Question about Rule 1800 H53SP-24 Swimming Pool Cover Pump
Emerald Vantage Hot Tub Dead
Turned off spa and drained for winter. 50 amp GFCI will not turn on. With ohm meter found both heater element terminals appear to be shorted to ground. Is this possible? Does the heater have separate fuses so as to remove heater from ckt and see if that is really the problem?
  • 717 Answers
If your GFI trips soon after the spa goes through the purge cycle then you need a new heater.
Yes the heater can develop a dead short and it causes the GFI to trip when power is sent to the heater.
Rod @ US Parts Center .com
Posted on May 09, 2013
2 Suggested Answers
thepool
  • 78 Answers
SOURCE: Trips GFCI outlets
The motor on this unit is sealed and not accessible for repair, only replacement.
Posted on Apr 21, 2010
I just wired my hot tub into my new house. And GFCI keeps tripping?
Still would go with Miswired.
if this is an auxiliary GFCI Spa Disconnect,
240 VAC, 50 Amp, then...
All of the following needs to be this way:
  • 4 wires from MAIN Circuit panel, into GFCI disconnect box, 2 hots, 1 Neutral, 1 ground
    • 2 hots go onto the disconnects Power Bus Bar for breaker
    • 1 white Nuetral goes to Isolated nuetral bus bar
    • 1 green Ground goes to ground lug directly on the box
  • 1 GFCI in the auxiliary disconnect box
    • The White Pigtail of the GFCI Breaker goes onto the Isolated Nuetral bus bar. There are now two wires there.
  • 4 wires come into box from Spa. (Unless the spa is Specifically a 3 Wire Connection Spa!)
    • 2 Hot/Line wires will go into the L1 & L2 lugs of the breaker respectively.
    • 1 White Nuetral Wire will go into breaker as well at the "Load Nuetral lug, usually marked as 'LN'.
      • It will NOT go on the Isolated Nuetral bus bar.
    • Green Ground wire will be connected to ground lug, 2 wires are now connected there.
  • Connections at spa will be respectively connected: the 2 hots on line 1 and line 2. White wire goes to Nuetralnd green ground will go to a Ground Lug, most likely to metal control box.
If it's not wired in this manner, it is wired WRONG.
May 27, 2015 | Electrical Supplies
Hot tub breaker trips but only when people are in it?
Because it is a GFCI. Try making sure that the grounds are all good. Maybe go the extra step of putting in grounding rods into the ground and grounding to the unit. These are just guesses.
Nov 17, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a Beachcomber Model 350 hot tub abd the GFCI is tripped and won't reset
You may have a bad heating element. But first make sure you have power to the gfci. (check the braker) You can test this by disconnecting the heater leads and see if it will reset. If it still trips try disconnecting your equipment one at a time, ie. blower, ozone, circ pump, booster pumps. If nothing solves the gfci issue you need to replace the gfci. All of this is assuming you have a blank gfci receptical monted to your spa pack.
If your talking about the 50 amp gfci at the braker box try pushing the braker all the way to the off position then back to the on possition. If it trips right away do the above.
Aug 06, 2013 | Pool & Spa
Emerald spa
Dead short on the heater element will need to be replaced.
You will need to get the model number off the silver sticker located on the stainless stell heater tube.
Apr 30, 2013 | Pool & Spa
Jacuzzi hot tub, Water is too hot. Heats until it trips the system. I have replaced the analog temperature control,
1) Safety question first
Why hasn't the GFCI tripped.
If your spa is not protected by ground fault., then you are at serious personal risk.
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
2) Replace the element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) If element is cracked, it can continue heating to ground wire, causing runaway heating.
This applies to spas, and water heaters of all type.
Dec 08, 2012 | Jacuzzi Pool & Spa
I have a 240V hot tub and when I turn on the Cutler-Hammer GFCB250 GFI Circuit Breaker, 50A, it trips immediately. I spoke with a tech support guy from the hot tub mfr who says that the heater and pump...
It is very possible breaker is bad. If you have another 50 amp breaker in the box try swapping them and see if it still trips. GFIC breakers are finicky and they do go bad. I would make sure that the heater is not shorted out before replacing the breaker. It shows 15 ohms which is not what you would normally see which is 9-12 ohms. The reading of 15 ohms you got is high but if the manufacture says that is acceptable then we must assume it is. You also need to test for a short before eliminating the element as a possible cause. Test it with your ohm meter set to the highest setting. Measure between one element terminal and the sheath of the element. Any reading indicates a short to ground indicating the element is bad. If you find it is good then a defective GFCI is really about all it can be.
Sep 20, 2010 | Eaton Corporation GFCB250 GFI Circuit...
I have a Rheem 81v52dt 50 Gal Elec heater. I can not get enough hot water to fill a tub.I have turned both thermostats all the way up. I have checked both elements with an ohm meter. I got a 220 reading on...
There should be a flip flop circuit in your heater that switches between the two heaters. I don't think they both heat at the same time. Check the rating on the indivitual heat element then compare that with the data printed on the heater RE: maximum WATT rating.
Now then, what did you miss - I'm thinking you missed the ohm reading. You measured 220 Volts but you did not check to see if the element is burned out or not. Move your meter to OHM and take a measurement with the power turned off. If the reading is "open" the element is buned out. If you get some reading beside 'open' the element is probably able to carry current.
Have you drained the sediment from your heater recently?
All the way up is a dangerous setting by the way. I suspect you know this.
Thanks for your interest in FixYa.com
Feb 19, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
GFCI alarm stays on
Open your drain valve under the unit to break any air lock that will have gotten there when you drained the tub.
Sep 30, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Gfci breaker keeps tripping
sometimes gfi outlets go bad and trip try testing with a heavy draw machine in it or just replace it and see if this fixes the problem
Jun 22, 2009 | Balboa Instruments Duplex Digital Panel 2...
Rule 1800 H53SP-24 Swimming Pool Cover Pump Logo
75 people viewed this question
Top Rule Pool & Spa Experts
Bill Jordan
Robco Water
Robco Water
David Spradling
David Spradling
Are you a Rule Pool and Spa Expert? Answer questions, earn points and help others
