Question about Lanzar Snv65I3D Navigation Receiver
Wiring The system was installed yesterday but there is no sound. What are the wires for sound and speakers?
Panasonic SC-BTT775 home cinema centre speaker has stopped working it was fine yesterday but I disconnected the wires to clean it when I run the speaker test I can get sound through it but that's it?
Some units have the ability to switch off the centre channel in different sound modes. It sounds like you have somehow switched it off. A careful read of the manual should get you back with sound.
Sep 07, 2015 | Panasonic Audio Players & Recorders
Tip
How to identify speakers on surroud sound system whe hooking up.
Most people will try there best to mark the speaker wires on their speaker system when they run them. That can be a big pain and if you don't mark the with a simple system it can be confusing. It will be more trouble if you did'nt mark the wires when you ran them. I have a very simple solution that works well. You don't need to worry with marking the wires at all. The easy way to identify the spearker you are hooking up when you are installing a system is to use a 1.5 vdc D cell battery. You may ask, why a D cell battery? It is pretty simple. If you have connected the wires to the speakers.With the + (possitive)terminal connected to the side of the speaker wire that is marked with a stripe. Sometimes the stripe is white or black and sometimes no stripe at all. If it does not have a stripe it will have small ridges along the side of the wire. Stripe or ridges we call that the tracer. Place the wire with out a tracer on the - (negative) terminal of the speaker. On the other end of the wires youwill need to strip the insulation from the two conductors of the speaker wire. Hold one of the wires to the - (negative) end of the D cell battery. the +/- indications are located on the side of the battery. The bump on one end of the battery is normally the + (possitive) end of the battery. Touch the other wire to the + (possitive) side of the battery for a second and remove. Repeat this several times and note the poping sound the speaker make. Listen for the location of the speaker that is poping. Hook the speaker to the terminal on the amp that matches the location of the speaker that pops. Move to the next speaker and repeat. Do not worry this action will not harm the speakers. They will see much more than 1.5 vdc when you drive them with the amp. The next time you need to install speakers try this tip. You can use it in every installation and it will speed the install process. I hope you find this very heplful.
on Aug 30, 2010 | Audio Players & Recorders
Changed Radio - now speakers don't work. I took out the Chrysler radio that had a CD and cassette in it and replaced it with an aftermarket radio. Now the speakers don't work. I got the adapter from a...
Sounds like your Gr Caravan has the premium sound package. You likely haven't hurt anything - but you may need to modify the wiring a bit. The speakers have a tweeter speaker in the center of the main speaker and the wiring goes through that. However, it only worked with the premium package. Go in to the speakers and move the wiring connections from the tweeter to the main speaker. Your other option is to replace the speakers.
Jan 19, 2010 | 1994 Dodge Grand Caravan
Speaker Fried, is my Amp toast too?
You are sending TOO much power to the speakers, Replace the speakers and then get a much smaller amp that is within the ratings of the speakers. ACTUALLY you should get an amp that is aboout 1/2 the total rating of the speakers.
You should ALSO procure a sound meter to verify the sound level is within safe limits. If you insist upon abusing your ears with too high a sound pressure, be ready to buy hearing aids at a VERY young age.
You also need to know that the enclosure of the speaker plays a part in keeping the speaker from tearing itself to pieces.
MANY of the auto sound system installers are hacks that don't do it right and you see what happens to your expensive equipment!
Using even a Radio Shack sound meter properly will protect your preciuos hearing for later life.
Dec 22, 2009 | Bazooka Car Audio & Video
How do i wire external rock speakers with 6 wires to my internal sound system with only two wires
Here is a link to the installation guide... for Insignia Simulated Rock Speakers... http://insigniaproducts.com/cms/documents/NS-R2111%20UM%20EN_SP_FR.pdf
Jun 12, 2009 | Insignia Simulated Rock Outdoor Speakers...
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Sep 29, 2008 | 1996 Ford Explorer
I need the colour wire description for a 2000 dodge caravan Im removing the the factory stero and installing after market stero and need wring diagram , what each wire is for ,speakers ,power etc.
HI.
In the caravan are 2 types of Radio.
1. Normal sound system.
1 Premium sound system.
Note: If you don't want to cut the original wires,
You can buy a harness connector to install the aftermarket Radio. The connector are made by aplication, and are plug in.
The colour of the connector are the same colour with the Aftermarket Radio. Just you need to soldering or just put joint connectors.
Normal: colour of wires.
Pink = Battery voltage.
Red/withe = Ingnition Voltage.
Brown/red and Dark green. = Left front speaker.
Dark bku/red and Voilet = right front speaker.
Brown light blue and brown/yellow. = left rear speaker.
Dark blue/orange and dark blue white = right rear speaker.
Ground is a single wire behind the radio.
If you have a premium sound. You need to use the front speaker out to connect the speaker on the door and the speaker on the dash. To complete the 6 speaker.
OK... I hope this information work for you.
Thank you , For use fixya. Rate please.
Jul 17, 2008 | Car Audio & Video
Protect flashing on screen
That is the system telling you it jhas shut down the amplifier circuit to protect itself from damage.
Check the speaker wires both at the back of the unit and at each of the speakers to see if any of them have come out or are touching anything they shouldn't be.
You may also have a blown speaker sending a short back down the line. So if you find no wires out of place, then disconnect each speaker and turn the unit off and on as you go until the message is not showing and sound is restored.
Apr 30, 2008 | Sony DAV-SA30 System
Front right and left speakers problems
This is going to have to be a solution in the works...so don't rate until we have some kind of end-result.
Connect the speakers to a different device such as an MP3 player or a Nintendo DS. See if the speakers still cease to work. If they work just fine with a different device, then consider that it may not be the speakers...but a problem with the sound system in your PC.
Perhaps the sound configuration in Windows is disrupted. Perhaps the driver settings for your soundcard in your PC are corrupted. (A complete reinstallation of Windows with a fresh installation of the sound drivers would probably prove this theory right or wrong.)
Perhaps there is a problem with the FRONT CHANNEL hole on the sound system on the rear of your PC. You could check that by plugging the REAR channel of the speakers into the FRONT channel on the PC.
And lastly...there could be a break or a short in the cable of the speakers. You could always test another set of speakers with each sound channel and see if that might be the possible issue.
If the sound card in the PC turns out to be the problem, then install a different sound card. If the soundcard in your PC is currently the onboard one, then disable it in the BIOS before installing the new card.
Let us hear the results before we do any rating. Unless of course you're able to fix it with the data given. :)
Cyryl
Dec 08, 2007 | Dell 5650 Computer Speakers
Lanzar Snv65I3D Navigation Receiver Logo
19 people viewed this question
Top Lanzar GPS Experts
Are you a Lanzar GPS Expert? Answer questions, earn points and help others
