Question about Maytag Atlantis MDG6400AW Gas Dryer
Maytag mdg6400 not heating properly
Stops heating when hot
  • Maytag Master
  • 8,220 Answers
Probably due to a good cleaning is needed or a worn out blower wheel. To get into these you take the door off and that will allow you to get the front off remember the door is reversible so you will have to remove screw on both sides. once the front is off you can take the hooks off that hole the top down and raise the top. then you remove the shroud and tub and give it good cleaning. Their are numerous videos on youtube that show how to disassemble the machine. Like I said look for a bad blower, lots of lint, and things like that. Also check your vent piping to outside. I have a slopeface dryer service manual on my foggy facts page.
Posted on Apr 30, 2013
I get code E6 and my Maytag dryer keeps stopping
BAD MOTOR WINDINGS OR DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Apr 19, 2015 | Maytag Dryers
Wont get hot and dry clothes
If the dryer runs the same as before except it will not get hot then check your heating element that is more than likely your problem.
Sep 04, 2012 | Maytag MDG6400 Atlantis Gas Dryer
MY DRYER STOP DRYING WHAT IS THE PROBLEM
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 16, 2011 | Maytag MDG6400 Atlantis Gas Dryer
Making a knocking noise for about a month... now it won't heat up... what is the problem and how do I fix it?
That is two differnt problems,the banging is probably the belt about to go and the other is the thermostat
Feb 15, 2011 | Maytag MDG6400 Atlantis Gas Dryer
My electric dryer stopped on me today...is there a curcuit breaker on it???
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 01, 2010 | Maytag MDG6400 Atlantis Gas Dryer
No heat in dryer
Hello there Here are some ideas that may help you
- Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
On the back of the dryer near the fan blower housing is a thermal fuse, if this opens up ( no continuity ) the gas burner often quits but the motor will still run. If the thermal fuse is open/bad, always clean, change, adjust the venting system and vent hood first and clean out the dryers air ducts. Sometimes it is a good idea to replace the operating thermostat at the same time.
Thermal fuse parts help link...on blower housing cover, can not be re-set, must be replaced if is open (no continuity between pins).
hope this is very helpful for you
best regards Michael
Dec 23, 2009 | Maytag MDG6400 Atlantis Gas Dryer
My front loader dryer stopped heating,
have a electrician inspect the circuit going to the dryer as it might not be providing proper current to operate the dryer
Jun 22, 2009 | Maytag MDE9206 Dryer
Gas dryer seems to be overheating
The first and easy thing to check is the vent going out of the house if it is restricted or cloged it will over heat and shut off check that first
Mar 28, 2009 | Maytag MDG6400 Atlantis Gas Dryer
Maytag Atlantis MDG6400AW Gas Dryer Logo
46 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
