Question about Dryers
Not heating properly
Not continuing to heat
  • Dryers Master
  • 8,220 Answers
That fact that it is heating at all tells me the element is fine. You probably have some sort of air flow problem. I would clean it real good inside and out. I have manuals and a collection of dryer service tips here: Dryer problems and solutions
Posted on Apr 30, 2013
Dryer wont heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Maytag Neptune MDE6700A Electric Dryer
Whirlpool Dryer LEB6200KQ0 - Issue will not heat. Have checked Power, Getting 220 volts (110 on each line at dryer) Checked Heating Element. Have continuity. Checked Thermal Link. Have...
heatman101
Jul 06, 2011 | Dryers
Dryer quit heating no power to element what is wrong?
The problem is most likely the thermal cut-off and the high-limit thermostat. The thermal cut-off blows when the high-limit thermostat fails and since these parts are wired in series with the heating element, power to the heating element is therefore terminated. Check the continuity of the thermal cut-off and if it reads open, replace it along with the high-limit thermostat.
You can bypass the thermal cut-off and the high-limit thermostat for troubleshooting purposes. Join together the wires of each part and insulate it properly then reconnect power. The two components indeed need to be replaced if the dryer heats up. If not and still no power to the heating element, check the continuity of the heating circuit. Check the continuity/resistance of the heating element if there's power to its terminals but doesn't heat. Replace the heating element if it reads open.
Let us know if you need further advice. Just indicate the exact model number of the dryer for accurate troubleshooting tips.
Jan 23, 2011 | Kenmore 700 6972 Dryer
I am getting no heat from my dryer. I have taken out the heat coil and did a continuity test an it checked ok. there is a sensor on top of the heat coil and towards the left side they both had continuity....
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 30, 2010 | Maytag Dryers
My dryer wont heat up or shut down
It's not heating up because the heating element is broken and should be replaced. It won't shut down because the thermostat isn't sensing heat and continues to run while expecting heat. So replacing the heating element should get it running properly.
Mar 23, 2010 | Whirlpool LER5636P Electric Dryer
My outside heat unit is frozen and it is 10 degrees out, will it thaw while I have it on emergency heat? How long do I keep emergency heat on?
Switching to emergency heat will not defrost the unit.
If the Heat pump is malfunctioning, continue to use the emergency heat until the unit can be repaired properly.
At ten degrees, no heat pump can keep up., but it should be automatically bringing on the heat strips as back up heat. (same thing as emergency heat, it's just automatic.)
Either the extreme cold is overloading the defrost system, due to lack of properly operating exterior temp sensors or the defrost is malfunctioning,
Feb 07, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
GE dryer won't heat, Has 240 volts at dryer plug and the heating coils have continuity.
You need to check the thermistor/thermostats...that may be your problem.
When they go bad, the will not let the heating element heat up to proper temp.
Good Luck,
Hope this Helps
Oct 07, 2009 | GE Dryers
Dryer has no heat
either your heating element or your thermostats are bad. on the heating element casing there are two thermostats. check the top one for continueity if it doesn't have continueity the change both thermostats. if they are good then check your heating element for continueity. after you get your dryer heating then clean out your vent system... if it's not venting properly then your dryer will take a long time to dry.
Jun 16, 2009 | Frigidaire Dryers
Clean light flashing
this is a safety failure of the unit not heating the water properly. if you push the " water heat, air dry, water heat, air dry" in that order, then it will go into the program mode and clear out that failure code.
then try the unit again, if you open the door during the heat cycle or it doesnt heat properly it will happen again. make sure you have hot enough water, 120 degrees, going to the unit and dont open the door after you start the cycle. if it continues call sears for service as it has a 1 year warranty.
Dec 09, 2008 | Kenmore 24 in. 15173 Stainless Steel...
Dryers Logo
Top Dryers Experts
