Question about Nixon Lodown Tide watch
ENERGY SAVER I need to know how to activate and disactivate the mode of energy saving.
WHAT IS KINETIC ENERGY
kinetic energy is an expression of the fact that a moving object can do work on anything it hits, it quantifies the amount of work the object could do as a result of its motion.
Mar 19, 2015 | Watches
I can't get my watch to turn on. Do these need batteries?
You have three sources of energy.
Solar/Light energy: expose the watch to direct sunlight.
Battery: replace a spent battery with a fresh one.
Kinetic or Automatic: the watch gets its energy from the movements of the arm on which it is worn. . It must not be put in some drawer and forgotten.
Nov 26, 2013 | Citizen Watches
Dpfellside@hotmail.co.ukwhat is actually meant by daylight saving time. my Citizen watch always indicates this setting is off (I am in U.K.)
Daylight savings time is primarily an USA thing. We set our clocks ahead every Spring in March and hour and back an hour in the fall. The idea was invented by Ben Franklin centuries ago to save energy and it is still done with the same idea in mind. Read elsewhere to see how it saves energy, debatable. Not all part of the country observe DST. Just turn it off and you should be fine. You may need to correct the time.
Mar 23, 2011 | Citizen BL5314 52E WR200 Eco-Drive scyba...
My watch stops in the night.But works fine when i wear it.any ideas?
Yes, the Movado is a self winder, and it was designed for the sports active wearer, of which the motion of the wearer's arm provides the power to keep the watch wound. Apparently you are not active enough for the watch to be fully wound, so when you take it off, it will use up all of the stored energy in the spring and stop. many self winders will only store enough energy for 8-12 hours of use and will require constant wearing. You could try wearing it to sleep and see if this is enough to keep it wound.
If you feel that this is not the case for your watch, then you may want to have it looked at by a watch maker
Jan 23, 2011 | Movado 800 Performance watch
My seconds have only started counting every 5 sec ? please could you let me know how much to resolve also asap please thanks
Hi, might be too late but you just need to change the battery as the watch save energy by going every 5 second, mine done the same and now is fine by changing battery.....
hope this help....
Oct 22, 2010 | Omega Seamaster 300M Mid-Sz 2551.80.00...
We bought a sportline solar watch that has a light mode and rerset and st/stp function mode we want to set the time but don't know how? Help please
mcdevito75 here, I see in your question, SOLAR if that means the watch is operated from the sun"s energy, you first have to get the watch going (ticking) before you can set the time, Instead of a Battery your watch has a capacitor that holds onto the sun"s energy and releases it, makeing the watch go (tick). After the watch goes, you need worry about 2 buttons, MODE & SET. Press MODE and see display Flashing, now press set to set each function, (hour, minute etc.) presss MODE after ecah function is set to move on, once all functions are set, press MODE for steady display, also if thew watch is new, look for a small piece of plastic just under the crown, remove that plastic and push crown down to start watch. Hope this helps.
Jul 04, 2010 | Watches
User Manual Nixon Lodown Tide Watch
hello... my nixon dont work... the screen went completely black and does not work any buttons....
I can do??
sanks Daniel
Apr 13, 2009 | Nixon Lodown Tide watch
Nixon Lodown Tide watch Logo
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Are you a Nixon Watch Expert? Answer questions, earn points and help others
