Question about RCA F27650 27" TV
RCA F27650 27" TV - Snow Bursts
This tv is about 9 years old..still has a great picture and have never had any problems until now. The screen will just go to snow infrequently and then after a few seconds/minute it will come back to a picture...the cable connection is fine..it is definitley the tv.........any suggestions??? thanks!!!
  • 398 Answers
The model you listed, F27650 uses the new ATC113 series chassis, which is only about 3 years old. The ATC113 chassis is not known to have snowy issues, but if yours is then I would suspect that a solder joint is loose in the tuner. If your set is actually around 9 years old, then it might perhaps have the notorious CTC175 - CTC187 series chassis, which went snowy all the time due to cracked solder joints on the shield grounds around the tuner and microprocessor. In either case, some good quality resoldering should cure your trouble. If you have never done fine solder work on PC boards with small surface-mount parts, allow a qualified tech to handle it for you.
Posted on Aug 08, 2007
Rca 32 rca 32
The repair of this problem will be near to or exceed the cost to replace it with a new flat screen. With TV prices at an all time low due to slack demand it is not cost conscious to repair it.
Jan 24, 2012 | RCA F32650 32" TV
Color separates and picture bows on 9 year old RCA big screen.
Hi, This is a convergence problem and you can set it right by changing the STKs. It is a professional job and i have knowledge of people who ruined their tv by spoiling some miniature surface mounted components close by. You may need to look at pico fuses too. I would say seeek professional help if you not comfortable working with electronics. Check out at www.fixurtvs.com,
Mar 02, 2010 | Toshiba 55H70 55" Rear Projection...
RCA XL100 20" Snow on screen
you have lost one of 3 things,Antenna/Cable, Tuner or part of your tv's power supply
Sep 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
No picture; black screen; only red light blinking.
take to a service station i think just changing the displsy IC would do . but check in service centre
Jun 19, 2009 | Toshiba CZ32V61 32" TV
Rolling lines on screen
Sounds like the power supply has a bad capacitor. This problem can inject excessive 60 hz from the AC line into the vertical stabilizing picture system. The hum also my come from the same reason, bad or leaking filter capacitors. Cheaper just to buy a new TV or borrow another TV and connected to your system to see if the problem still occurs.
Mar 16, 2009 | RCA F36668 36" TV
Fisher tv monitor intermittently turns to snow and loud buzzing
Could it be vertical IC loose connection. It is sometimes connected with correct tuning. Check it for crack or wiggling connection best is to resolder.
Feb 02, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
Scrambled Picture/Snow Screen, has sound, can play DVDs through colorstream
I had this with a rca once. Can you hear a crackeling noise coming from the flyback transformer? My problem was just the wire was loose
Sep 27, 2007 | Toshiba TP50H50 50" Rear Projection...
RCA F36450 TV is intermittently snowy
Your tuner assembly has a bad connection inside of itself, or there is a bad connection around the tuner assy. if this is an ATC113 chassis Good Luck
Mar 21, 2007 | RCA F36450 36" TV
Poor cable connection
radio shack sells type f/rca adaptors
Jun 28, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Open Questions:
Letterboxing: The top and bottom of the screen are cut off I originally obtained this TV from my Bro who passed away from cancer at age 31 a few years ago & I was never able to find out what he did with the manual. However, I was able to find a manual online but after viewing it, I still wasn't able to find the info. that I am trying to obtain for the correct settings to get rid of these black margins at the top & bottom of the screen. I am trying to find out what video output format is supported by this TV model, as far as the resolution and output format, specifically for a Cisco or AKA Scientific Atlanta 500GB HD-DVR through Cox cable? My available settings with Cox cable & the DVR I have( Cisco or Scientific Atlanta 500GB model)are the following-Resolution:480i, with output format of either:Zoom 16:9 Pic or Letterbox 16:9 Resolution:480p standard, with output format of either:Zoom 16:9 Pic. or Letterbox 16:9 Resolution:480wide, with either output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic Resolution:720p wide, with output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic and finally, resolution:1080i wide with output format of:Stretch 4.3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic? Everything worked fine with the screen size when I had a 160GB Motorola HD-DVR with Cox under the video output settings of:resolution:480i and video output of:Zoom 16:9 Pic until, I grew tired of constantly running out of space & had them switch me to a 500GB HD-DVR. They were supposed to install another Motorola HD-DVR but just with 500GB version but when the Cox maintenance employee showed up to swap them out and install the 500GD HD-DVR, he only had a Cisco/Scientific Atlanta 500GB available on his truck, which is I guess what they use for the Contour service but he attached a filter to the back of the coxial cable to make it a regular HD-DVR without Contour(even though they tried charging me extra for contour for 3 months before I finally got that straightened out since the maintenance workers & billing dept. are often not on the same page as I found out at Cox. I have tried calling Cox for support & they say that I need to find out & know my TV's video output settings. I explained to them that it worked perfectly fine just weeks ago with 480i resolution and output format of Zoom 16.9 Pic before they switched to the Cisco/Scientific Atlanta HD-DVR from the Motorola DVR and that I didn't have the manual and I stated why and they basically said, too bad, figure it out yourself. Can someone please help me out? I have the TV set up for the correct zip code, cable box-Yes, the cable box output channel-video 1/Aux (since that is what the TV manual I read online said to use if you are using the 3-color coded cables instead of the coxial cables to plug in from the TV to the HD-DVR) & I have the Cable box remote control code set to code 008 (Scientific Atlanta) that I verified to be correct by checking it through the TV's automated code search. The serial # for the TV is:C306B2084 and the Chassis # is:ATC113BB1 and its the 27" RCA Entertainment Series Guide Plus Gold Gemstar that is X-Box ready. Thanks so much, Todd
Feb 26, 2017 | RCA F27650 27" TV
RCA F27650 27" TV Logo
141 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
