Question about Pioneer PD-M426 6-Disc CD Changer
How do i adjust the volume??
The volume is too high for our "on hold" customers We need to adjust it.
Tracfone customer service
  1. Check a ringer volume and profile. Press a volume key to see the volume status bar at the top of the screen. Use the volume up and volume down keys to adjust the loudness of the ringer (scale 0 to 30). Tap on the text next to the ringer icon to change the profile (vibrate only, ring+vibrate).
  2. Check if the issue is with a specific ringtone: Go to Settings > ringtones+sounds > Ringtone, and tap on a playbutton to preview the ringtone.
  3. Switch off the ringer vibration (Settings > ringtones+sound > vibrate) temporary, to determine if your phone is affected by any motion settings i.e. Flip-to-Silence.
  4. Make sure that call forwarding is not switched on: Tap the phone icon > ... > Settings.
If the problem persists, restart your phone by pressing and holding the power and volume down keys simultaneously until the phone vibrates. Release and the phone will restart. After this operation, you may need to re-adjust the volume and set date+time on the phone. Note that this does not remove your personal content.
Mar 13, 2014 | Computers & Internet
My volume is stuck on high. How do I fix this?
Open the Control Panel, Sound, adjust volume, OR Click on the Sound Icon in the Tray Notification Area, adjust sound. OR reboot the machine.
Jan 07, 2013 | Acer Aspire 7250-bz600 Laptop
Startup volume is too high how can I adjusted to a lower level
Some sets (you would have to contact the mfr) (Samsung?) have in the technical menu a setting for "initial volume level" and some even let you set that level for each speaker or channel.
I doubt it will be in the customer menu but if there it would be in the audio portion of the menu.
IF YOU ARE USING A SAT OR CABLE TYPE BOX MANY HAVE THE VOLUME CONTROLS ON THEM AND IF TOO HIGH THIS ALSO COULD BE THE PROBLEM.
Mar 14, 2012 | Samsung HP-S4253 Television
How do i adjust voice volume on my jitterbug
The rubber volume button on the outside of the phone adjusts both the ringer volume and the call volume, which is how loud a caller sounds when on a call. If you are not on a call, the volume button will adjust the ringer volume. To adjust the volume of a caller, you must adjust the volume while on that call.
To do this, while looking at the inside screen, adjust the volume by using the rubber volume button, which can be found on the outside of the phone. Press the top of the button to increase the volume and the bottom of the button to decrease the volume. The inside screen will display the call volume level. You may also set the call on Speakerphone mode. If you have the Jitterbug J model, there should be a button labelled "SPKR" on the upper left corner of the keypad.
If you need additional help, you can call a customer service expert available 24 hours a day 7 days a week at 1-800-733-6632 who will walk you step-by-step through the process.
Nov 19, 2010 | One Touch Jitterbug One-Touch Cellular...
When the volume is turned up past 30 the sound shorts out and breaks up on my KD-R200
Well if say ur volume doesnt go much past 30,,they usally do called distortion,,but if your cd volume say goes to a 100 and it doin that @ 30,,could be a speaker wire touchin ,,another,,or channell goin out,,I would take it and make sure connected good and pos and neg correct,,goodluck
Nov 18, 2010 | JVC AM FM CD DET FACE CAR STEREO
The volume stays on high. I can lower it but, after I release the button the volume goes back to high.
I have the same problem with KV-20-FV-300. My remote stopped working and when I adjusted the volume manually, it goes to high and when it adjust it back down, it goes high again. I'm able to get the sound to stabilize by getting the volume to where I want it, and then pushing the up and down volume buttons at the same time. I'm still searching for a permanant solution though.
Mar 20, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
How do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Dec 30, 2009 | Uniden DXA15588-2 Twin Cordless Phone
My Slice phone no longer rings out loud or vibrates when a call comes in. How do I restore those settings?
Check out this link for a PDF manual for your phone. Just copy and paste into your browser.
http://safemanuals.com/user-guide-instructions-owner-manual/UTSTARCOM/PCS1400-_E
I got this info off of page 60 from your manual.
CUSTOMIZING YOUR PHONE VOLUME
Control the volume for Ringtone, Speakerphone, Headset, and Advanced settings.
Ringtone
Set ringtone volume and incoming call alert options:
1. Press [Menu], then press "Settings".
Press "Sounds", then press "Volume".
2. Press "Ringtone".
3. Press / to adjust the volume level. Press to select Vibrate when High is the volume level.
The volume settings available are:
• Silence all: All sounds are off.
• Vibrate : Phone will vibrate to alert you of incoming call or message.
• Off: Only the ringtone is muted.
• Ringtone mode: Low, Medium, High.
Tip • You can adjust the ringtone volume with the side keys.
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Oct 05, 2009 | UTStarcom PCS1400 Cellular Phone
Pairing the insignia bluetooth wireless headset with an ipod
Perhaps either its pairing log is full, thay hold a number of pairing internally, and may need to be cleared to make room for another....or the headset may need to be reset, either way...heres the scoop....to clear the pairings hold the track forward/track backward buttons down together until the light flashes Purple....Empty pairing log......
If not then try pluging in the set to the charger and holing the 2 volume buttons down the same way..this will shut it off and reset it if it went a bit screwy on ya.... Merry Christmas
Nov 05, 2008 | Insignia Bluetooth Wireless Headphones...
Audio stuck on high
You cannot adjust the volume when the stereo cord is plugged into the back of the dock. Instead, plug the stereo cord into the front headphone jack of the dock. You will be able to adjust the volume then.
Mar 11, 2008 | Sirius Stiletto 2 Satellite Radio Receiver
Pioneer PD-M426 6-Disc CD Changer Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
