Question about Clarity Ameriphone XL40
PROGRAM PROGROM NUMBERS IN AUTO DIAL
2 Suggested Answers
  • 1632 Answers
SOURCE: how do you program new numbers in speed dial on the clarity c4105 phone
Delete the old ones and add the new ones one by one .
Posted on May 15, 2012
How do I program in numbers for auto dial?
i dont know the type of phone you are using but with my BB, i press and hold any number key and it gives my the option to assign a speed dial to that number key.try that and see if it works for u
May 06, 2011 | Cell Phones
I have the KX-T7020. How do I reprogram the auto dial numbers?
Here's a guess. Is the 7020 the one with 16 buttons? If so, they are marked CO 1-12 and F1-4. You program them by putting the phone in PROG from the switch on the back of the phone, then press the button and 1. If it's a F button, dial 9 + number and STORE. If it's a CO button dial 29 + number and STORE.
If you're talking SYSTEM speed dial numbers, those are done from the display phone at jack 01 and putting the system in programming.
Carl
Mar 24, 2011 | Panasonic KX-T7020 Corded Phone
How do I program a phone number to the one touch buttons on a Panasonic KX-T7730 phone?
It depends on what you get when you dial "9" on the intercom. If you get an outside line, then the 12 right side buttons on your phone can be programmed for one touch dialing like this:
On an idle phone, press PROGRAM a button and dial 9 plus the number and STORE. You can program more than one button by just pressing button numbers and STORE. Exit programming by picking up the handset and dropping it back down.
If you want a specific line, you may be able to dial the specific 8x code to access a line directly, or you can go into system programming and delete the open lines in program 400. Disabling would be the best, because if your 8x line is busy, you can't make the call with the auto dial button.
Carl
Mar 08, 2011 | Panasonic KX-T7730 Corded Phone
How do I program the system for auto-dial? The manual is useless...I have followed those directions & have gotten no where.
The 7030 phone was first introduced in 1989 or so, and it is forward and backward compatible with about 18 different Panasonic systems. Since the "auto-dial" is part of the phone system, it isn't easy to answer your question.
As a minimum, you have buttons with lights and "F" buttons without. They program differently.
For example, if you want to autodial another extension, you pick a lighted button, put the phone in PROGRAM, press the button, and dial 1 + ext and STORE. How you program outside numbers depends on what happens when you dial "9" on the intercom. If you get a working line, then you program a button with lights by the 2 + 9 + the number, or "F" button by just dialing 9+.
System speed dials are programmed from the master phone in system location 01 or 001, depending on model.
Carl
Mar 02, 2011 | Panasonic KX-T7030 Corded Phone
I WAS RE-PROGRAMMING MY AUTO DIAL BUTTONS AND WAS ON MY 3RD ONE WEHN IT DECIDED THAT ALL MY BUTTONS WOULD NOW DIAL THAT NUMBER. i CAN'T TOUCH A SINGLE BUTTON WITHOUT IT DIALING THAT NUMBER.
To Program Buttons On Your Phone:
For External Numbers:
1. Press the Feature button, then * 1
2. Push the button you want to program
3. Display will read "Program and OK"
4. Enter the telephone number, then press the OK softkeyFor Internal Numbers (Extensions.:
1. Press the Feature button, then * 2
3. Display will read "Intercom #:__"
4. Enter the extension number
For Feature Codes:
1. Press the Feature button, then * 3
3. Press the Feature button then enter the Feature Code
Aug 12, 2009 | NorStar M7310 Corded Phone
Program and use speed dial numbers
speed dial must set at port ' 00 ' or 000
to check, use display phone, press #402 or #401
speed dial code are from 60 to 99
to set press speed dial , redial , speed dial code eg. 60, press 9 follow by destination number asn redial to confirm
to use speed dial to call press speed dial short key follow by speed dial code or *60
May 26, 2009 | Toshiba Lands Phones
Programming Auto Dial Number
Yep. Those are speed dial numbers. They are programmed from ext 101 or the main phone. Without picking up the handset, press PROG **1234 and dial 001 and ENTER. Dial your 3 digit speed dial number If there is something there, it will be displayed. A speed dial number is stored with the trunk access code in it (usually 9) so if you're putting in a new number, include the "9" plus the number exactly the way you dial it. Dial your new number with the access code and press ENTER.
Number changed :-)
You can keep putting in a whole boatload of new numbers with this procedure.
Carl
Mar 16, 2009 | Panasonic KX-T7633 Corded Phone
Seems to be locked into a program - do not have a manual
If using the KX-T7730 phone on a Panasonic 308/616/824 system press Program 11 and then AUTO DIAL / STORE . Press Program to exit programming mode.
If this answer was helpfull please vote
Thank you.
Oct 15, 2008 | Panasonic KX-T7730 Corded Phone
Phone settings
I have a panasonic KX-T7730 and through trial and error i have found out how to change the time.
Press Program. PITS-PGM N)? should come up on the screen.
Then press O
This should give a list of digits on the screen.
The first 6 digits is the current date in yrmmdd format.
Then there is a space and a single number. I represents monday 2 represents tuesday 3 represents wednesday and so on.
The next set of numbers is the current time in 12 hour format.
The last number is either 0 for am or 1 for pm.
Press auto dial/store when you have entered all the relevant numbers to save.
For example to set 3pm today you would type 090406 1 03:00 1
Mar 19, 2008 | Panasonic KX-T7730 Corded Phone
Clarity Ameriphone XL40 Logo
12 people viewed this question
Top Clarity Lands Phones Experts
Andrew Taylor
Andrew Taylor
Are you a Clarity Lands Phone Expert? Answer questions, earn points and help others
