stereo equalizer
http://support.radioshack.com/support_audio/doc48/48943.htm
Ten-Band Stereo Frequency
Equalizer (310-2025) Connections Faxback Doc. # 48943
Follow these steps to connect the equalizer to your audio system.
CAUTIONS: Use only shielded audio cable with RCA-type connectors (not
supplied). This type of cable is available at your local
RadioShack store.
Before you connect the equalizer, turn off all components in
your audio system and unplug their power cords.
Before you plug in the equalizer's power cord, complete all
connections and be sure the equalizer's POWER button is out.
1. To connect the equalizer to your receiver, connect the receiver's TAPE
OUT jacks to the equalizer's MAIN IN jacks.
Then, connect the equalizer's MAIN OUT jacks to your receiver's TAPE
IN or TAPE MONITOR jacks.
2. You can connect a tape deck to each set of tape jacks (TAPE 1 and TAPE
2) on the back of the equalizer.
To connect each tape deck, connect the equalizer's TAPE OUT jacks to
the tape deck's in jacks. Then, connect the tape deck's out jacks to
the equalizer's TAPE IN jacks.
3. Plug the equalizer's power cord into your receiver's switched power
outlet or any standard AC outlet.
WARNING: The equalizer's power cord has a polarized plug. To prevent
electric shock, do not use an extension cord or other
receptacle unless you can fully and easily insert the plug's
blades.
4. Connect the power cords of all other components.
(wr 08/04/98)
Feb 24, 2010 | Audio Players & Recorders
What is the 6 pin
You can replace the power supply in this Dell with a normal ATX power supply. Make sure the total wattage is equal to or greater than the old power supply.
Oct 02, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Need a schematic for achme power supply model am630bs20s
Do NOT open a power supply!!!! Proceed with caution: When finding a new power supply, make sure the voltage is the same and the amperage is less than or equal to the original power supply.
Sep 28, 2009 | Shuttle SS51G XPC Mini PC System (MSS51G)...
Power Source/Supply
Confirm the wattage(how many watts e.g 150W) needed by your system from your manual.Make sure the wattage of power supply you are buying exceeds it or is equal.
Jul 15, 2008 | Computers & Internet
Car Audio & Video Logo
54 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
