Change hostname lexmark t644 - Office Equipment & Supplies
SOURCE: Reset Lexmark T644
1. Turn off the printer. 2. Press and hold (check) and .(right arrow). 3. Turn on the printer. 4. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. 5. Select Reset Maintenance Count from the Configuration menu. 6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
Posted on Jan 26, 2009
SOURCE: setting print count on Lexmark T644
I'm assuming you mean the maintaince counters... Turn off the printer. Press and hold the check and right arrow buttons on the front of the printer
Turn on the printer. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. Select Reset Maintenance Count from the Configuration menu. The message Reset Maint Cnt=Reset displays momentarily. Press Check to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
don_farr
  • 1018 Answers
SOURCE: Lexmark T644 network settings missing on menu
These are options that you must add via the Network Setup Menu.
Don
Posted on Jun 03, 2009
SOURCE: lexmark t644 error code 917.00
This error indicates that there is a charging problem with the transfer roller. You could start by cleaning the contacts for the transfer roller (power off printer first). The transfer roller is the black foam-like roller under the toner cartridge. Handle it with paper because the oils on your hand could damage it. To remove it, just pry under the far left side with a screwdriver. Lift and pull to the left to remove. If this does not fix it, then you have a more serious problem. It could be one of the arms or the HVPS.
mary_sparkes
  • 25 Answers
SOURCE: lexmark t644 is showing "920.06
920 error is cold lamp on fuser replace fuser will clear problem
Posted on Nov 13, 2011
How to install a lexmark t644 250 sheet pick arm ***'y in 3rd tray
We do not advice that you remove the pick arm for the Lexmark T644. I would suggest that you contact Lexmark Technical Support or contact a local Lexmark Service Provider (please click on the link below to locate a Lexmark Service Provider nearest to you).
Link: http://bit.ly/UeQhSB
Jul 04, 2012 | Lexmark T644 Laser Printer
What's your problem?: Lexmark T644 238.02 ERROR
Lexmark t640 Fehlermeldung 238.02 alles nach gesehen kein Papierstau was kann es sein?
Feb 08, 2012 | Lexmark T644 Laser Printer
Lexmark t644 is showing "920.06
Sep 25, 2011 | Lexmark T644 Laser Printer
How to change tray 1 to plain paper legal of T644
...Tray Tab. Change the Paper Source to Tray 1. Click the Paper Tab. Select in paper size, Letter. Select for Output Size, Same as
Sep 24, 2011 | Lexmark T644 Laser Printer
How to fix,if every time somebody send to printer Lexmark T644 shows error message:"change tray 1 to color letter? thank you Bella Touro College lab tech
Have a look in the preference settings of the printer driver and check the paper type. If this is set to color letter you'll have to set the traysettings to the same type of paper. Best is to set both setting to normal paper.
Jul 27, 2010 | Lexmark T644 Laser Printer
I need to feed the paper, how do i change the tray to feed , lexark t644
Perhaps the Lexmark T644 User's Guide will be able to help you. Just click on this link: http://bit.ly/cOEjQN. Scroll to Page 44 for instructions on Loading standard trays and optional trays. Hope this helps. If you need more assistance, leave it as a comment and I'll get back to it. Thanks.
Jul 06, 2010 | Lexmark C533DN InkJet Printer
Don
Jan 16, 2009 | Lexmark T644 Laser Printer
LEXMARK T644
Make sure that the toner is not leaking and check your connections from the HVPS. If they look good I would replace the printhead.
Roger
Sep 10, 2008 | Lexmark T644 Laser Printer
103 people viewed this question
k24674
jasbo
jasbo
