Question about Tools & Hardware - Others
Apsco a9 stapler how to insert staples - Tools & Hardware - Others
2 Suggested Answers
SOURCE: Apsco A9 loads apsco
Carole - re A9 Apsco stapler - my A9 is not a staple-gun but is what I call a heavy-duty stapler for 10+ sheets of paper. There is a hinged metal hood at bottom end of handle (beige colour on mine). If you pull that metal hood upward towards you (being the handle mechanism) you will see the staple loading track mechanism with tradtional-lever that releases spring for loading staples. Good luck!
Posted on Jul 21, 2011
Apsco a9 stapler user manual
Try Googling (Apsco)(a9)(manual) without parens.
Aug 03, 2017 | Tools & Hardware - Others
How do I open an Apsco 2000 model stapler, to refill it ?
Push the button upward, then pull the piece at the front forward, the staple tray will slide out.
Jun 16, 2014 | Staples One Touch Executive Stapler
Swingline Optima 45 Stapler - cannot slide tray back in stapler, no staples jamming
Sometimes the rectangular insert where the staples sit on, gets dislodged. On the underside of channel insert is a spring and when correctly seated is in between the tabs of the bottom piece. If the insert isn't in between the tabs, it sits too high and makes it difficult to open and close the staple tray. The staples will jam.
Jun 13, 2014 | Swingline Optima Electric Stapler 45 Sheet...
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
Apsco A9 loads apsco HO staples, can remember how to put the staples in it anymore.
Feb 08, 2011 | Tools & Hardware - Others
How do I replace the staples in Stanley Bostitch B310HDS? I cannot seem to figure out how to open it.
"The staples load from the rear of the stapler. At the back end of the is a piece of black plastic that extends beyond the end of the stapler. This device holds the staples inside the stapler. To open the area where the staples are placed, push this extended button and lift up on it. The spring device that holds the staples inside the stapler will then slide out. Place a new strip of staples inside the stapler on top of the two metal guide rails. Then insert the spring device to lock the staples in place. The stapler is now loaded and ready to work. " hope this helps you out
Jan 06, 2011 | Stanley Bostitch 00540: 00540 AntiJam ?...
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
Can't load staples in high capacity stapler
Try breaking off about 15 staples from the strip.
Dec 24, 2009 | Ace Hardware Ace Staple Gun
How to put the staples
depress the handle enough to release the side catch on the stapler. now pull the bottom track down. insert a few rows of staples and snap the track back up into the stapler. the spring loaded follower goes in back of the staple stack.
Oct 20, 2009 | Arrow CHROME STAPLE GUN ARROW IND....
Panosonic Electric Stapler does not staple paper!
It could be either jammed up with staples or the spring mechanism is shoddy.
Apr 14, 2009 | Office Equipment & Supplies
Tools & Hardware - Others Logo
23 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
