Question about Refrigerators
Hotpoint fza54 freezer door does not shut properly but when i take 3 drawers out it does can you help
Dave117
  • 134 Answers
SOURCE: freezer door keeps opening on
Maybe, but if there is a magnetic door seal, they sometimes warp or need replacing..
Posted on May 04, 2008
  • 10 Answers
SOURCE: hotpoint freezer fza54 frost free,
Power off the freezer.
Remove all freezer drawers.
Remove the four screws retaining the ducting at the back of the freezer compartment. Top at the top, two at the bottom
Carefully pull the ducting out - it's located in the guide slots for the freezer drawers, and should pull out without too much drama.
This exposes the air circulating fan, and the evaporator coil (the bit that gets chilled).
In my case, despite a defrost of the frost-free section, the evaporator section was one massive chunk of ice. If you have similar, carefully defrost this, and check the drain hole at the bottom of the cavity.
Re-assemble, as reverse of above.
Mine's been trouble-free since doing this.
Posted on Sep 19, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore Frig-bottom freezer/freezer door pops open
Replace a door gasket on a refrigerator....
Replace a door gasket on a refrigerator: The first thing to do when changing a door gasket is to check and see if you have the proper part before taking the old gasket off. Hold the new gasket up to the fridge door to make sure the gasket is the same size as the old one. Next step is to remove the wrinkles in the gasket caused by folding for shipping. Instructions with the gaskets say to soak the gasket in hot water. Another way is to use a hair dryer to heat the gasket and remove the wrinkles. Be careful not to burn the gasket with the hair dryer. Almost all gaskets in use today are magnetic. I am placing instructions here for the most common one. They have strips of magnetized material inside the gasket material to adhere to the cabinet when the door is closed. Therefore there is sometimes no up or down on the gasket. Some fridge's have magnets on only 3 sides and the side without a magnet is the hinge side gasket. But to be safe, check this before installing. You will certainly want to check for this on older refrigerators that have magnetic door latches. Some of these have no magnets on the latch side of the gasket. There are about three different ways of attaching gaskets. All will be addressed on this page. Remove the food from the shelves on the door. Loosen the screws that hold the metal strips that keep gasket in place on the top half of the door. Back the screws out about 1/4 inch. The gasket has a lip on it that seats in a groove under the top part of the metal strip. Pull the old gasket off. Work the groove on back side of the new gasket under the cutout in the metal strips that holds it on the door liner. Straighten and get good install before tightening screws. Run screws back up against the metal holding strip snugly, not fully tight. Go to the bottom and do the bottom half. By doing the top half first and tightening, then doing the bottom half, you will minimize any warping of the door. If there is warping of the door, we have not yet fully tightened the screws. so you can realign the door easily and then tighten the screws. Check the alignment of the door and be sure the gasket is sealing properly before fully tightening the screws. If the door is warped, (see picture) simply warp it back to a sealing position, then tighten the screws. There are instances where the gasket is too tight on the hinge side, and you may have to shim the door hinges out from the cabinet to keep the gasket from scrubbing when closing. .also use a little petroleum jelly on the gasket on the hinge side will allow the gasket to "settle" better. The hinge side must slide along the cabinet edge while the other 3 sides just close up against the cabinet. The jelly will allow the gasket to rub smoothly and also prevent squeaking noises. Maintenance of the gasket is important also. It should be cleaned on a regular basis. Clean the gasket and the mating cabinet surface with warm soapy water, rinse clean and dry it good. Putting a little baby powder on the sides (except the hinge side because we put the jelly there) will prevent the gasket from sticking and tearing. The heaters in the refrigerator used to keep moisture from forming on the cabinet attracts airborne materials and make the gasket sealing surfaces sticky. The powder will help stop this. Probably 75% of the fridge's made a few years ago use this edge under the metal track....some American made fridge's use the U shaped metal strip and the gasket pushes into the metal strip, (see a picture) the screws that hold this metal strip do not have to be removed or loosened. A lot of fridge's also use the metal strips with out the edge. Some Maytag's and Woods come to mind. The screws go through the metal strip and the gasket as well. The screws have to be removed completely to replace the gasket.
Gasket sheet to assist you in replacing a common door gasket.
Freezer door pops open when I shut the fresh food door:
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
I hope this helps, and if you need more information On solutions just let me know, Thanks Sea Breeze
Posted on Feb 06, 2009
  • 864 Answers
SOURCE: we have the bottom drawer freezer, top french
Make sure nothing has fallen behind the freezer drawer or is hitting the top of the freezer to prevent it from closing. Also check that the tilt open front is in the closed position. If nothing is blocking the drawer the gear wheels that support it may not be in the right position. See Owners Manual for instructions about removing/reinstalling the drawer. When you get the drawer to close you may have to unplug the power cord for 30+ seconds to get the unit to reset and restart.
Posted on Aug 11, 2009
  • 234 Answers
SOURCE: Hotpoint FFA75 Fridge Frezzer. Freezer door not
This could indicate that your defrost cycle system is nor working and frost(ice) is building-up on the cold coil in the back of the freezer compartment. This will definitely expand the back plate and the drawers wont go in completely. You need to have the defrost system checked: either the timer, the defrodt coil, or the defrost thermostat. Goodluck, Macgivor
Posted on Jan 02, 2010
Freezer drawer on Kitichen aid french door stuck shut. Been of for 24 hours still won't budge.
tough question
by the look of the picture it should not have that problem
something jammed or fallen on both openings
that stop doors from opening
call a fridge repairer first
those doors cost a lot to replace
maybe the fridge guy can you undo the top hinge of the french doors
if the freezer draw handle is broken you might need his help with that anyway
Sep 26, 2016 | Refrigerators
Why on a whirlpool gold double door refrigerator
That's an easy one, the draw is not in correctly, preventing the door to close properly. Clean up the mess then work with the draw until it seats properly, then double check that the door seals closes right.
Jul 23, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have the bottom drawer freezer, top french doors, 3 months old, freezer will not shut all the way and now after door open beep has gone off for an hour the whole unit has gone dark
Aug 11, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Hotpoint Fridge freezer FFA74 Freezer Door Will not close
check that the part that the drawers slide into is in its proper position. try lifting up on door to shut. if this works u may have a broken cam riser. or u may be able to put a washer or two on hinge to raise door up for better clearance.
Jul 26, 2009 | Hotpoint Freezers
Freezer door will not shut whilst drawers are in
Do you have an icemaker?  Be sure the ice maker drawer is in all the way.  This means pulling out the drawer and being sure the gears are lined up properly with the crank located in the back of the freezer.  If they are misaligned the drawer sticks out 1/2 inch (even though it feels firmly seated when you push on it) and the result is a freezer door that will not stay shut.  Believe me, this is experience talking.
Jun 25, 2009 | Hotpoint FFS70 Bottom Freezer Refrigerator
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Upright freezer door won't stay shut
the door maybe disaligned. Look at the the door side on to see if it has dropped a little. It may just need adjusting.
Oct 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Freezer Drawer Stuck
Our 550 bottom freezer drawer froze shut earlier this week and the motor made an unusual sound, like it was working too hard. Two of us eventually were able to open the drawer to find that it had frozen shut due to a leak which filled the ice tray solid and then adhered to the actual door, freezing it shut. We emptied the fridge and freezer, turned the control dials down to 0, but neither the motor nor the light would go off. We finally killed the circuit breaker to get the appliance to shut down. It's cleaned and defrosted and we noticed that the gasket has torn in three places, two on the fridge door and one on the freezer door. The freezer door could be from our tugging, but the refrigerator door is normal wear and tear. We filled the tears with some kind of putty and when it is dry we will start everything up again. This is not the first problem of this nature we have experienced with our subzero 550, but it is the most dramatic. Each previous time we have called a repair man out and he has been unable to fix it.
Aug 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
