Question about Cell Phones
How do you remove back of huawei e589
Remove back cover
Ascend y330. Where can I get free SIM unlock code?
http://sim-unlock.net/simlock/Huawei/Y330
How to unlock Huawei Y330 by code?
Unlocking Huawei Y330 by code is very easy, it is also safest and non-invasive method of unlocking your phone. To get code for unlock Huawei Y330. You need to provide IMEI number of your Huawei. Type on keyboard *#06# or remove battery from your Huawei Y330 to check IMEI number.
To unlock Huawei phones you need to provide them with IMEI number and model of your phone.
Huawei Unlocking process is safe and easy.
Nov 21, 2015 | Huawei Cell Phones
Tip
Nokia battery
<b>Remove the back cover</b><br /> Place the phone with the back of the phone facing you. Pull up the back cover from the finger grip at the top of the cover.<br /><br /><b>Note:</b> Always turn off the power, and disconnect the charger and any other device, before removing the cover. <a></a><span>Avoid touching electronic components while changing the cover.</span> Always store and use the device with the cover attached.<br /> <b>Remove the battery</b><br /> After you have removed the back cover, insert your finger into the finger grip, and lift the battery from its compartment.<br /> <b>Replace the battery</b><br /> <ol> <li>Insert the gold-colored contact end of the battery into the battery slot. </li> <li>Push down on the other end of the battery to snap it into place. </li></ol> <b>Replace the back cover</b><br /> Place the back cover on the phone bottom first so that the cover tabs align with the slots in the phone and press the cover moving from the bottom to top until the cover is securely in place.
on Mar 09, 2011 | Cell Phones
WEAR IS SIM CARD SLOT FOR HUAWEI M 835
1.Carefully push the SIM card out of the wallet-sized plastic card carrier.
2.Turn your Huawei M835 off.
3.Grasp the notch at the top of the back panel and pull away from the Huawei M835 to remove the back cover.
4.You'll see a notch at the top of the battery.Use it to lift the battery out of the Huawei M835.
5. Your SIM card has one corner missing.Slide the SIM card into the SIM slot so that the corners match.Ensure that the gold contacts are facing downwards.You will hear a click.
6. Reinstall the battery and back cover and then power up the Huawei M835
Apr 29, 2015 | Huawei Cell Phones
How to remove back cover of viewsonic VT2430
Download the service manual from here:
http://elektrotanya.com/viewsonic_vt2430-1m_vs12335-1m.pdf/download.html
Apr 28, 2015 | ViewSonic VT2430 24"" LCD TV"
Water spilled on my huawei android
Water and electronics don't mix.
Immediately, (too late for that), remove batteries.
Wipe off any excess liquid with absorbent paper or cloth.
I have heard that if you bury it in rice overnight, with the battery out and cover removed; that the rice will absorb moisture.
Next day put the battery back in and turn on.
However if there was damage done instantly, you will just have a dry android that doesn't work.
Feb 02, 2015 | Huawei Cell Phones
How to remove back cover ?
Before you remove the back cover, need to unscrew the nails from the back cover. then remove the keyboard (carefully remove the connector ribbon cable), then the top cover nails, after carefully removing the ribbon cables. Then the screws for the display panel. Remove the nails in the motherboard following the markings of the manufacturer. Finally you can take off the back cover separately as required. This procedure has to be followed and the experience is a must to avoid damages to the equipment. Get some professional advice before proceeding.
Jul 22, 2014 | ASUS Computers & Internet
I don't know how to get the battery out of my Huawei ascend h866c to be able to put an sd card in it
1.Remove the back cover by pressing and sliding it downward toward the bottom of the phone. 2.Insert the battery into its compartment so that the metal pins on the phone are touching the metal bars on the battery. Make sure to position the bottom of the battery first and then push the bottom in gently. 3.Once the battery is in place, replace the back cover.
Aug 24, 2013 | Cell Phones
Removal of engine cover
Pry apart the back cover by guiding the flat-head screwdriver along the separating line between the front and back covers of the iPhone. When the back cover is apart from the front cover, flip the back cover off the iPhone, but be careful because a flat cable that goes to the motherboard connects the two covers.-----------------------------------------------------------------------------------
NEXIQ 125032 USB Link Plus
Jan 17, 2013 | 2007 Pontiac G6
Cell Phones Logo
262 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
