Question about Overland Data NEO 2000 LTO-3 Tape Drive
Compression not working on NEO 2000 with CA ARCserve
I am using CA ARCserver for backups to my NEO 2000 with 2 drives. The device is set for compression "on" but the data stops below 400GB instead of filling to 800GB. I've updated drivers, firmware etc to no avail. Any help would be appreciated.
My Ca Arcserve is showing that the quantum superload is constantly busy. I can not do anything as it also says that it is busy. I have shutdown and restarted the quantum drive a few times and all still...
power down both the library and computer, disconnect the library, power up the library. Check the operator panel of the library for an online ready status.
Jan 13, 2011 | Quantum SuperLoader 3 LTO-3 Tape Drive
Restoring files after using the Backup utility.
1. Plug in the USB drive that contains the data.
2. On the XMB go to Settings then System Settings
3. Go to Back Up Utility like before but
4. Choose Restore rather than Back Up
5. The PS3 does the rest
You can have the PS3 delete the data file from the USB drive by choosing Delete Backup Data.
Sep 18, 2009 | Sony Playstation 3 (PS3) Console
I have a backup folder for all my courses. I accidently deleted a course in "My Courses" section of the software. I copied a backup file into the igolf folder where all of my courses reside. It's in the...
This solution applies to the newest version of iGolf Neo Sync. If you don't have the newest version download it from the IGolf site. Open iGolf Neo Sync and all of the courses in your backup file should appear under "My Courses". If all of your courses don't show up, click on "Settings" under "MY DEVICE" . On the page that opens you will see the tentative location of your backup files (for example, C:\Golf\Backup). If the location isn't correct browse for the right location. Once you find it click OK. Now all of your courses should show up under "MY COURSES" on the iGolf Neo Sync page. You can then send any of the courses to your GPS.
Jul 13, 2009 | NEO iGolf neo MP3 Player
Restore problem on brightstor
the registry key SQLprotocol made brightstor use named pipes to restore which is not supported in SQL 2005.
Jan 14, 2009 | Computer Associates BrightStor ARCserve...
Backup Problem
80GB is the non compressed and 160GB is fully compressed. Based on my experience youll never get a compression rate of more than 1.5 to 1, so you should expect to get more than 120GB on the tape.
The issue that you are having is that you are using the drivers that either are built into windows or came with the tape drive and not the driver from symantec.
Go into Tools->Wizards->Device Configuration Wizard and follow the step to "Install tape device drivers". This should take care of the compression issue.
Dec 09, 2008 | Dell PowerVault 110T DLT VS160 DLT Tape...
I am unable to get IBM UlTrium TD4 SCSI device drivers for windows 2000 server
if you "have not" using Backup Software (e.g. Symantec Backup Exec, CA), you can try this IBM LTO-4 driver for Win2K.
IBM LTO-4 Device Driver for Windows 2000
Ned Huang
Tandberg Data Taiwan
Technical Support.
Oct 15, 2008 | Computers & Internet
ARCserve Backup to disk Solution
Yes it is possible. You had to create the new media pool and added that in to particular new or current device group. and schedule your backup on that media of that device group . Cheers Parveen
Nov 27, 2007 | Computer Associates BrightStor ARCserve...
SONY LIB-81 Error on LCD screen - Drive Information 51
I think this sounds like the drive is having a issue loading and moving the tape in slot 1.
AIT units are known for having this kind of problem.
Try a cleaning tape and then a new tape fresh out the wrapper for a test backup.
if it fails with a known good tape then its time to send it out for repair
www.tape-drive-repair.com
Tape-Techie
Jul 26, 2007 | Sony (LIB81A3BB) AIT-3 Tape Drive
Overland Data NEO 2000 LTO-3 Tape Drive Logo
42 people viewed this question
Top Overland Data Computers & Internet Experts
David Payne
David Payne
Are you an Overland Data Computer and Internet Expert? Answer questions, earn points and help others
