N220 cant connect
Wireless adaptor on my desk top wont connect to internet
CoachTim
  • 202 Answers
SOURCE: LINKSYS WIRELESS - G WAG54GS
Diana, The router has lost its IP address from the ADSL gateway. Unplug the router from the wall for about a minute or two. Plug it back in..? If that doesn't work you need to login to your router and check the settings. or(there is a small reset button on the back of the router. Hold it in for 10 seconds the router will reset.) http://www.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=US%2FLayout&cid=1114037290855&pagename=Linksys%2FCommon%2FVisitorWrapper http://www.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=US%2FLayout&cid=1114037290855&pagename=Linksys%2FCommon%2FVisitorWrapper If possible turn your computers off while resetting the connection. Some inter Microsoft networks will issue its own IP if it doesn't detect one. Good Luck, Tim
Posted on Feb 07, 2007
One Piece
  • 53 Answers
SOURCE: limited or no connectivity
make sure wireless switch on laptop is on. since you are using XP, type services.msc on the run box, on the services local page go to wireless zero configuration, check if it has started automatically. then go to your wireless area connection, r. click then view available wireless networks. you shall see your 2wire network as 2wirexxx, where xxx stands for the last 3 nos. of your modem's serial no. connect to that network, it will ask you to enter the wireless key or passphrase. now type in the default wep key, that is the 10-digit nos. at the bottom of your 2wire modem right below the sn 7 it is enclosed in brackets. if you still has limited or no connectivity, check the modem if it is set to use default wep-open encryption. it is done by going to homeportal/management, type your system password, it will lead you to the management & diagnostic console page (mdc), click on wireless under local network. pls check if wep encryption is set to open and it is selected to use default encryption. you can also change the wireless channels & power settings, then click on submit. now try to connect.
Note: you can do the mdc on the desktop.
Posted on Apr 08, 2008
  • 9 Answers
SOURCE: netgear wireless router DG834PN wireless access local only
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To start with plug the LAN cable, type 192.168.0.1
into your browser, a netgear window should come
up name is (admin) PW is (password) default.
goto to wireless settings.
Tick Enable Wireless Access Point
Tick Allow Broadcast of Name (SSID, give it a name
Under security options, Tick none
Hit apply and exit
Setup your laptop up with no security to start with, the laptop
Should now see the Netgear SSID name you made.
After this find out your laptops MAC address, log back onto the
Netgear unit, add the MAC address to the allowed list, hit apply
And exit, now only your laptop will be able to get a wireless connection.
Hope this helps
Have a nice day
Posted on Dec 22, 2008
  • 49 Answers
SOURCE: cant connect my laptop wirelessly...
Try to reconfigure your wireless network on your DI-524.
To access the configuration page of your router by Default type in on the address bar 192.168.0.1. On the login page by default the Username is admin and leave the Password blank.
If inside the the configuration page of the router
>Click Home
> Click on WIRELESS located on the left side and you will have the wireless setting of your network
> Change the wireless network name
> Under security choose either WEP or WPA -PSK for this type of router.
> Type in your new network key (also know as Passphrase of Key1).
For WEP use 0 to 9 Number or A to F character and it should be exactly 10 characters.
For WPA-PSK you can use alpha numeric from 0 to 9 and from A to Z. The minimun character would be 8.
> Click on apply
> Click on continue.
Try accessing your wireless network first using your wireless computer. If you are connected to your wireless network try connecting to the Internet.
Posted on Jan 30, 2009
jaye_ellen
  • 591 Answers
SOURCE: have internet on desk top pc, but netgear wireless
Once you connect the router, attach a CAT-5 cable between the router and your computer. Once this is done, go to http://192.168.1.1 and log in to your router. The login info is also in the manual. After logging in, fo to the Wireless section; set your network's name (SSID) then your security. I prefer the WPA-PSK[TKIP] for its simplicity. The rest of the router settings are pretty much automatic and not messed with usually. Feel free to ask if you have more questions.
Posted on Nov 11, 2009
I can't get my desk top to connect to internet it tells me my ip address is not right but my lap top goes through my desk top and i don't have any problems getting on line.
your dell needs a network adapter card or wireless card installed is that the case(look in b ack)
if no wireless, then it needs an ethernet cable plugged into modem/router from cin bell and then in back of dell
please advise your network configuration
May 28, 2012 | Dell Dimension E310 PC Desktop
Trying to get internet from laptop. i have a desk
You need to conenct a wireless router to the modem provided by your ISP.
Jun 06, 2010 | Computers & Internet
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
No Internet via zoom X6 wireless router to desk top, lap top ok.
Access your zoom router by using the laptop which still has access to the router.
Your going to have to open your Wireless Network Connection Status window located under your network settings.
If you see this window your going to left click the (details) button
Now you should see a IP DNS server address
for example: 192.168.1.xxx
Type that address onto the address bar of your web browser.
it should take you to your router setup page.
There you will need to check if the lan port is enabled
Feb 04, 2010 | Zoom X6 Adsl Modem/router Rohs...
Cant connect printer to wireless laptop.
have you setup the wireless connection in between the printer and the laptop...
your laptop is working wirelessly with the internet but for making the printer to use it wirelessly the printer should be also a wireless printer.
and if the printer is a wireless printer then you have to setup the connection in between the printer & laptop to work wirelessly.
Apr 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
DESK TOP TO WIRELESS CONNECTION
First make sure you have the correct drivers installed, go to the Belkin website to get the latest drivers for your device.
Next make sure that your router is set to broadcast, and that is in Wireless G mode. You can find that information at the router manufacturers website.
Apr 15, 2009 | Dell Dimension 2400 PC Desktop
Cant connect my laptop wirelessly...
>Click Home
> Click on apply
> Click on continue.
Jan 27, 2009 | D-Link AirPlus DI-524 Wireless Router
Lan internet
the easiest way to setup internet on the laptop, is to go to control panel, and launch the network setup wizard. this will enable you to setup a new network, and scan for a local area network connection. this will also give you access to the troubleshooter. to solve any connection problems or issues, should there be any. If your using a wireless method. Your PC must also be able to transmit/receive wireless Signals. If hardwired you,ll have to use the network setup wizard, as this will auto determine I.P And any other DNS settings et,c.
Hope this Helps Mike @ compurepair.
Jan 14, 2009 | Toshiba Satellite Pro L300 Notebook
No wifi
You need to get a wireless adaptor your laptop did not come with wireless built in. You can get a USB adaptor or a PCMCIA adaptor. Either will work but the pcmcia adaptor will be a little faster
Have a look here
http://www.google.com/products?hl=en&q=pcmcia+wireless+card&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
Hope that helps
Aug 25, 2008 | Compaq Presario Notebook
Networking
netgear kwgr614 i have internet when connecting staight from the cable to the desk top, but when the router is plugged in first there is no connection.
May 20, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
